Question about Panasonic VIERA TH-42PX60U 42 in. Plasma HDTV
Why am i getting pink flashes on the screen
My tv will "strobe" with pink flashes around various pictures on the screen intermittently. Almost like a pink outline on door frames in picture, foreheads, etc. Not constantly, but enough to make me concerned.
4 Suggested Answers
  • 124 Answers
SOURCE: Picture and Sound flash from 'on' to a black screen
Hi, The problem lies within the unit. You have a hardware failure within the board. The power supply board needs to be repaired or replaced. If you are a handy person, you can easily swap the power supply board.. If not, bring it you to local reapir shop, they will find the parts and replace it for you. I wish I had a better solution like an easy fix for you. Sorry, but on hardware failure, there is no easy fix. Thanks, Mike
Posted on Nov 02, 2008
  • 298 Answers
SOURCE: My tv has a pink blob in the centre with a blue large ring around
Is it old-style CRT tube?
Does your kid have a magnet??
Sounds like you need a DEGAUSS.. or indeed your built-in DEGAUSS may not be working. This is usually 'fired' when TV is first turned on - massive AC pulse goes to wire loop around face of cabinet and clears residual magnetism so all dots hit where they are supposed to. If it goes out, this doesn't happen and eventually screen goes pink, yellow or purplish..... But this sounds alot like a kid with a magnet to me.
You can Buy a degaussing ring tool from MCM or HOSFELT electronics and fix it ;-)
Then take away the magnet)
Posted on Jan 18, 2009
  • 8457 Answers
SOURCE: Viera TH-50PZ83U, 20 months old, used nominally
The main Tuner signal board have problem.That the board,where the broadcasting signal cable plug into it.U have some skills,like take things aparts and put it together again?Yes,than.Try website like Ebay.com buy a refurbish Tuner signal board for the replacement.Or pay the shop for part and labors they'll to do it for u.
Posted on Oct 21, 2010
Testimonial: "Thanks so much. This is the first answer I have received that made sense!"
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My coby flatscreen comes on and works but strobes flashing light but works good just with strobing light ! whats going on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz,...
I have a Vizio plasma tv which intermittently flashes like a strobe when powers on. Other time turns on normally. Which board should I replace?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 19, 2015 | Vizio Televison & Video
Rca hdtv dlp screen flashing
Sounds like it could be the power supply. Try changing the brightness of the screen and changing picture modes like movie or standard. If this causes the flashing to change in severity, it will most likely be the power supply board
Dec 13, 2013 | Televison & Video
Got it new at Walmart in 2006? Never had any problems with it, and always had a surge protector. I know the kids have abused it though. Anyway, yesterday they had a pink, washed screen, turned it off/on...
No.The tv video board have dead components,that the board where it is connected to the CRT-(tv picture tube).Troubleshooting that video board and changes parts should fix ur tv problems.Hope ur tv problems,it is not the video board main big IC colors processor inverter.This big IC is a pain to change and probally not in the market anymore.Troubleshoot test all the capacitors around that big IC colors processor inverter alot of times just those few capacitors are dead only.
Apr 02, 2011 | Sanyo HT30744 TV
Green edge around images (outline)
my 2002 sony wide screen projection tv has menu and pictures when turned on first thing in the morning?
Jan 30, 2010 | Mitsubishi WS-55905 55" Rear Projection...
Flashing picture
I had the same problem with my 237V, I had to replace the power supply to fix the problem. I believe when it would work the output voltage of the power supply was around 19.2v. When the screen started to strobe the voltage had jumped up to 21.5V. A new power supply fixed it for me but now I think my main board is on the fritz.
Sep 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Pink and greenish lines creating a double picture
with your remote go to your menu and find convergence. Follow the instructions to auto set convergence. if that don't fix it the problem convergence panel if bad.
Mar 15, 2009 | Philips 55PW9363 55" Rear Projection...
Panasonic VIERA TH-42PX60U 42 in. Plasma HDTV Logo
287 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
