Here ya go.. Took me a minute. Its located at Funai who now own Magnavox
The link is safe and if your computer can open pdf files just click link and the 48 page manual will open..
Changing from 3 to 4 wire hookup on a electric dryer: Power cord help for 3 & 4 prong dryer cords This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business. This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
On the back, there are three ports that are color-coded and match the cables. Take the yellow cable and plug it into the yellow port. Do the same with the red and white. Take the other end of the cables and plug them into your TV or VCR. Most TVs and VCRs have ports for the cables on either the back or front, and are also color-coded. Plug the yellow cable into the yellow plug on your TV/VCR, and repeat for the red and white cables.
In general, you want to run red, yellow, white (composite or a/v) cables from the out of your sat box to the in of the Magnavox. Then run a 2nd set of r,y,w cables from the out of the Magnavox to the in of the TV (there may be one or several places to plug it into TV). If your sat box is an HD sat box, you probably won't get it to work with this Magnavox. This unit was jointly manufactured with Funai corp, so you will have to call 1-800-605-8610 for tech support.
honey and guest: connections: Red, white, and yellow composite from out of cable/sat box to in of this dvd, and then a 2nd red , white and yellow cable from out of this player to in on television. Every television calls the correct channel something different - make note of where you plug the r,y,w cables to TV -- it may be labelled video1, video 2, av1, av2, input1, ext 1, etc. Turn tv to correct input/av/source/video channel. Call 1-800-605-8610 for further assistance.
and how is dfghdhdfhdfhd supposed to help?
