Question about Acer Aspire 5100 Notebook
Acer aspire 4720z
My acer aspire 4720z i just bought it a month ago suddenly problem imerge it responds so slow it take 10min to open the start menu what should be the solution on this plss help...
  • 57 Answers
Try to clean up your system remove the program causing the system slow then defrag your system  after you defrag  scan if there is a virus,.. virus also causing  the system to make slow if there is virus try to clean it ..and if the virus unremovable format is the best solution ....... remember backup your files before you this......
Posted on Oct 24, 2008
  • 35 Answers
There are multiple problems that could be causing this. The most likely problem is spyware or a virus has infected your system. First off, you didn't mention your OS, but apparently it was shipped with Vista, so I'm going under the assumption that that is what you're running.
First thing to do is try this:
1) Open the start menu.
2) In the place where you can type, type "msconfig" without the quotes and press enter.
3) In the box that opens up (System Configuration) click on the "Startup" tab.
4) In startup UNCHECK EVERYTHING then press "OK"
5) Restart your computer.
If the system starts back up and starts responding much better, chances are something that was loading up in your startup menu was causing the issue (most likely spyware) in which case download, install and run both of these:
Ad-Aware: http://www.lavasoft.com/single/trialpay.php (You can choose "free" version)
Spybot Search and Destroy: http://www.safer-networking.org/en/download/ (100% Free)
If you're still having problems, you can try doing a "System Restore" by doing this:
(Warning, this will revert your system back to an earlier date, so make sure you have backups of the software you've installed since the computer started having problems)
1) Click "start" and type "System Restore" (without the quotes) and press enter.
2) On the window that comes up choose "Choose a different restore point" and click Next.
3) Make sure you put a checkmark in "Show restore points older then 5 days" and look for one from before your problem started happening. Then press next.
4) Just press finish. It should restart your computer and start doing the system restore. If it doesn't restart your computer.
After the restore is finished, check to see, is everything working fine? If it is, SUPER, if not you'll have to go a little more extreme.
If the system is still problematic, you'll have to do a full system recovery. Back up ALL the data you have on your system that you don't want to lose (documents, pictures, mp3's, bookmarks) first before performing this task as it will wipe your hard drive and everything on it.
When you turn on the computer you want to get into your system recovery. It's usually either F10 or F11 (Consult your documentation if that's not it) just follow the prompts until the system is restored.
If THAT doesn't work, you've got a hard drive that is about to fail, or ram that has failed in your system and you'll have to bring it in for warranty issues.
HOPE THIS HELPS!
I have acer aspire 4736 model laptop bought 2
You can perform a recovery on the computer.
Press Alt+F10 as soon as the computer restarts, choose Full system recovery and follow the onscreen instruction.
Note: By perfroming FSR you will loose all the datas on the computer.
Mar 12, 2010 | Acer Aspire 4730-4947 Notebook
Sir i am using acer aspire 4720z. i am not able
Most likely your drive needs to be replaced. In most cases that means hardware problem related to the laser. But there is a chance that one trick will help you. If you are running Windows XP click Start --> Control Panel --> Administrative Tools -->Services --> IMAPI CD BURNING COM SERVICE -->right click (on IMAPI), select properties --> Start up type drop down menu, select disabled --> click APPLY at the bottom. Reboot. Try to burn your disk.
Sep 05, 2009 | Acer Computers & Internet
Adding memory to Acer Aspire 4720z
The RAM memory slot is up on battery .
First open cover above battery plate then fix RAM there .
Jul 13, 2009 | Acer Aspire 4720 Notebook
What can I do to speed up my ACER Aspire 4720Z
Disk defragging maybe not enough. The problem can be caused by various hidden Windows errors. They firstly cause your Acer slow, and then freeze up occasionally. One day crash all of a sudden! To quickly handle the issues, it is recommended to use an Acer speed up software to scan your Aspire. See how to from: http://www.speedupacer.com/
Mar 29, 2009 | Acer Aspire 4720 Notebook
Acer aspire 1 netbook won,t boot up.
Hi
When you first turn the machine on hit F2, that will take you into the bios menu, i don't know what version your machine is using, but the information is usually on the first page, you should find it easy enough because it will be next to the CD/DVD drive.
Feb 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computer hardware
ashu, not familiar with the 4720z model and I couldnt find it on the manual downloads section of the website.
Have you tryed pressing F11 as this brings up the boot menu on my Aspire and allows you to select the device you wish to boot from.
Failing that i have found this site on google which will sell you a replacement manual.
http://www.user-guides.co.uk/asp/product.asp?product=52837&ph=search&Keywords=Acer%20Aspire%204720Z%20%20-%20User%20Guide%20Owners%20Instruction%20Manual%20PDF%20Danish
Let me know if you need any further help.
Regards
Nick
Oct 25, 2008 | Computers & Internet
Problem with webcam..acer aspire 4720
i have acer aspire 4715z madel notebook.i instal vista but it didn't acept drive (wifi did not detect).so ppease send vista drive particularely wifi drive.
subahar22@gmail.com
Jun 07, 2008 | Acer Aspire 4720 Notebook
START MENU AND KEYBOARD PROBLEMS ACER 5610z
Check to see if this happens when booting into safe mode.
Jun 05, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5100 Notebook Logo
727 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
