Question about Amana Refrigerators
Amana refrigerator trips breaker
When I plug in my refrigerator, it trips the ground fault circuit interrupter. Even when I have the settings as warm as possible and the fridge is in a cold garage.
  • isrb710 Feb 14, 2012
    Do you think the compressor bad or the start relay? Thx, Ron
    Problem Solver:
  • 19 Answers
Your compressor is bad its drawing whats called locked rotor amps you can buy a hard start kit at your local hvac supply house which will be a plug in fix make sure you read the instructions
Posted on Feb 12, 2012
  • Jason S. Jan 08, 2013
    I am having the same problem and would like to look into the 'hard start kit' option but don't know where to look for it. Could you please give a bit more info as to what it is - brand name, model number, or anything else? It would be much appreciated. Thanks, Jason.
Coleman mach rv ac unit tripping breaker
If it trips the circuit breaker as soon as you turn the FAN on, suspect either a bad fan motor or a failed fan motor start capacitor. If you are able to turn the fan on but the circuit breaker trips as soon as the COMPRESSOR starts, it is possible that the compressor is seized.
If, on the other hand, the unit is tripping a GFCI (Ground Fault Circuit Interrupter) breaker or GFCI utility outlet, it is possible that neutral and hot are reversed at the outlet into which the trailer is plugged (happened to me this year at an RV park).
May 14, 2015 | Coleman Heating & Cooling
Hi my my Kic fridge tripping electricity what
There are two things with different answers- \'trip\' normally can apply to either the circuit breaker (~15-20 amperes) or the Ground Fault Interrupter where the latter can be part of a circuit breaker or a wall-mounted AC outlet.
Circuit (overload) breakers prevent fires when appliances (or others) and GFIs prevent death by electrocution.
The first (breakers), can trip when motors and transformers fail, the second (GFIs) trip when a faulty current path is detected that can allow hazardous AC voltages to be present on accessible parts.
Both circuit breakers and GFIs can fail to perform correctly and some training and a multimeter is required to accurately determine the source of the problem.
Sep 19, 2014 | Refrigerators
Simoniz S2000 XE02 internal cct breaker keeps tripping after 30secs tried to get a parts break down but that info is really ****** and nothing on line anywhere. Any idea what causes the cct breaker to...
First be very careful because the unit is protected by a ground fault internal circuit interrupter and may trip if there is a short circuit to ground. Even a very small short circuit will trip the circuit breaker.
Something else: If you are plugging it into an already existing ground fault outlet then that may also cause one of the breakers to trip.
Like I first mentioned, if you don't know what your doing be very careful. Electricity and water are not friends, especially if the circuit breaker is tripping.
Good luck,
Marty
Jun 26, 2014 | Coleman Powermate DuraBuilt 1400 PSI...
Hoover Refrigerator Model B38tf. Causes earth leakage circuit breaker to trip. Has just started to occur in last week. What is likely cause and what rectification can be applied?
If you're referring to a GFCI (Ground Fault Circuit Interrupter) breaker tripping, a refrigerator should not be plugged into a GFCI circuit because of the sudden load it requires to start the compressor, etc when it kicks on. The GFCI breakers are meant to be very sensitive, and over time the sudden energy demands caused by a refrigerator can weaken the breaker's threshold, causing them to trip often. Try connecting the refrigerator to another circuit that isn't on a GFCI breaker. If there are no other circuits nearby, you may wish to replace the GFCI breaker with a standard breaker, and replace the receptacles with GFCI receptacles, except of course, the one the refrigerator is plugged into. Be sure and consult and use a qualified electrician for this. Hope this helps..
Oct 29, 2013 | Refrigerators
Installing arc fault interrupter with ground fault
If you meant arch fault with ground fault then no, the two types interfere with each other and trip the breaker as one senses an arch and the other grounding.
If you meant ground fault breaker with a GFCI. receptacle, you only need one of the two, either GFCI. breaker or receptacle.
and for circuits, you can put up to 12 devices (i.e receptacle, light)assuming they consume 1 amp each. Anything over 12 amps or 80% of the rating on the breaker, it will trip/reset.
Or if your talking about wires on a breaker then no more than 2 wires recommended. Try adding a junction box outside the panel if your trying to add other branch circuits or tap off of a receptacle.
Apr 21, 2013 | Siemens Seimens Arc Fault Breaker
GE Profile 24, 15 years old: Occasionally, it trips the house ground fault circuit interrupter (GFCI). Tripping happens about 5 seconds after plugging to mains. For a week the problem disappeared, now it...
The motor (compressor) is pulling too high amps on the startup ... this tripps the GFCI...
The compressor cap is going bad or the motor is going bad...replace the realy and cap first...
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 28, 2010 | Refrigerators
Amana side by side SB 520S fridge trips ground
the unit has a higher heat load than normal after being off for a time. the compressor draws alot of amps and could easily trip a ground fault cb. The breaker should have a ground wire hooked into the back of the breaker that is connected to the nuetral or ground bar. this wire should be at least 12 guage wire if it is on a 15amp breaker
Dec 20, 2009 | Amana SXD524VW Side by Side Refrigerator
My Amana heat pump model PHD60C02F1 Keeps tripping the circuit breaker
Is this kicking the ground fault on the cord or the breaker. If it trips breaker could be bad breaker. If it trips quickly it is a short in the unit. Russ
Aug 01, 2009 | Amana PTH123B25AJ Heat Pump Air...
15 amp Gould breaker trips every 24 to 48 hours
As seemingly with everything else, these devices were once very reliable but now fail early in life.
Assuming that this is no GFI (Ground Fault Interrupter) equipped breaker, you must  have a bad one. If it is, you may have some stray currents tripping the breaker.
While finishing up on our new home and putting breakers in the main box for the first time, one brand new breaker refused to stay set even though the circuit was OK and no loads on that branch connected at all. In the two years we have been here, we had to replace a second one acting just as you describe.
Dec 15, 2008 | Ace Hardware Hi-Tech Circuit Detective...
Refrigerator tripping ground fault circuit
The thing you were "spinning" was the defrost timer, not a circuit breaker. The problem may be you have a shorted defrost heater; It is on a timer that runs it for 30 minutes every 8 hours of compressor use.
May 31, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
229 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
