Question about Samsung SGH-D600 Cellular Phone
Phone switches on but blank screen
Changed screen ribbon as broke other when changing phone housing. New ribbon now in, turns on and makes turning on tune but screen is blank?
    Brigadier General:
  • 7,752 Answers
You need to take the phone to a mobile service center and have them replaced it for you.
Posted on Oct 26, 2008
T715 screen keeps goin blank
hi :) T715 should aslide phone right?? the scren will blank,cause phone ribbon was spoil. pls send to mobile shop to change a new ribbon to solve your pro. Good Luck.
Jul 06, 2010 | Sony Ericsson T715 Cell Phone
Turns on (fans spinning, HD clicking), blank screen, no sounds
hi this issue is with ribbon cable it is connect between the mother board and your LCD screen. the cable required change. if you can change it OK other wise take it to nearest service center.
Jun 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have changed the flex ribbon on my n80, but now when i turn it on the buttons light up but the screen is blank
dear,
you changed due to this kind of problem?? is it...
if yes, then properly plug the strip/ribbon properly and if it is properly connected then you have to check the ribbon itself because sometimes it doesnt work....as i experienced.
goodluck..
Aug 15, 2009 | Nokia N80 Cellular Phone
Blank on my samsung u600
The ribbon connecting screen to keypad is probably worn
new ribbon can be purchased on ebay for less than a fiver
Jun 23, 2009 | Samsung SGH-U600 Cellular Phone
How do i change the housing on my 6500 slide mobile
You need a T5 screwdriver and a new housing... Use an Original housing, copies dont usually fit right... 1, Remove Back cover and Battery. 2, Remove 4 T5 screws at the back of the phone, run your fingernail/opening tool around the housing and it should come away a little, dont pull it apart as there are 2 ribbons one for the Screen the other for the keypad. 3, Turn the phone over and run your fingernail under the keypad. 4, Carefully take the bottom half away with the phones PCB still in the bottom housing, using a flat screwdriver carefully lift off the two Ribbons 5, You can then remove the keypad from the top part of the phone, this is stuck on by double sided tape pull downwards, there are 2 spring loaded pieces on each side. 6, Remove the 4 T5 screws, 2 under where the Keypad was and 2 at the top 7, Again using your fingernail or a opening tool run around the edge and the screen part should come apart, dont damage the ribbon You now have the phone apart take out the bits and change what you like :)
Jun 10, 2009 | Nokia 6500 Slide Cellular Phone
Nokia n95 8gb lcd is blank but i hear it's turning on
if its blank you have to replace the lcd screen with a new one.
sometimes it maybe a flex cable problem which occurs in some slide phones.
at mobile phone repair stores, the cost of an original lcd screen replacement is usually $150-$200, though sometimes an original lcd screen may not be fitted into your device but rather a hong-kong made one which is similar to the original but is less brighter and a little less sharper.
if you take it to a nokia care centre to replace the lcd screen you may have to pay over $250.
you can just buy an lcd screen off ebay, replacing the lcd screen yourself isnt hard with the tools provided. you just have to take the ribbon cable from the old lcd screen and insert the new lcd screen and plug in the ribbon cable for it.
the reason for original Nokia n95 8Gb lcd screens being so expensive to repair/replace is that it is also the same lcd screen used for the Nokia N96.
cheers.
May 30, 2009 | Nokia N95 Cellular Phone
Acer Aspire 5100 new screen and still goes blank.
ACER PICTURE PROBLEM – MY SOLUTION
I had a similar problem, but I got a picture before it broke up and went off. The screen was backlit, but no video (screen was receiving some power).
The LCD needs a very stable voltage to work, this is provided through the LCD connector ribbon. In my case the ribbon was damaged and replaced it.
I have had no problem since.
I discovered this through trial and error; I first changed my transformer power supply and then the video inverter card.
You may find the link below helpful as it contains articles that photographically show you how to open the laptop for repairs.
http://www.insidemylaptop.com/category/1-acer-laptops/
Hope this helps. (Please rate my advice)
Jan 25, 2009 | Acer Aspire 5100 Notebook
you should take the phone to a mobile service center and have them replaced the flexcable for you
Oct 26, 2008 | Samsung SGH-D600 Cellular Phone
Screen display
take it to any technician, its ribbon need to be changed once it will get changed ur screen will start displaying everything, ribbon of screen has damaged , so need to be replaced
Dec 17, 2007 | Samsung SGH-D600 Cellular Phone
Samsung SGH-D600 Cellular Phone Logo
82 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
