Question about Avanti Refrigerators
AVANTI EWC 120B WINE COOLER IS NOT COOLING. FAN IS RUNNING, LIGHT IS ON...STILL NO COOLING. WHAT IS THE PROBLEM?
  • 1314 Answers
SOURCE: Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Posted on Jan 01, 2008
  • 1314 Answers
SOURCE: my cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
Posted on Jun 03, 2008
SOURCE: OSTER WINE COOLER
I followed the advice of Ancient Bob and located the heat shrinked fuse as he described. I removed it from the circuit board using a very small tipped soldering iron and repaced it with an inline fuse holder with about 1" leads(Radio Shack or Auto Parts store) and carefully soldered it in place on the circuit board. This makes a fuse replacement a snap if necessary later..I used a 5A 250V fuse as original. It has been running fine for two weeks now, I think the fuse in question blows if the ambient temperature gets too high in the room-a design defect (my opinion). As Ancient Bob said, the total cost was about six dollars icluding 3 extra fuses. Care must be taken when removing the solder, or resoldering the circuit board. It's not complicated but must not be sloppy. After removing the original fuse I drilled out the circuit board fuse holes (they may fill with solder as a byproduct of removing the fuse) with a tiny drill bit to make the installation of the inline fuse neat and easy. Good Luck
Posted on Oct 03, 2008
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
SOURCE: sylvania table top wine cooler
go back where you bought it...buy another one and bring back the one thats flashing,get your refund and walk home with a new cooler
Posted on Jul 03, 2009
Can I get an electrical schematic
Google (Avanti)(EWC-12)(schematic) without parens, of course.
May 24, 2016 | Avanti EWC-12 Wine Cooler
Hys60 12 kd 130c circuit
Hi, This is very easy designer this Board, I 'm a repair center from this boards.... what do you need from shematic this board, question for my and I give help for you from Brasil in www.indexdata.com.br.....
Jun 21, 2013 | Avanti EWC-12 Wine Cooler
My avanti wine chiller mod ewc 16 b serial n.0800854 stop cooling what can i do ?
I've added a link for an Avanti ewcb,
http://www.retrevo.com/support/Avanti-EWC16B-Refrigerators-manual/id/867bh235/t/2/. There you can find a complete manual on the product which will help you to locate where the problem is coming from. hope I've helped!
Oct 24, 2012 | Avanti EWC16B Thermoelectric Wine Cooler...
Take apart AVANTI
here is the reference manual for that model hope it helps http://www.avantiproducts.com/manual/ewc12.pdf
Apr 22, 2012 | Avanti EWC-12 Wine Cooler
Avanti EWC-12 circuit board replacement (correction)
the green an yellow wire is a ground. Look for an area on the board with a ground symbol earth.gif. Can you not match the location from the old board???
Either way the black and red are your positive and negative power, while the third is the ground. The wire probably are located in close proximity to each other.
Let me know if this helps
Jer
Jan 16, 2010 | Avanti EWC-12 Wine Cooler
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
Oil appears to be leaking from my Avanti Wine Chiller
Is it cooling ok?Where did you find the oil? If is not cooling and you see an oil spot inside or outside where the compresor is that means there's a refrigerant leak.
May 01, 2009 | Avanti WC3200BG Wine Cooler
My cooler cannot cool
May 27, 2008 | Avanti EWC28 Wine Cooler
Refrigerators Logo
63 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
