Question about Jensen VM9511TS AM/FM/CD/DVD/SD Player/7" LCD Car Video Player
"'Jensen (VM9311TS)' Will not Accept CD or DVD".
I have a friend who owns a Jensen VM9311TS (actually the VM9311TS kind; not the VM9511TS kind) automobile radio/CD~player/DVD~player. Anyway, this particular automobile device will not accept any kind of CD or DVD at all. Whenerer the CD or DVD is inserted, it comes back out within 7 seconds. Can anyone help me resolve this particular problem?^^ Thanks to whom it may concern. ^_^
  • 1 more comment
  • ranson_60 Oct 29, 2008
    i have the same damn problem
  • cfowler1 Jan 27, 2009
    mine will take a cd half way then spit it out
  • dbearheart Feb 14, 2009
    same problem
Cerfer39
  • 709 Answers
SOURCE: jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Posted on Nov 30, 2007
SOURCE: BackGorund Change on a Jensen VM9311TS In-Dash DVD player
yes there is an e-brake override code! ive been using it for a year without the peach wires! i've never used the pink wires before. connect a second screen or any tv (temporarly) or what ever and there is no blue screen for the second screen...insert a dvd. on the remote push stop twice and then 1, 2, 6, 4. push the joystick on the unit down twice, and then click it inward once. then press sys. setup on the remote twice to save your settings. and there you go!
Posted on Mar 09, 2009
SOURCE: jensen player
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
Posted on May 05, 2009
SOURCE: bypass parking break feature on the Jensen VM9311TS
with Dvd playing (use toggle switch between the ground and pink .. switch on and off several xs till dvd plays) then on main remote push
stop twice, then 1264, joystick south twice, then once, then sys setup twice to save
Posted on Jun 20, 2009
MNfisherman
  • 11896 Answers
SOURCE: INSTALL JENSEN RADIO
There should be a label with all the wiring on the player/radio itself.
Yellow goes directly to battery to hold memory
Red is for ignition switch to power on
Black is ground
Blue is not used unless you are power an amp or other accessory.
All other wires are for speaker wires.
You can get a quick connect harness so you don't have to cut your factor vehicle wiring. If you did do this already, you can go to installer.com to find out which wire is for what.
Posted on Sep 23, 2009
Ipod 4th gen not charging on Jensen VM9311TS
The issue is that the 4th Generation iPod takes far more energy to run than your 4gb iPod. Updating the firmware has nothing to do with it. It's the amount of energy/voltage that this new 8Gig unit takes to run.
Think of it as a 4 cylinder verses an 8 cylinder engine. The 8 takes far more gas to run.
Blessings,
A/V Media Guy
Nov 21, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
When i turn on my vm9311ts it comes on at a louder volume
page 12 of your manuel left corner volume adjust program check there
Jan 07, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
Make is jensen vm9311TS
HI,
I'll let you know if the codes are available..
Jun 03, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen cd/dvd player
be more specific im relly good at this kinda stuff this is a car cd + dvd playable player right is it a radio all in one or just a player if its just a player what kind of radio do you have any other info you think i may need will help
Feb 06, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen VM9311TS DVD/CD No sound
sounds like the channels are out or the system has a malfuction on the inside i recommend you return it for a new one.
Nov 24, 2007 | Jensen VM9510 Car DVD Player
Brake wire for Jensen VM9311ts
You first have to figure out which one of these wires goes to ground potential when the brake is engaged. Get a digital multimeter set it to read resistance (turn the dial to the omega symbol)and then connect one end to ground of the car try the outer ring of the 12 cigarette lighter and the other using the tip to pierce the insulation of one of the wires, then press the parking brake. The meter with the brake not pressed should have ---- when the break is pressed the meter should read 0000 or some value less then 1.000 ohm. The wire that goes to ground when the brake is pressed is the parking break wire and attach your DVD player brake wire to that. My money is on the solid green wire.
Sep 21, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
you may have to open the unit up and manually turn the unload and load gear to eject the DVD from the carriage. The load and unload gear is a round gear located under the DVD carriage and is attached to the load and unload motor
Sep 20, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Sep 19, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Car Audio & Video Logo
306 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
