Question about Hardware & Accessories
Westek TE02 1 outlet digital manual - Hardware & Accessories
2 Suggested Answers
SOURCE: How to set timer. Westek TE06WHB 2 Outlet Digital
1) Westek TE06WHB is sold at Target in back of store near extension cords.
Lowes also sells identical timer under different brand and model number
You can buy a timer, and cut open side of package and slide out the instructions.
Scan instructions into your computer and then take timer and instructions back for refund.
2) Also open following link to identify timer for sure and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Two different manuals show for product:
http://waterheatertimer.org/pdf/Woods-59377.pdf
http://waterheatertimer.org/pdf/Westek-TE06WHB-manual.pdf
3) Since there is not enough space allowed in free answer to copy-paste entire manual, if you have difficulties, then add a comment with specific issue and I will answer if possible.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 12, 2011
I was wondering if the dual outlets can be program individually? For example, both start a 6am but one end at 8pm and the other one at 10pm. Thanks
No. Woods does not make 2-channel timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#digital
Nor is this feature available through Intermatic wall timers, GE wall timers, Leviton, Swilight, UPM, Tork, Westinghouse, Westek, Utilitec, maplin, Stanley, Brinks, Timex, Kichler, Hagar, First Alert, sylvania, Aube, Honeywell, coleman, HPM, etc etc.
However, you can buy narrow timers like Westek TE22, also similar sold by Brinks... and 2 different timers can plug into same duplex outlet... letting you control 2 different loads from same outlet... by using two timers: usually this type timer is sold as 2-pack
http://waterheatertimer.org/Woods-timers-and-manuals.html#Westek
There are also box timers, like Intermatic ET series, that can be programmed for 2-channel operation where same timer controls two different loads, each with different weekly or daily schedule ... Intermatic PE153 offers 3-chanels, and there is one timer, ET90000 that can be programmed for 40+ channels with 4000 set points and 365 day calendar for each channel etc
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
Tork also offers multi-channel box timers.
Gene.
Aug 04, 2013 | Woods Hardware & Accessories
I HAVE 2 PROBLEMS, I CAN NOT SET MY WESTEK TIMER SO IT COMES ON AND OFF THE SAME TIME EACH DAY, ALSO MY SON PUSH THE RESET BUTTON WITH A PIN, NOW IT IS STUCK IN THE DEFAULT SETTING, HOW DO I FIX THIS
Good boy. Resetting timer is always first step for restoring functionality of timer. Try resetting again. This will clear conflicts in programming, or stray code in memeory from factory testing etc.
1) Copy following link to download possible manual for Westek timer: Read manual very carefully.
2) Add comment and describe timer buttons in detail, so timer can be identified by expert.
3) Buy another Intermatic, GE, or Woods timer at local box store: Advantage of good timer from local store: defects can be replaced easily by buying another timer and returning defect in new package.
4) Don't buy westek, first alert, westinghouse, stanley, brinks, timex, and other off-brands from ebay, local drug-thrift-dollar stores, etc that do not have specific warranty protocol and hard-to-find or non-existent manuals.
Dec 22, 2012 | RTO Westek Weekly Digital Timer, White
I have a Westek Timer Model No. TM16DOLBB and the wheel that turns the timer on will not turn to turn the light on and off. If I take it down and work for several minutes, I can turn it by hand. It
Test outlet with circuit analyzer for correct polarity and grounding.
Plug timer into different outlet.
This type timer must be installed in gfci-protected outdoor outlet.
Do not exceed timer load rating.
All timers are susceptible to surge.
Buy another timer from Home Depot, and return defect in new package.
That's the advantage of buying at local store instead of internet purchase, because you can get longer-term warranty.
Almost all timers have 1 year limited warranty for workmanship defects, including very expensive commercial timers, except for the Intermatic digital plug-in timers DT620 and HB800 that have limited lifetime warranty against defects in workmanship.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#digital
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Sep 05, 2012 | Hardware & Accessories
Westek TE06WHB Timer has been plugged in to charge for over 5 hours now and still now LCD display. It won't let me set the clock or program
Some of these timers use actual battery instead of rechargeable battery. Check back of timer for a battery door.
Press the reset button and see if this resolves the issue.
Check outlet polarity using circuit analyzer.
Plug timer into another outlet.
Turn on light switch controlling outlet.
See if a light works on same outlet.
Check circuit breaker.
This timer has 1 year warranty against defects in workmanship.
I suggest always buying timers at local store for ease of possible return.
Lowes and Target sell same/similar timer under different brand name. Buy new timer and return defect in new package.
Sep 05, 2012 | RTO Westek Weekly Digital Timer, White
I have a Westek indoor digital timer, i have a nano tank with 2 lights (moonlight, daylight). I"ve tried setting the timer for 7 days with each light on at different times, it just won't work.Though...
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
http://waterheatertimer.org/Woods-timers-and-manuals.html#TE05W
You want to control each light with different programming?
Westek TE05 timer is single-channel timer, so different lights cannot be controlled by different programs.
You need a two-channel timer so each light can come on at different times.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Zilla timers are two-channel timers: yellow outlets for daytime, and blue outlets for nighttime.
Mar 28, 2011 | RTO Amertac TEO5W Decorative Indoor Weekly...
How to set timer. Westek TE06WHB 2 Outlet Digital Timer
Feb 11, 2011 | Woods Industries 59377 Indoor Digital...
I need the instructions for the Westek digital timer 1 3 prong outlet (TE55WHB) so I can program it. Thanks
I saw similar Westec timer at Target yesterday. Sears is supposed to sell Westec too. Buy timer and copy instructions.
Westec shows some manuals, but doesn't show TE55 product or manual for TE55
Other site reported problems with the TE55
http://www.amertac.com/content/home.nsf/Subjects/LIghting+Controls+Frameset/
I found manual for TE05, which might be similar
http://waterheatertimer.org/pdf/TE05WHBL-WTBL-INSTRUCTION.pdf
Nov 24, 2010 | Hardware & Accessories
Hardware & Accessories Logo
2,842 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
