Imac powerpc g4 will not shut down or restart properly and will not recognize external hard drive
Won't shut down or restart properly - it just goes to screensaver and i have to push the power button on the side to shut it off. It also no longer recognized my western digital my book external hard drive. I tried unplugging everything. I tried a "Safe Boot" holding the shift key - it did not boot up, it just stopped and the screen went black.
  • 1,606 Answers
1. Press the power key and immediately press and hold shift-option-p-r until you hear a second startup ****. (This resets the parameter RAM).
2. Press the power key and immediately press and hold command-S. The screen should go black and show a verbose listing of the boot process in white type. When it stops, you will see a flashing cursor at the end. Type the following: fsck -f, then return. This will start a check of the file system, and the fsck program will attempt to repair any errors found. Wait until the program displays the results (it can take a while if you have many files). Post your results here. If it finds errors and corrects them, your problem may be solved.
3. (Don't do this unless the file system comes up OK and you are still having problems.) With the computer off, press and hold Shift-Cntrl-Option+Power for 5 seconds, then press the power key. This should reset the power management unit.
Posted on Feb 17, 2012
  • 37 Answers
SOURCE: i need a manual for my imac.
Is this what you are after?
http://manuals.info.apple.com/en/iMacG4_15inchFlatPanelMultilingualUserGuide.PDF
http://docs.info.apple.com/article.html?artnum=50018
Hope this helps. If so, don't forget to rate my answer pls.
Hope it helps
Posted on Mar 20, 2009
kenezz6396
  • 64 Answers
SOURCE: Transferring software and files from PowerPC G3 to PowerMac G4
to mount somthing in a mac is basicly cutting it on for use.
For example if you instal a flash drive or an hard drive via an out side connection, The mac will mount it so you can use it.
Posted on Aug 09, 2009
citroenchris
  • 600 Answers
SOURCE: PowerPc to an intel proccessor.
The G4 powerbook Im typing this on is running 10.5.8. It is only snow lepeord that is intel only.You cannot upgrade the g4 chip.
Posted on Oct 24, 2009
  • 1619 Answers
SOURCE: iMac G4 Mac Desktop: i have a IMac G4 that when i start it a folder wit...
It can not find the hard drive or the startup folder on the hard drive. Try and fix that by putting in the original boot cd/dvd and repair and choose your hard drive start up folde as boot device. If you can not your hard drive may have died.
Posted on May 23, 2010
  • 1121 Answers
SOURCE: How do i installe Windows 7 on western digital m'y
i find a site who may help you, but is hard work.
http://www.simplehelp.net/2009/01/15/using-boot-camp-to-install-windows-7-on-your-mac-the-complete-walkthrough/
Good luck
Posted on Aug 07, 2010
Imac G4 0s 10,4.11 need a flash to watch hulu free tv
You can't watch Hulu on a PowerPC iMac G4. You need an Intel processor based Mac to watch Hulu and Netflix.
Dec 19, 2012 | Apple A1106 Powerbook G4 15", 1.67 Ghz,...
My IMac g4 has a not enter sign logo with flashing folder , after I installed a new 250GB hard drive that has OS X 10.5. I even updated my RAM up to 1000 GB. When I re-installed the old drive it work, but...
The folder and do not enter sign means that the drive is not compatible. I'm going to guess that the drive came out of an intel Mac that had leopard loaded on it. This is not going to work with a PowerPC Mac. Do a clean install of leopard and you should be fine. I believe g4's go up to 10.5 and g5's go up to 10.5.8.
Nov 14, 2012 | Computers & Internet
My Nancy Drew computer game won't work
Hi longview924,
Unfortunately there is no way to make that game run on your mac. Your mac uses the older powerPC architecture (all G3, G4 and G5 macintosh machines use this architecture) but the game requires that you have a mac using the newer intel architecture.
I found the details of the system requirements here:
http://www.buzz99.com/1167/nancy-drew-trail-of-the-twister-system-requirements/
Intel and PowerPC processors are very different in how they work (Intel chips are CISC chips and powerPC chips are RISC chips), which is why there is no way around it. This is also the reason why apple dropped support for the powerPC architecture in mac OS 10.6 upwards.
Without meaning to sound harsh, it may be time to consider an upgrade - macs are very expensive but the intel macbooks are leaps and bounds faster than the powerPC range :)
Jul 03, 2012 | Video Game Consoles & Games
Internal hdd made external
just buy an external enclosure with the correct output wires, most come with usb
May 11, 2012 | Seagate U6 (ST320410A) 20 GB Hard Drive
Sims 3 won't install on my imac G4. I have Leopard 10.8 so I have the correct system requirements. When I click on install it keeps coming up Not supported on this architecture?
If you read the system requirements of Sims 3, it says that you need at least an Intel Core Duo processor, which the iMac G4 does not have. The iMac G4 has a PowerPC processor.
Jan 31, 2010 | Apple iMac G4 Desktop
Oct 18, 2009 | Apple iMac G5 Desktop
Aug 09, 2009 | Computers & Internet
Steady buzz coming from computer
Personally, I think your CPU is to far to come back. I'd trade it in.
Aug 13, 2008 | Apple eMac Desktop
LACIE DRIVE NOT READING
try going to the manufacturer web site for the make of the hard drive
find a download for that model and select mac as the operating system\
download and run
Dec 02, 2017 | Computers & Internet
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
