Question about Roper FGP300 Gas Kitchen Range
Roper gas range. Oven glow coil comes on but has no gas to heat?
My Roper Gas Range Model # FGP33560 Serial # RH 3310535 has a glow coil in the oven. The glow coil comes on but it is not heating. Is it the ignighter or the gas valve?
    Problem Solver:
  • 19 Answers
If the glow igniter is on and it doesnt light its probably the gas valve
Posted on Feb 12, 2012
Range won't heat up
it is a glow coil , thermocouples are on units with a free standing pilot that you have to light, if you have a range like this you may need a thermocouple if not a free standing pilot you have a electronic gas iginition system that uses a glow coil, you turn on over setting and oven glows orange then iginites if this is what you have you need new glow coil, easy to repalce
Feb 03, 2010 | Magic Chef 9122 Gas Single Oven
Oven does not heat but broiler does
First thing to suspect would be a weak igniter....see if the amp draw while the igniter is glowing matches the amp rating of the gas valve, the value will be on the side of the valve, if the amp draw of the igniter is lower than the rating of the valve you would need to replace the glow coil/igniter.
Mar 22, 2008 | Bosch HGS 255 Gas Kitchen Range
GE Gas Range/oven Model JGBS16 The glow coil in the oven works intermittently. When it doesn't come on we find that turning the control knob on and off several time will help or if we start one of the...
could be a bad thermostat but it sounds most likely like a loose wire connection somewhere. if the coil comes on and doesnt quite glow as bright as it should, the glow coil needs replacing.
Oct 10, 2009 | GE JGBS17 Gas Kitchen Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire gas range oven won't come on
the oven ignitor needs replacing, this is the part that makes everything works, it's a glow coil in side the oven, nest to the burner, that is the electronic pilot, when it goes bad the safety valve, the one that sends gas to the oven will not open to light the oven burner.
Dec 07, 2008 | Kitchen Ranges
The oven doesn't work ,the ignator doesn't light up. no gas coming
The technical jargon is,.....:
In order for your gas oven to work this is what has to happen: 1. when you turn on the oven, the range sends 120 volts to the glow bar igniter. 2. as the igniter heats up (and starts to glow) it starts using more electricity. 3. when the electric use reaches a set amount (say 3.2 amps) the range knows the glow bar igniter is hot enough to ignite the gas, so it then releases gas through the gas safety valve. 4. when the thermostat tells the oven controller that the temperature has been reached, the control cuts power to the igniter, cutting the amp draw down, causing the safety gas valve to close. 5. process repeats to hold oven temp until you turn off oven.
So,..........the solution is:
most likely your oven igniter burnt out. Find your model number, usually on the range frame just behind the lower drawer or broiler drawer (depending on if it is a self clean gas range or not) and order the correct igniter and replace it.
Nov 02, 2008 | Kitchen Ranges
Kenmore gas (propane) range Model #119.7488810 18-20 years old
you have a bad oven/bake ignitor, althoough you see ther glow, its not "hot" enough to allow gas flow or ignition, very common issue, 2 screws and 2 wires, probably about $75, service company gets min $225..
Oct 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven won't heat
try replacing the oven igniter/ glow bar the thing you see light up it sounds like it is weak you can tell if it glows with a white color in the bar it should glow a bright orange color
Aug 28, 2007 | Tappan TGFS_63 Gas Kitchen Range
Roper FGP300 Gas Kitchen Range Logo
173 people viewed this question
Top Roper Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Thurston
 Fix Your Board
Fix Your Board
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
