Question about Music
Where is the fuse on a Peavey Encore 65?
My 6L6 tubes gave out and the fuse blew. I don`t see where the fuse is.
Blowing the main fuse.on my peavey 212 renown.can someone help me out.hate to scrape the thing.
This is a vacuum tube driven amp. First thing to do is remove all the tubes and see if the fuse burns out. If it does not then a tube is bad. Process of elimination to figure out what tube it is.
Jun 13, 2016 | Peavey Music
Why wont the tubes in peavey amp not warm up
This is not user servicable. Here is a link to the service locator for peavey-
Peavey com
Jun 24, 2015 | Peavey Music
I have 2 peavey sp2 bx well I was pushing them really hard and blew the black widows. Now I have got a replacement and hooked it up and still no sound out of them. I do have the horns working but they...
The lamp bulb fusing is just on the horns. Check the Black Widows individually with an ohm meter for continuity. If the speakers themselves test OK, you most likely blew the crossovers. Peavey service (877-732-8391) can rebuild most of therir crossovers in house and they generally are cheaper to fix than replace.
Nov 02, 2014 | Music
Power want come on
sound like you shorted a cathode on a tube..take it to the SHOP!!!!
Feb 23, 2014 | Peavey Triple XXX II Guitar Amplifier...
My Peavey Envoy 110 won't turn on
Most likely a blown fuse, but the real issuse would be why is blew the fuse. If you replace it and it quickly blows again, take it to a repair shop.
Jan 31, 2014 | Peavey Envoy 110 Amp Combo
One side of my peavey xr86000 power mixer blew a fusework
Any unit that blows fuses needs to be serviced. Do not keep putting in fuses only for them to be blown again. Each time you put in a fuse and it blows, it will create more damage to the amplifier.
Jan 14, 2013 | Peavey XR 8600D Class D Powered Mixer
I have a peavey valvenmaster head that was playing at very low volumes even when cranked up pretty loudly. i replaced all of the tubes with new matched groove tubes and the volume and tone improved. ...
You start by downloading the schematic here:
http://elektrotanya.com/peavey_valveking_100_212.pdf/download.html
Scroll down to the link "Get Manual" and download the schematic. Note that it has several pages of parts list preceeding the schematic.
Next, put a 150 Watt incandescent bulb in series with the power cord to act as a current limiting fuse. Now replace the fuse and proceed with testing. You may find that one or more filter caps have shorted. Also pay particular attention the the BIAS power supply. You should see about -35 to -40 volts. Note that the series lamp will come on if excess current is being drawn and voltages will be low if the lamp lights. If the BIAS supply has failed, it is possible your power tubes have been damaged.
Mar 31, 2011 | Peavey ValveKing 100w All Tube 212 Combo...
What kind of fuse does a Peavey PR12N sound reenforcement(PA) speaker take? Blew the internal fuse and cany find one(locally) Looks very similar to a cars interior ''dome'' light bulb
According to the Peaver PR12N Manual which can be viewed at http://www.peavey.com/assets/literature/manuals/pr12p.pdf
This unit requires a ABC Type Fast Blow 5 Amp fuse. The replacement fuse must be of the correct type to properly protect the unit. If the fuse continues to blow repeatedly the unit should be taken to a qualified service center for proper repair.
Aug 22, 2009 | Music
Music Logo
52 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
