Question about Bosch Dryers
Bosch condenser dryer drum has stopped turning it seems to be stuck
If the drum will not turn by hand and the motor hums the fan is probably stuck on something. My fan broke into pieces and some of the parts got stuck stopping the drum. Pull the back off and replace the fan.
Posted on Nov 15, 2008
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
Candy dryer goc 590c
There may be a loose belt or the drum may be stuck with sticky stuff and needs cleaning.
Sep 05, 2014 | Dryers
What is recommended load size for Bosch Nexxt dryer
The Bosch Company is probably known best for its high-end dishwashers, but the company also produces other home appliances including refrigerators, stoves, washers and dryers. Bosch dryers carry the Energy Star rating. A Bosch dryer has a structured drum that provides more thorough drying and condensation drying for faster cycle completion. If mechanical problems occur with the dryer and troubleshooting efforts fail, performing a reset may return the dryer to normal functioning.
1Unplug the Bosch dryer from the power supply and then reconnect to the power supply.
2Replace the local fuse or reset the circuit breaker if a fuse or circuit breaker has tripped.
3Place items to be dried into the dryer and select a program. Close the door firmly.
4Press "Start/Pause."
5Press "Stop/Cancel" if the above steps do not resolve the problem.
6Pull the dryer out from the wall and use a standard screwdriver to remove the central metal plate on the back of the dryer.
7Locate the small red reset button above the heating element and press and hold the button for a few seconds. Release the button.
8Place the back access panel back on the driver and move the dryer back against the wall. Repeat steps 3 and 4. If the problem continues, press "Stop/Cancel," turn off power to the dryer and contact an authorized service technician for assistance.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
I have a Bosch Maxx Sensitive WTE84100AU dryer which stops a few minutes after the dryer starts. The dryness lights all turn off. The clothes don't dry.
There is a thermal overload switch behind the back cover. It has overloaded because the big lumps of lint in a) lint basket, b) small vents either side of the vent basket (use a chopstick), c) in the big pull out condenser unit at the front bottom left, and d) reach right to the slot for the condenser unit and scrape all the lint out of the back.
Now you can do the reset - unplug your dryer first. You will need a Torx T15 screwdriver to undo the all screws around the fan & drum cover, then use a thin blade to pop off the back cover. If you don't have a Torx screwdriver, you will have to buy or borrow one - there are just too many screws to use anything else.
I was thinking of drilling a 6mm hole in about the right spot so I can poke a chopstick through to press the reset button. 6607f76a-b20b-43ef-8059-a4858d51d2dd.jpg
Jan 08, 2013 | Bosch Dryers
I have a Bosch Exccel condenser dryer WLT6305GB/01 FD 8309 200147 it seems to get warm not hot, isn't drying properly, stupidly replaced the heating element and thermostat unit before checking if it...
could be the condenser unit..........they get blocked up with lint..........i take then outside and flush with a hosepipe............
Jul 27, 2017 | Dryers
Bosch Condenser Dryer Classixx
I found this on, I am going to try it this weekend and I will post an update.
"Ok if you remove the left hand side panel then located at the back is the drain pump
remove the hose on it which goes up to the bottle and blow up it to make sure its clear.
If thats fine then remove the pump and clear any fluff thats in there and make sure the impeller is ok and turning fine.
Then refit and try again hopefully this should sort it out.
let me know if you need anymore info."
Dec 22, 2009 | Bosch Axxis WTL 6003 Electric Dryer
Dryer drum will not turn
check to see if there is a little red button on the back if so push it in thats your re-set button
Mar 24, 2009 | Dryers
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
286 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
