Question about Dynex 32 in. LCD Flat-Panel HDTV
Dark spot on screen
Approx 6inches in with and 12 inches in length on my left side of the screen
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Ok Iam afraid my question was misunderstood. I have a 70 inch mitsubishi projection TV. it doesn't have color outline or 3D imiging. It has a dark section about 6inches from the top down that is dark not...
I would take it in and have it devices professionally. It may just be dusty inside, however having a pro do it is best. Use warranty if applicable.
Aug 29, 2014 | Televison & Video
Dark Spot on Lower left screen
1,white spots appeared on screen,means the DMD is broken,you need a new DMD. USD150-200
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 03, 2014 | Acer H5360 3D DLP Projector
Recently the left side of the screen is dark (about 4 inches). I put in a new bulb but the dark spot remains. Is this fixable?
Sounds like a classic "Light Tunnel" defect. This part can be replaced in pieces, but can be tricky. I would not advise attempting this, rather for a DiY you should replace the entire Light Engine. The PN will depend on your Service Model # ...WX or WAX... and the version Id #.
Mar 13, 2010 | Samsung HL-R6167W 61" HDTV
Large yellow blot on the left side of the screen.
that sounds like a very expensive repair I'm afraid
, it is the light engine that is bad
Larry D.
Aug 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Dark area on screen.
i have had the same problem with the dark patch and found out it was because i had a speaker sat too close to the tv!!!
Apr 04, 2009 | Maxent MX-26X3 Television
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
42 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
