Question about Linksys WRT300N Wireless Router
Slow wireless connection
Lan connection speed fine, wireless slow
  • 550 Answers
I think you can try to upgrade the firmware on the router.
Connect one compute to the router and download the firmware of the router.
Open the setup page and upgrade the firmware.
See How to upgrade firmware on the router
After upgrading the firmware reset the router and reconfigure it manually.
See if that helps you.
Watch video: How to reset linksys router
Posted on Feb 13, 2012
3 Suggested Answers
  • 17 Answers
SOURCE: LInksys WRK54g-wireless connection works fine, but cannot get LAN
You might have faulty LAN ports on your router or your network cable is bad.
Posted on Jan 24, 2010
  • 89 Answers
SOURCE: limited connectivity, had my isp
Please open the router setup page with the address 192.168.1.1 which is default ipadress
>This will ask you for the username and password.
Leave the username blank and in the password type admin which is default .
>Open the router settings page and go the wireless settings Tab.
>Under the basic wireless settings Change the wireless channel to 6 which is best compatible channel.
>click on the save settings and exit out of that page.
>Restart the router after.
Regards:-
Amit Awasthi
Posted on Dec 08, 2010
Why is my computer so slow to connect to internet web sites
I would try to connect using a wired connection instead of a wireless connection to see if the speed increases. Also go to Speakeasy Speed Test and run a test to see what speed your internet is really running at.
Sep 24, 2014 | Acer Aspire Desktop Computer - Intel Core...
I have an issue with Wireless Access Point D-Link DAP 1155 When i'm connected to the internet via WiFi by mobile device (different ones Galaxy Note 1, Galaxy Note 2, Galaxy ACE) when browsing internet is...
Do other wireless laptops connect to your wireless router, and give good speeds? Do you have many wireless networks, other than your own, that show up when you try to connect? It could be interference from other wireless networks in your vicinity.
Aug 21, 2013 | D-Link Computers & Internet
What's your problem?Lan problem
Your internet is very slow because it is connected to many systems using a low speed plan.Due to heavy load your lan may be very slow. So it is better you choose a higher internet plan according to the number of systems connected and then check your speed at Scanmyspeed.com .. Contact your ISP for plan details
Nov 27, 2011 | Gigabyte GAH67MAUSB3B3 Motherboard Intel...
My down load is very slow
Hi,just check your speed from here http://www.scanmyspeed.com/ and if still your speed continues to be slow contact your provider.
Mar 08, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Hi I have a belkin F5D8233-4v3 router but the speed isn't what it should be. I have a 100/10 Mbit connection but when I have my computer connected through the router with a cable all the speed tests I try...
The speed of the wireless connection can be affected by -
1. The signal strength
2. Clashes with other wireless routers in your area broadcasting on the same channel
3. Electrical interference with the wireless signal
4. WEP & WPA Encryption of the wireless signal to prevent unauthorized access does slow the data transfer a bit.
That is why you are getting better performance using the LAN cable.
Jun 09, 2010 | Computers & Internet
Linksys WRT54G connects but is homicidally slow, and won't renew DHCP if signal falters!
Linksys wireless firmware is know for it slow connection issue. I have one and my lan speed was double then my wireless speed. I put the third pary firmware from www.dd-wrt.com website and now my wireless and lan speeds are the same.
Nov 12, 2009 | Linksys Wireless-G WRT54G Router
Ethernet works wirelss is very slow
Most of the wireless adapters connect at a speed of 54mbps max, while wired lan connection adaptors (LAN adapter/cable) works at max of 100/1000mbps. hence use a cable to connect the PC to make it faster than using wireless.
Aug 17, 2009 | 2wire 1800HG Router (RG1800HG00)
Upload Speeds Slow, Ping High
s it is ur problem of ur LAN card..check the speed of ur LAN card..
Aug 16, 2009 | Acer 91.AB370.001 Network Adapter
Wireless computers work fine, wired desktop extremely slow
On your old desktop, go to Control Panel > Internet Options > Connections > LAN Settings make sure no check on boxes there. Click OK and Apply. Click on General tab, click on Delete File (delete all offline content), Clear History and Delete Cookies. Click Apply and OK.
Jun 29, 2009 | Linksys Wireless-G WRT54G Router
Wireless LAN low speed
Try plugging the computer directly on your modem/router then check your speed. If the speed improves then big possibility that it's the wireless adapter. Try uninstalling then installing it again. If the speed did not change even though you directly plugged it then it means that your computer has a problem. You may need to optimize your IE or disable any firewall or any programs that uses the internet.
Mar 29, 2008 | Computers & Internet
Linksys WRT300N Wireless Router Logo
214 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
