Question about Whirlpool 21.7 cu. ft. Side-by-Side Refrigerator ED22PQXF
Whirpool ed22pexhw trouble restarting
Frig runs gets cold stops and won't restart all the time, turn the controlls for the frig it will start eventually or right then, turn them down or off and on and to start the frig somtimes seems to run to long
esanto2
  • 3 Answers
SOURCE: whirlpool refrigerator gold conquest shuts off
Start at the basics; shut off, and then remove front grill and if necessary, back covering(s). Vacuum and/or blow compressed air into condenser fins, including coils in the back; especially paying attention to piping that looks to expand or balloon, clean these carefully with a rag and warm water to remove grime; retry. If issue continues, turn up your front thermostat to see if you start to hear continuing clicking sounds from the back, if so that may be your overload switch going bad, in which requires replacing. ee
Posted on Dec 07, 2008
joecoolvette
  • 5660 Answers
SOURCE: Upright frig/freezer not getting cold, compressor running
1.My first suggestion, is to clean out the compressor area located at the bottom of the refrigerator. Refrigerator unplugged from power. Remove the cardboard panel from the bottom, (Watch the water line), and use a vacuum. I also bring the refrigerator towards an open door, and use compressed air to blow it out, afterward. You'd be surprised how much gunk builds up here, and how cleaning it out will help your fridge tremendously! (Good tip for air conditioners also. Power unplugged, case cover removed. Use a garden hose to flush the fins out. Let it dry, reinstall the cover) 2.Your refrigerator may be low on Freon. This requires a professional to purge the system, and reinstall Freon and lubricant. (Oil)
Posted on Jun 15, 2009
heatman101
  • 43501 Answers
SOURCE: have side by side will thaw out all the way get to
Here are a couple of tips that will give you some things to check out...
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 15, 2010
livewire874
  • 618 Answers
SOURCE: My Side by side whirlpool frig w/ice maker stopped
Either the start relay on the compressor is bad or the compressor itself .
Posted on Nov 01, 2010
  • 29 Answers
SOURCE: frig will not stay cold unless you keep moving the
the thermostat is most likely to go. i would replace that. if you want to make sure and you have a meter handy. set it to then ohms scale. turn off the power remove control cover set a test lead on each side of the control knob. as you go higher your resistance number goes higher. then you no its good. to test the thermostat you would have to turn power on. i dont recommend it unless certified, if seen some things. thanks hope this answer helps.
Posted on Jun 20, 2011
Won,t freeze frig won,t get cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 18, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
The freezer is working and frig not .any ideas i looked at fuses and reset many times
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 12, 2011 | Dometic RM2852 Refrigerator
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only...
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Sep 08, 2010 | Refrigerators
Maytag P MFD2561HEB model the frig is not cold but the freezer is fine. How do we set the frig control?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Refrigerators
The frig. stoped working but the freezer on the bottom is still working what can I do
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure the fan is running when the compressor is. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 27, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frig section not cooling and at time appears to stop but freezer is ok
There is one compressor, condenser and evaporator in all refrigerators. The part that makes the cold inside the unit is the evaporator. It's in the freezer, behind a barrier on the back wall. It's a "coil" with many small fins. There is a fan that blows air over the evaporator which makes the air cold. This air comes from the freezer and stays in the freezer. The cold food section (the refrigerator) has a control that opens a hole for air to pass from the freezer to the fridge. This being said...you can rule out the "temperature control" for the fridge.
The sound you hear could be the compressor relay, the evaporator fan or maybe something else. It could be bad, it could be not too bad. (Like a fan blade a bit unbalanced with dust)
OK,,, back to the evaporator. There is a little heater next to the coil that turns on every 8 hours or so to defrost the coil. That's called the "defrost cycle". Makes sense, no? If the defrost timer (common problem) or defrost control board (common problem) go bad, your evaporator coil freezes up, and that's not good for anything in your refrigerator. But it can often keep the freezer section cold. You can easily disassemble the evaporator cover in the back of the freezer and take a look. If it looks like a block of ice, you probably have a defrost issue. An even, thin coat of frost is OK, but lots of ice is a no no.
Jun 26, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Fridge compressor problem ?
Seems to me you have a faulty cold control. (behind the temp control).Not too expensive , about 40 bucks.
Feb 23, 2008 | Refrigerators
Frig just not Cold
Check to see if air is blowing into refrigerator compartment.If no air is blowing.It may be that the settings on your dials are not right.If they are and air is not blowing,your evaporator fan is not working,or may be obstructed.
Dec 03, 2007 | Refrigerators
Everything in frig is frozen and it won't turn off.
If the compressor is running non-stop then the temp. control is not telling it that it's "cold enough". If the compressor isn't running non-stop then you should look at the air damper (little window) that lets the freezer air into the refer compartment... if it's stuck open then you will always get cold air pushed into the fridge eventually becoming a freezer in itself.
Jan 17, 2007 | Kenmore 74844 / 74842 Top Freezer...
Refrigerators Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
