Question about Traxxas Link 2.4 Ghz 5 Channel Receiver P/n 2218
Can not get a traxx 2.4 ghz controller to work
When the unit is hooked up i turn on the controller nothing lights up on the reciever i tried binding it did not help
There is a flashing red light below on the left side of my firebox
THAT FLASHING RED LIGHT IS PROBABLY THE RECIEVER FOR YOUR REMOTE CONTROL & EITHER IT'S SIGNALING PROPER OPERATION, OR YOUR BATTERIES AT FIREPLACE RECIEVER ARE LOW, & SOON THE REMOTE WILL NOT OPERATE IT AT ALL. CHECK THE BATTERIES!
Dec 25, 2012 | Heating & Cooling
I have a Rocky Mountain KAT-TRAXX Radar.laser. g-force, it will not go go to Radar detector mode when I turn it on or when I try to select Radar mode. This option is gone
Lol fake so you are telling me that whenmine detects cops from miles away its lying even though I see them. Read the description *******! He had the Kat Traxx. That unit does not have a radar scrambler or claim it does. It has a laser scrambler which by the way are still active scramblers and laser scramblers are still legal. As for your problem, call Rocky mountain radar they are helpful and will talk to you to try and fix it if not you can send it in to them and they fix it for you.
Nov 09, 2011 | KAT-TRAXX Radar Detector
It won't turn on. It buzzes but that's
Blades are bound up. Unplug the unit under the sink and using an allen wrench (one should have come with the unit, looks like a bent rod with 8 sides on it), insert it into the manual turn fixture on the bottom center of the ISE. Use this to turn the unit by hand to see if you can free it. If you can free it, see if you can find something inside the sink drain that might have caused the blades to bind up. Remove any debris and reset the circuit breaker, a small button, on the bottom of the unit as well. Also, the ISE needs to hang straight down below the sink. If it is pulled one way or another due to the way it is hooked to the plumbing, the blades may bind up and keep from running.
Sep 11, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Bose 321 series II is not responding to the control remote commands. Everything else does (TV, VCR,etc), but the BOSE receiver does not.
Replace the batteries from the remote control. Press and hold the TV button on remote for 5 seconds. If the red light shines bright, your remote is OK since it is showing it's programmable side. If unit still won't go on using the remote, reboot the whole system by unplugging the power cord and other wire from the Subwoofer. Wait one minute, then replug all and see if the system displays BOSE 321 in front when re-connected. If so, try the remote and if that doesn't work, your dead, the Infra red communication device from the unit to the remote is busted inside the unit and needs to be returned to the company like mine!!!!!
Jul 16, 2009 | Bose (321GS) System
My 1/2 hp Chamberlain garage door stops while going down even when I am holding the wall unit. If I stop it and restart it goes a little further and then stops. Both sensors have green lights and they are...
On the back of the motor unit you will find the down force control. You may have to remove a light lens depending on your model. Increase this a 1/4 turn and try.
May 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Just recieved a type 6 dreamgear wireless controller,doesn't work
1. Ask gifter/seller if it ever worked. If not, return it. What connect do you hit?
Apr 07, 2009 | DreamGear TYPE 6 2.4 GHz Wireless...
Out of range ?
was there a storm ie electrical try unplugging the main set and see if the busy line goes away if it does you can try unplugging them from the electric for while and then replug them to see if this reset them if the busy line return it appears the phone(s) are done
Jul 30, 2008 | GE 25932 Cordless Phone
Gears of War for Vista and Logitech Rumblepad 2 directional issues (fwd/rev)....
There is a way to fix it: go into your control panel under Game controllers, select your logitech cordless rumblepad 2 and hit
properties -> settings -> Enable Swap Mode -> close -> ok
Now start Gears of War and go into the options menu under controls for the controller.
Invert Axis = yes
Joystick Mode = Left-handed
This fixes the problem with the joysticks, but there is still a button fix that needs to happen. operations for buttons 2&3 are swapped, same thing with buttons 1&4, 5&7 and 6&8. I don't how to fix this problem yet.
Dec 30, 2007 | Logitech Rumblepad 2 Vibration Feedback...
No power!
okay, this seems like either the fuse hase blown in the actual mains plug, or the mass fuse inside the device, it looks like this very small glass fuse, same size as an ordinary fuse, its just seethrough. see if you can get a replacement for it, you may need 2 open the unit to check if it has blown, it will be black or a "burnt" colour from inside! if you dont want to open it, take it to any electronics store, they are bound to check for you, but these fuses don't cost more that $1 or 50pence!
hope this helps
Dec 22, 2007 | Panasonic SC-HT730 System
Unable to recieve mms
call t-mobile tech support directly 1-800-937-8997
Dec 10, 2007 | T-Mobile MDA Pro Smartphone
Traxxas Link 2.4 Ghz 5 Channel Receiver P/n 2218 Logo
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
