Question about Korg D888 8 Track Recorder
Korg d888 power supply voltage
This unit has a switching power supply. Generally this means that it will accept both American and European supply voltages. Can anyone confirm this for me please?
  • 430 Answers
Why cant i connect to my pc anymore
If you have updated your computer OS it may no longer be compatable. Other than that do a herd reset on the Korg and see if that helps.
Sep 22, 2015 | Korg D888 8 Track Recorder
I plug the USB from the D888 to my laptop (Toshiba Satelitte with Windows Vista) and nothing happens. The USB button is turned on.
Not a solution but a question that might get you closer to resolving this. Have you attempted to connect to any other computer with your D-888. Did this work?
Mar 23, 2013 | Korg D888 8 Track Recorder
Moving to Canada Korg M50 - 220V to110V ?
110 will not damage it, just will not work, if built in power supply should say on the rating plate next to power input the voltage it is able to take, a lot of units are rated 110-240v some will have a small switch to change over from 110 to 240. Other than that, you will need to get a step up unit to supply 240 from 110 just a small transformer unit.
Mar 06, 2013 | Korg M50 61-Key Music Workstation Keyboard...
When my Korg d8 power is on 'working' message is followed by Init>?, I cannot go beyond this. How to solve this problem? And can I change the internal Hard drive.
It is asking for confirmation that you want to initialize the unit. The manual doesn't say anything about this... but you should try pressing the "Yes" button to confirm you want to initiallize the unit or press no if you want to staart without initializing.
Aug 15, 2011 | Korg D888 8 Track Recorder
D888 recorder/mixer wont boot up. Screen says "power on failure" initialize" appears that hard drive has failed. though I hear it running
The hard drive has probably failed. In spite of it rotating, the head servo and electronics has to work. I would recommend testing the drive in a computer to see if it works. You will likely have to reformat it after if it does work. FIRST look for obvious things in the D888 like cable that is partially off or loose.
Aug 05, 2011 | Korg D888 8 Track Recorder
Hi, I have a korg D8 recorder and that i use pretty regularly.One day i switched it on and it was completely dead - no lights, nothing. I've tested the power supply (the one it was supplied with ) and...
Most common cause are failed connectors. Power inout jack failures are common. Beyond that, tracing out the power input for a failure would be in order.
Jul 16, 2011 | Korg D888 8 Track Recorder
I have a old (but almost unused) Korg d1200 recorder. Recently started getting disc error messages. Followed manual instructions to check disc drive and still get same results. Powered it up just now to...
First thing would be to check the power supply voltages. It may be the disk drive is failing. Drives are inexpensive, might be worth a try with a new drive. Also check that cables to the drive have not been loosend by handling.
Jun 17, 2011 | Korg D888 8 Track Recorder
Hello everyone, you are my last hope. Here is my story I have a Triton Le bought in Mexico in 2005, it has the American AC/AC power supply cable. I moved to Europe and there I bought a 240V INPUT (9V...
I have been trying to find a schematic, however the damage should be limited in the unit.
Since there is only 9VAC input, we know that it has to go through a rectifier and a filter capacitor and then likely a regulator. I doubt the problem goes beyond the regulator.
The screen light MAY be independent of the logic power in the unit, the LED's will NOT be independent.
The voltage rating of the fuse is NOT a problem.
You likely blew out the rectifiers as a start. They may be individual diodes or a small module with four diodes inside.
The diodes SHOULD have survived but check them with an ohmmeter on the diode range. The Filter cap may be destroyed, and alsothe regulator which is likely a three terminal one like a 7805.
Aug 11, 2010 | Korg Pa800 Synthesizer
Can I plug my American bought triton in European standard electricity Korg 61 key Triton
Only if it has a switch that changes over to 220. I beleave, if not ten you will have to get a power inverter for the power difference and plugs for the different styles that they have over in europe. I hope this helps.
Aug 15, 2009 | Music
Korg D888 8 Track Recorder Logo
186 people viewed this question
Top Korg Music Experts
Vito Vacirca Jr.
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Korg Music Expert? Answer questions, earn points and help others
