Question about Poulan Pro " Pro" Self Propelled Mower
My poulan mower wont start - Poulan Pro " Pro" Self Propelled Mower
  • Poulan Master
  • 2,239 Answers
Start by relacing the fuel in the tank with fresh, check for a spark at the plug, if there is no spark try a new plug, still no spark replace the ignition unit.
Posted on Feb 13, 2012
Starts but wont drive
Sounds like your drive belt came off the pulley. Look at the bottom of the engine. If you see a loose or broken belt, that's the problem.
Aug 29, 2016 | Poulan Garden
I have a poulan 6.25 self propelled mower that wont start soun like its not getting fire
First make your kill handle is pulling your cable all the way back.Sometimes the cable will rust or even break inside its sheathing. to test take a peice of wire and tie it off by pulling the arm all the way back then start it. If that works replkace kill cable
Jun 17, 2012 | Poulan Pro 22" Self Propelled High Wheel...
I have a poulan riding mower and when i go to start it it only turns over a couple times then it wont move anymore
sounds like the battery is weak try and jump start it with your car if that doesn't help try and jump it at the block and solenoid the battery cables could be bad
Apr 09, 2012 | Poulan Garden
MY POULAN PRO 6.5 WONT START....nEED TO REPLACE SPARL PLUG BUT DO NOT KNOW 'right one"..
Take the old plug out, any auto store should be able to match it up.
Gary
Aug 13, 2011 | Poulan "Poulan" Push Mower
Lawn mower cranck but wont start...
Since you already checked for spark and air I would drain all the fuel out of it and check that fuel for water. Over time some lawn mowers end up with contaminated fuel. You can see the water sitting on the bottom of the fuel if you let it stand for a bit in a small plastic bowl.
Be sure to empty and dry out you fuel can as well. Especially if the mower stopped running right after a refuel. Which is a good sign your gas can is contaminated too.
Jun 26, 2010 | Poulan "Poulan" Push Mower
Why wont my poulan riding mower start with the key and new battery keeps going dead
clean all the connections from battery to starter, selonoid connections to and ground cable where it connects to the battery and to where it connects to the frame it might just be a bad connection on frame i seen alot of poulans with this problem.
Jun 06, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
May 01, 2010 | Poulan Garden
Lawnmower wont start
Are you getting spark first of all. If you are getting spark do you have good gas? If you have good gas most likely your carb needs some attention maybe you had some old gas sitting in there and something inside is gummed up it might need cleaning.
Sep 19, 2009 | Poulan "Poulan" Push Mower
17 hp poulan mower 42" deck wont start
Recheck the valve lash sometimes they are set too tight. Do a compression test if the valve are set ok. If it indicated lower than 80 psi it may be a burn out valve.
Jul 20, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan Pro " Pro" Self Propelled Mower Logo
140 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
