Question about IBM ThinkVision L170 17" LCD Monitor
Laptop doesn't see the monitor i attach to it
Trying to get 2nd monitor (IBM thinkvision 17" flat) hooked up to my laptop, i hook it up but my pc doesn't see it's even there. can't extend desktop onto monitor....
  • 108 Answers
1st off there is a Fn key, I think Fn + F5? to turn the monitor on. It is a toggle button that toggles between only the monitor or monitor and Laptop screen both or just the laptop screen.
I hope that can help, if not, please tell me what you have tried. As in, does the monitor work on another PC/Laptop?
G'luck
Posted on Oct 24, 2008
Monitorwont come on
When i turn on my IBM ThinkPad laptop the battery and power light is on green but the monitor remains black.
Jan 20, 2013 | IBM ThinkVision L170 17" LCD Monitor
It doesn't show the image from computer, the screen still black but the power light appears on.
Connect another monitor to the PC and confirm that the PC is working , specially the display drivers/card. If so the fault is only with the monitor and it can be related to power supply issue, a backlight inverter circuit shorting or a fault in the main board., all of this mightt require a good probe with the use of manual. So please check this out and confirm if the fault is with the monitor or the PC.
Oct 18, 2011 | IBM ThinkVision L170p 17" LCD Monitor
I have a type 6734-LB1 17" Lenovo ThinkVision
where will i get to install the software/drivers of IBM 6734-L-B-1 for listening Music
Sep 30, 2011 | IBM L170M (Black) 17 in. Flat Panel LCD...
Ibm thinkvision monitor problem
I would try it with other PC, if it is still doing the same thing and you want to DIY repair, then please read below.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 14, 2010 | IBM ThinkVision L170 17" LCD Monitor
LCD flat panel monitor blinks logo over and over
Sounds like the LCD monitor is not getting a proper input signal. Check your cables between the computer and monitor. Replace them if need. Also check the pins and make sure that none are bent or disfigured.
Try a replacment monitor from a family member or friend. If their monitor works ok.....then your due for a replacment. The are very little user servicable parts inside.
Jan 23, 2009 | IBM ThinkVision L170 17" LCD Monitor
17 inch IBM Thinkvision
Well... a good way to tested the caps is to used a Blue ESR meter.
Oct 04, 2008 | IBM ThinkVision L170 17" LCD Monitor
Ibm thinkvision l170 monitor
Hi! Tammy,
It's seems your new pc resolution settings, set to high...
Hook up to another monitor and go to settings to correct your
resolution to 1280x768 or less. That will fixed your problems.
Good lucks!
Aug 07, 2008 | IBM ThinkVision L170 17" LCD Monitor
Ibm 15" thinkvision lcd monitor
The entire Thinkvision series of monitors have been plagued by capacitors on the power supply board failing.
This sounds worse then it is. For the most part they only fail well after their warranty period, so it's not a design flaw, just old age.
The repair should not cost alot and would be worth a trip to your local computer/TV repair man.
Hope that helps =)
Apr 06, 2008 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L170 17" LCD Monitor Logo
112 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
