Question about JVC Car Audio & Video
KD- R538 radio wont turn on
The radio wont turn on, I'm trying to install it into my pontiac 2004 sunfire. It seems like its not even getting any power at all.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • JVC Master
  • 2,226 Answers
Make sure you are getting power to both the red and yellow wires. Red is switched or ignition and yellow is constant and controls the memory of the radio.
Posted on Feb 22, 2012
I have a short somewhere in my 2004 Pontiac sunfire radio wiring that I cant find.
you may have shorted out the radio itself ---if changed fuse test line from fuse to radio if power then radio most likely damaged
Jul 28, 2017 | Pontiac Cars & Trucks
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
I have a 2000 pontiac sunfire an the radio seems to stay on even when the car us turned completely off. What does that mean because it keeps killing my battery.?!
The most likely answer is that your vehicle's door pin switches aren't working. When you open the driver's door, does your dome light turn on? Your radio works with the vehicle's data bus to stay on until the door is opened; if the system can't tell that the door has been opened, then it won't turn off. The door pin switch should be mounted at the front of the door opening.
Aug 16, 2011 | 2000 Pontiac Sunfire
2004 sunfire ignition key wire does it have one/ instaling new radio only have constanyt 12 volt radio power on off button does not shut off do i use this wire and where does it go the ignition wire...
Hi, your factory Sunfire wire colors are pasted below. The yellow wire should be accessory. This should connect to the stereo's red power wire. The orange "always hot" wire should connect to the stereo yellow wire--this is only used to keep your station presets in memory. Please let me know if you have more questions, and thanks for using FixYa.
2004 Pontiac Sunfire Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 04, 2011 | 2004 Pontiac Sunfire
Someone stole my 2003 pontiac sunfire radio, so i got a 2004 radio from the wreckers, installed it and it came up locked, how do i unlock it ?
You need to get the radio code which will cost you, Search for radio codes online or call the dealer. The dealer will not give you the code intil you can prove you own the car but since this is a replacement from another vehicle someone will need the model and serial number of the radio.
I personally would of had a aftermarket one installed. It would of saved you alot of aggravation.
Mar 30, 2010 | 2004 Pontiac Sunfire
I have a 2005 Pontiac Sunfire. How do I set the
key on & radio off use the seek and scan buttons to set the clock
I have a 2004 Pontiac Sunfire. The battery to my
first you should double check to make sure the batteries are installed correctly ,then get the new car manual out of the glove box ,and check for the reprogram procedure for your remote . every car manufacture has there own procedure , example,I have 03 mustang mach 1 the procedure goes something like this.turn key to on position..put drivers side window up then down open and close driver door then turn lights on and off then radio on off and so on
Jan 05, 2010 | 2004 Pontiac Sunfire
Car Audio & Video Logo
185 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
