Question about Cameras
Two switches on my Konica Minolta A2 don't work: they are the circular direction switch on the camera back, and the ISO change switch on the left side. Also the anti-shake lamp lights up sometimes and will not turn off. Can this be repaired?
  • Cameras Master
  • 19,396 Answers
To repair it the camera must be taken apart, and the switches teated with circuit cleaning solution or replaced.
Posted on Oct 24, 2008
  • 13,433 Answers
Most likely yes if the switches are broken the repair wont be much
Old pictures show up fine but new pictures show up very darkkk
two reasons for this are possible:
1) you changed the exposure compensation by mistake to minus something... - see below - change it again to +- zero:
Konica Minolta MAXXUM 5D Instruction Manual Exposure Compensation
2) you should have the ISO settings to auto:
Konica Minolta MAXXUM 5D Instruction Manual Camera Sensitivity iso And...
Jan 28, 2014 | Konica Minolta Dynax 5D / Maxxum 5D...
I bought a used Konica Minolta DiMage A2 online. Is it normal for the image to change from color to black and white, then back to color, repeatedly, in the viewfinder and screen when preparing to make a...
When it goes to black&white the lightconditions are probably too dark. It has a better range in black&white so it switches. (but if I remember correctly this only happens when you're in video-modus 'cause in photo-modus the flash will pop up)
Sep 29, 2011 | Konica Minolta DiMAGE A2 Digital Camera
The manual focus ring on my camera doesn't work. The ring turns but does not seem to adjust the focus. Automated focusing still works. How to fix it?
Two methods:-
1. Use the slider switch on the left of the camera to set it to MF (manual focus). The focus ring is an electronic one rather than a physical control like the zoom ring, so the response can seem slow.
2 Go into the camera menu and enable DMF (Direct Manual Focus). This allows you to override the autofocus simply by adjusting the focus control, but it does not work if the slider switch is set to the AF C setting (continuous autofocus), it only work in the AF-S (AF only activates once when the shutter is half pressed).
Jan 31, 2011 | Konica Minolta DiMAGE A2 Digital Camera
It takes very grainy pictures in cloudy weather and at dusk. Even a very basic digital camera won't have this problem. Wonder if there is any solution, or it is a factory defect.
Check you ISO settings. If it is set high (400 or higher) there will be increased sensor noise. Sometimes a camera will automatically set a high ISO when the light is low. You can check the ISO in the exif data on your computer, by right clicking the file and checking the advanced properties. If the noise is excessive, send it in for repair.
Jul 05, 2009 | Konica Minolta DiMAGE A2 Digital Camera
Grainy Pictures
I have an earlier version of this camera: a minolta  dimage 7. While your camera is better(later) than mine beyond ISO 100 these cameras tend to be noisy.  The only solution is to asscpt the noise since hou will need a high ISO in order to use an acceptable shutter speed  and use a noise reduction program (noise ninja, neat image, helcion noise filter). One of these may be free- i think helcionbut aside from changing to a DSLR this is the best solution
Jan 17, 2009 | Konica Minolta DiMAGE A2 Digital Camera
Need a manual for Konica Minolta DiMage A2
I have the complete instruction manual for the G400. I think I can just email you the whole file if you like.Let me know and I will do that.
david_brosius@comcast.net
I have this camera and cannot get it to focus properly.
Nov 24, 2008 | Konica Minolta DiMAGE G400 Digital Camera
Konica minolta a-2
hi, i need help to find a good setting 4 my camera, minolta a2! could u help me?
thanx, tibi
Dec 05, 2007 | Konica Minolta DiMAGE A2 Digital Camera
What are the available ISO rating for the DiMAGE A2?
The DiMAGE A2 sensitivity can be set to Auto, ISO 64, 100, 200, 400, and 800. When Auto is selected, the camera automatically controls the sensitivity within the range of ISO 64-200.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Which types of filters can be used?
Please use thin type filters to prevent vignetting on the corners. The following filters are vignetting-free. Konica Minolta 49mm AC L37 (UV filter) (Thickness is approx. 5.5mm in total, and approx. 3.4mm excluding the screw part.) Konica Minolta 49mm ND 4x filter 49mm type causes vignetting. Please use Konica Minolta filter adapter (49mm > 62mm) and 62mm Polarizing filter II (Circular) in combination.
"Milky" Viewfinder
After a quick look at the manual you can find in the setup menu 3 "reset defaults" which shoud set you camera back to its first settings.
Sep 13, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
