Question about Casio Exilim EX-S500 Digital Camera
Lens The lens of my camera doesn't come out when I turn it on. It's out like half a millimeter but doesn't go in or out. I don't know what is causing it. If it's possible I'd prefer not to have to get a new camera.
  • 374 Answers
Send it into repairs and have them take a look at it. Might be something they can fix.
Posted on Jul 08, 2007
SOURCE:
Hi. my problem with my camera is that my niece play with it and she pushed the lens mechanism while the camera is on. now, the lens was stuck and doesn't comes out anymore. when i'm turning on
Force it out like it was forced in. Try to rotate the lens. Remember it has to be off. As soon as the lens is half way out, turn the camara on and the lens will go to its position. If not, while the lens is out turn it left or right until it's back to its position.
Good luck.
Aug 24, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
I have a Nikon N65 and an AF Nikkor lens on it. The lens fell off some time ago, and now it does not lock in place.
The most likely culprit is a broken mount on the lens. Some Nikkor lenses have a plastic mount whose bayonet blades can break off when the camera is subjected to a shock. Since you neglected to specify the lens I don't know if this is the case with yours.
If you have access to another lens, try it. If that one stays on then the problem is with your lens. If that one doesn't stay on then the problem is most likely the mount on the camera itself, which is a more serious problem (unless the mounts on both lenses are broken).
Jun 19, 2012 | Nikon N65 35mm SLR Camera
The camera was dropped while it was on. The lens is stuck in the open position. When the camera is first started it sounds like tiny gears spinning but not catching. It doesn't really grind or...
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon SD cameras:http://www../Device/Canon_Powershot_SD880 or
http://www..Guide/Disassembling-Canon-PowerShot-SD800-IS-Lens-Assembly/4093/1
Also you may try this Canon "Lens Error" troubleshooting guide >>http://camerarepair.../fixing-lens-error-on-digital-camera
6.To download the complete service manual for a similar camera model can be downloaded at the link below:
http://www../canon_powershot_digital_elph_digital_ixus.pdf/download.html
Wait 10 sec and click Get Manual .At the bottom of the page.
10_8_2011_7_21_11_pm.jpgCanon SD990 IS digital camera lens with ccd parts can be purchased from eBay >>PARTS-REPAIR-/140607486728#ht_483wt_1642
Oct 08, 2011 | Canon PowerShot SD990 IS / Digital IXUS...
Cant get video out on my gopro after a crash on a hillside. It looks OK at the outside, only some scratches.
I had a cracked lens after dropping the camera, it still worked, just had a fuzzy spot from the cracked lens. I went to Quality Video Components/Rage Cameras and they replaced the lens. The literature on their web page lists other internal repairs they make to GoPro cameras. Maybe they can help you, GoPro doesn't do repairs. www.ragecams.com (wearable video)
But now these cameras are getting so abundant, it may be better to buy one than repair it. The lens was half of what a used camera costs on ebay. Or you can buy just the camera by itself new since you don't need the accessories.
Jul 03, 2011 | GoPro Digital Hero 3 Digital Camera
I have a Canon EOS digital Rebel XT. I was taking photographs the other day when suddenly it stopped working. The camera still turns on and all the buttons are functional, but it won't actually take a...
I hope you have solved this problem if not there is two things that have happened to me one was that I had unlocked the lens and it turned a little which shut off the communications between the camera ad lens. The other is where the gold contacts between the camera and lens became slightly dirty with a hazy this is easily fixed with a DIY. using a pencil eraser gently polish the contacts between the camera and lens both sets of contacts, be careful not to get dirt into the camera or lens when you are doing this. Don't use a puffer or any air.
May 07, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I lost the lens cap for my wide angle lens on my Maxxum 7000. Are they available and if so, where can I get one?
I don't know which wideangle lens you have, but there most likely is a number giving the the size of the thread in front of the lens. If there isn't, you can measure it with a ruler marked in millimeters. Either way, simply order a lens cap of that size online or buy it at a good camera store. If you can't find the size, simply take the lens with you to a camera store and find a lens cap that fits. You don't need to find a specific brand, about the only thing that matters is the size. Unless, that is, you care a whole lot about the styling...
Jul 08, 2010 | Minolta Maxxum 7000 35mm SLR Camera
Power problem with 450
The LCD goes dark after the camera has been inactive for a time, to save battery. When that happens, you can easily restore the LCD display by half-pressing the shutter. If you want to, you can turn this off by selecting menu-setup-SleepTimeout and turn it off. (I don't recommend it, though, as the LCD always on will drain your battery).
Sep 08, 2005 | Pentax Optio 450 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
29 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
