Question about Craftsman Garden
Replace drive chain on cox ride on
9005j model
Do i need to replace fuel tank if rubber grommet has come out
cant find a picture of a cox ride on mower fuel tank
should be able to buy a grommet to do the job
mower repair shop first stop
Nov 05, 2016 | Garden
Rubber grommet in cox ride can it be repaired
rubber grommet on a cox ride on mower
should be able to buy a new replacement grommet
need to know the model
Nov 05, 2016 | Cars & Trucks
Chain diagram
sorry but no lawn mower I have ever worked on has chain drive .when asking questions we need make , model , year if known , horsepower ,if known .
Oct 03, 2015 | Garden
Change an upper v belt on cox jackaroo ride on
Not to find any online IPL that I can access from here in the USA so I have no idea of how the drive belt is routed.
If it has an electric PTO clutch then you need to remove it so you can drop the engine pulley down to get belt off and on as the upper belt retainers will prevent you doing so if not done. If just a double stack pulley you will probably still need remove the retaining bolt so you drop the pulley as above.
Nov 15, 2014 | Garden
Removing clutch cone from cox stockman ride on mower
Old question, but maybe this will help others:
Here is the answer for all Cox Stockman machines fitted with a single large bolt through clutch cone. Below it you'll find a VERY GOOD REASON WHY YOU SHOULD NOT DO IT!!!
1. Disconnect the negative (-) lead from the battery.
2. Loosen the four bolts that secure the engine and slide engine backwards.
3. Remove the 'R Clip' on the link rod at the front of the clutch carrier, then disconnect the link rod.
4. Loosen all four grub screws on the drive plates and slide them as far out as you can.
5. Raise the rear of the machine and secure with axle stands or some other method that will leave you with a SAFE WORKPLACE!
6. Remove the 9/16" locknut on the clutch pivot bolt (under the rear of the machine), then unscrew the pivot bolt. Do not try to drive it out with a punch, as it is screwed into the adjusting plate.
7. When bolt is removed, slide the rear of the carrier across to one side and the front of the carrier to the other side ( to clear the bracket at the front of the carrier) and work the whole assembly forward enough to clear the rear chassis rail. Then drop it down and remove the assembly from the machine.
To replace the cone, lock the large bolt head into a vice, then use a 2 or three pronged lock bar to unscrew the pulley from the bottom of the bolt. Then, fit a new cone onto the bolt and reverse teh entire process.
Now, here's why you should NOT DO THIS AT HOME!!!!!!!!!!!!!!!!!!!!!!!
If you don't read this part, I absolutely guarantee that it will end up costing you far more money than if you'd sent the machine to a Cox Service agent ( I am one).
About the only thing on any Cox machine that requires specialist knowledge and tooling to correctly repair, is the drive cone clutch system. Removing and replacing the drive cone itself is the easiest part of the process and I have seen it done by plenty of people. I've also spent plenty of time then fitting another new cone to their machine, because the one they put on is now stuffed. The drive cone is just one part of an assembly and if the entire job is not done correctly the FIRST TIME, the new cone can be destroyed in a very short time. And the only way to do the entire job correctly is to have the special tools and knowledge. No if's, no but's and no maybe's!
Oct 21, 2014 | Garden
Why would my cox lawn boss stop driving forward and back when I engage the mower deck
Sounds like a drive lockout switch. Check under seat or dash. EBrake? Good Luck
Oct 18, 2014 | Garden
I have a Poulan 295. I needed to replace the chain. It is a 20" chain. There is bar oil in the resevoir. The chain will not stay on the bar (it seems loose even when fully tightened). I replaced...
If you replaced the bar AND the chain, you'll need to make sure the chain is the correct chain for the particular bar you've used. If you're only replacing the chain, you need to make sure the chain has the same # of drive links as your old chain (maybe one or two more, if you've had some removed because of chain stretch).
On that particular model, for a 20" chain, you could have a 78 OR 80 drive link chain (drive links being the part of the chain that rides in the groove of the bar). The correct drive link count is determined by the bar you've installed and should have been made clear by whoever you purchased the bar from. Some brands use an 80 drive link chain, but MOST use the 78 drive link chain.
If the bar you purchased uses the 78 drive link chain, but you have an 80 drive link chain, then no matter how far out you adjust the bar, you may not get the chain tight enough. PartsBuggy shows a listing of which bars use the 78 drive link chains here.
Aug 29, 2011 | Poulan Pro Chain Saw 46cc 20"
I have a victa corvette cox made ride on mower
Being cox made I'd go looking for cox manuals for the same era. Victa just rebadged others mowers.
Nov 18, 2009 | Garden
Replace motion drive belt garden tractor craftman 917273080
On what make and model riding mower ..
Jan 19, 2009 | Garden
Garden Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
