Question about IBM Infoprint 1352 Laser Printer
Infoprint 1352 printer is leaving 3/4 of page shaded. chnaged toner. still same roblem.
These printers container a little replaceable cleaner over the drum. If it gets caked with melted toner over time it becomes ineffective, and then output gets darker and dirty.
Open the door on the back of the output tray on top, take out the little plastic part with the pad and clean off the accumulation of melted toner. If the pad is still good put it back in and the printer should be printing a lot cleaner, after a couple of runs through it.
If this does not fix it check the drum through the hole where you took out the cleaner. The drum might be messed up if you used it a lot without doing the above referenced procedure once in a while and might need to be replaced.
Hope this works for you.
Posted on Oct 31, 2008
Hp 2600n line
after you have printed a few pages switch the machine off just as the paper leaves the fuser. then open the front cover and take a close look at the image transfer belt ( black plastic conveyor type belt)
use a torch shone accross the belt to better light the error- if you can see these Green/yellow/cyan lines on the belt then theres a good chance its coming from the toner units- ( also try print quality troubleshooting pages in the menus under diagnostics.look at the individual colour pages and look for any lines or Uneveness about the shaded colour) replace whichever toner is not printing correctly
Jan 22, 2014 | HP Color LaserJet 2600n Printer
Why does printed page have gray shaded area on left side of the page and vertical gray stripes on rest of the page?
The drum unit on your printer is probably the cause of this. Try replacing the toner cartridge (drum is a part of the toner)
Feb 14, 2011 | HP LaserJet 4L Printer
I have a Minolta cs pro 2080 copier, shading on copies
3 possible causes:
1) The optics are dirty thus making your copy darker. The test for this is to manually lighten the copy using the exposure control on the panel of your copier. Lighten the copy several positions and see if the copy gets better. If it does then the optics need to be cleaned.
2) The copier is overtoned. This means that the toner to developer concentration is to high. This will require a trained technician to lower the toner ratio and then recalibrate the toner/developer ration using the F8 mode.
3) If the shading gets much worse as you run say 10 copies in a row then the drum cleaning blade would be the cause. So run 10 copies of something and compare the first copy out with the tenth copy out. Do you see a dramatic difference in the amount of background or "shading"?
Good Luck and thank you for using Fixya.
Mar 16, 2010 | Minolta EP4000/5000 CS/PRO Copier
Grey shading on page??
At first. clean the optic. Change the developoer. if no good? Cange toner - it is the soft way. Then photo drum. its may be not espensive if you calling to service. Clealing the coronat first and the second. There are no nothing
Mar 13, 2010 | Canon NP 7130 Black and White Copier
Dell 3110cn Printer prints shades of pink
Have you pulled out the imaging drum and transfer roller to see if they are caked in Magenta toner? if so they will need to be cleaned off. Would also suggest blowing out the area around the drum to rid of loose toner in that area.
Feb 15, 2010 | Dell 3110cn Laser Printer
My HP1020 prints black shade throughout the page
You have bad toner or a bad toner cartridge. Get a new cartridge.
Mar 12, 2009 | HP LaserJet 1020 Printer
Dark lines on printer paper
Possible.... other possible solution is a dirty drum... try changing the toner cartridge and cleaning the drum
Mar 11, 2008 | Samsung CLP 300 Laser Printer
Different looking text, but only in certain areas of the page.
Samsung CLP-300 color laser leaves 3-4 lines of various shades of black in middle of paper. Otherwise everything is great.
Posssible black toner cartridge problem?
Jan 30, 2008 | Samsung CLP 300 Laser Printer
Test Page blachy, text faint, supplies staus page bar vertically spotted
Have you tried the toner cartridge?? IF not please do so. Failing this clean out the middle of the machine with a dry cloth as you may have loose toner in there. Try this if it doesn't work then the laser unit may have a fault.
Hope the first one helps
Thanks J
Jan 15, 2008 | HP LaserJet 2430n Printer
IBM Infoprint 1352 Laser Printer Logo
100 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
