Question about Kodak EasyShare M1093 IS Digital Camera
What is dpi on Kodak EasyShare M1093IS
Need 300dpi images for art exhibit application.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
The DPI (dots per inch) number only has meaning when printing the picture. It's meaningless to a camera.
The M1093IS takes photos that are 3672 x 2748 pixels at its best resolution. If you make a 4x6 print of one, you'll be getting more than 600dpi. If you make a 8x10 print of the same picture, you'll only be getting about 300dpi. Yet they're made from the same image file.
If you must change the image file itself, open it in just about any photo editor, change the DPI field, then save the file. Make sure you do this to a copy, not the original.
Posted on Feb 13, 2012
5 Suggested Answers
  • 75 Answers
SOURCE: Kodak EasyShare DX6340 running error
Completely uninstall EasyShare and download the newest version from the Kodak website.
Posted on Jun 05, 2008
leepania
  • 1099 Answers
SOURCE: my easyshare model m1093is comes on then goes off
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 13, 2009
duane_wong
  • 6826 Answers
SOURCE: my kodak easyshare m1093is turns itself off when i turn it on.
OK, try getting the LiIon batteries recommended for it if you haven't done so already. Charge the battery pack and install in the camera.
If the correct batteries are not used, the camera will function in this way. i.e. if you use alkaline, NiMH, or other types of AA batteries in this camera, the battery voltage is not compatible with your Kodak camera.
The whole line of Kodak Easyshare cameras is this way.
Hope this helps.
Posted on Jul 13, 2010
  • 102366 Answers
SOURCE: kodak easyshare Z740 compatible with mac? Since
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Posted on May 07, 2011
Can I use a 2gb PNY memory card in my Kodak EasyShare #M1093IS
Yes, you may use the PNY 2GB SD card, or any SD or SDHC card in your camera.
May 16, 2012 | Kodak EasyShare Z730 Digital Camera
How do I change the dpi of this camera?
The digital cameras capture images with number of pixels that that image sensor allows. They usually dont have DPI adjustment. However you can adjust capture resolution from 5 Mega Pixel to 1.1 Mega Pixel. Please refer to Page 24 and 25 on the following Owners Manual for this camera.
Feb 24, 2011 | Kodak EasyShare C315 Digital Camera
My kodak easyshare m1093is turns itself off when i turn it on.
Hope this helps.
Jul 13, 2010 | Kodak EasyShare M1093 IS Digital Camera
What is greatest dpi for PowerShot SX100IS?
Yes your camera will give images with 300dpi . You need to set the dimension as 3264 x 2448.
Hope this helps.
Jan 30, 2010 | Canon Cameras
They keep telling me that my picture is too big . It is a 4X6 picture on my computer.
More information on exactly what you are trying to do would be helpful... But it sounds like it's a resolution problem. Computer monitors usually display 72 or 96 dpi (Dots Per Inch) Printers usually print out images at 300 or 600 dpi Some newspapers are printed at only 50 dpi Scanners can scan a photo in thousands of dpi...
If your photo is a 4x6 at 300dpi, then when they try to display it in 72dpi, it will display as just a bit larger than a 16x20" image
When you are scanning a photo to email, then make sure that you set your resolution to 72 dpi to display on the screen - or vice versa, if you are going to print something, make sure you scan it at 300dpi
If you have any graphic programs, (Microsoft offers "PowerToys" for Windows XP) you can open the file in that, and usually find a setting for the Image Size that will let you set a new DPI. It's usually ok to lower an image's dpi - but there is a loss of quality anytime you try to add dpi, since you are forcing the computer to "guess" what all those hundreds of dots should look like, and they aren't good at that.
Oct 29, 2009 | Cameras
How do I take a picture at 300dpi
The DPI are not a user allowed settings. Normally DPIs are factory defined.
You can change the DPI using software. Normally the image administration software and advanced softwares can allow you to change it.
Remember an important issue: DPIs are a printing matter not an image quality matter. Yo can set an image to 300 DPI and the same to 72 DPI and you will see no difference between both images.
A good camera and your skills will allow you to take high quality images.
Jul 13, 2009 | Canon PowerShot A630 Digital Camera
I need 96 dpi but I don't know what resolution settings to use to get that
It sounds like you need 96 dpi for some sort of graphics application? This really has nothing to do with viewing on your monitor though. DPI has more to do with how the image, pixel per pixel, is spaced during printing.
For instance... if you have an image that is 960x960.. at 96dpi you could print a 10 inch square image (wouldn't look that great at 10 inches however).
However printers ALSO manipulate the dpi. So for large images, you might need to give the printer an image that has 196dpi.
In summary, it really depends on the application. Thermal printers normally prefer 300dpi, large format printers like 196dpi (or there abouts), and our normal home inkjet will accept any dpi but you will notice if you give it 196dpi, you will get a better image when printing larger images.
Jul 11, 2009 | Acer 20 Widescreen LCD Monitor B203W bdmr
Creating a 300 dpi x 300 dpi file
You need to be able to change the DPI setting in the image file. This can be done in most complete photo editors, though they tend to name the procedure in different ways. In Corel Photo-Paint, you would look for "Resample Image". In the open source photo editor Gimp, look for "Scale" under "Image".
In all such procedures, what you want is to set both the vertical and horizontal DPI values to 300, apply them, then save the image. Please do save it to a different filename, since you lose some quality of JPEG images every time they are saved.
Sep 18, 2008 | Canon Rebel XT / EOS 350D Digital Camera
300 dpi
Shooting pictures in Fine quality will give you atleast 300 DPI resolution. Check your camera setup menu to see what quality you're shooting in, and adjust as necessary.
If you need to print 300dpi, this is done in whatever program you're using to output. In Photoshop, this is done by going to image>image size and changing Resolution to 300 (or whatever other resolution you want)
Apr 08, 2008 | Nikon D40x Digital Camera
Resolution
The short answer is you cannot! I believe the resolution of your camera is 1600 x 1200 pixels; if you print this out @ 300dpi. you will get a print size of 5.3 x 4 inches. if you print at 72 dpi the print size will be 22 x16 ins. The 72 ppi that is recorded with your exif data is meaningless.
Sep 12, 2005 | Olympus Camedia C-2040 Zoom Digital Camera
Kodak EasyShare M1093 IS Digital Camera Logo
71 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
