Question about Quasar VV-1319W 13 in. Combo
Orion tv manual 1319
Need Orion tv manual 1319, TV says its from 1997. Need to know how to hook up DVD player to TV, via a RCN Motorola cable box
premtech
  • 934 Answers
SOURCE: I need to program my tv to Cable but I don't have a remote
You'll need to get a universal remote if not the original... The original can be purchased from places like anyremote.com and a good universal from Radio Shack... I'd strongly recommend getting the original because some features are ONLY accessible through the original remote. Good Luck! Bill
Posted on Jun 04, 2007
Benimur
  • 6966 Answers
SOURCE: Hooking up a DVD player to a Quasar TV/VCR Combo
Yes, for a workaround. The adapter would be 2 RCA female to 1 RCA male. You have to connect both the red and white to the female RCAs and use the male to connect to the TV's Audio INput. The yellow goes to the video. There should be no negative technical effect other than lost of stereo quality. The audio output of the DVD is line level and could normally tolerate this condition.
The correct method is to use a simple line level audio mixer and mix the L& R audio signal to produce a mono signal or to use a stereo amplifier for the sound output.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 07, 2007
SOURCE: Where do I have to go on the tv to see that my Dvd player is working?
Well. I finnally figured it out. All you need to do is hook in the cable and let the cable program set to the channels.
Posted on Jun 24, 2008
  • 537 Answers
SOURCE: Please, I need a user Manual for this. Thank You.
Please check this link:
http://alpha.retrevo.com/support/Panasonic-VV-1319-TVs-manual/id/620ag406/t/2/
Posted on May 05, 2009
  • 163 Answers
SOURCE: TV hooked up to APEXDT502 Digital TV Connector; I
You can get a copy of the manual here
Posted on Jan 08, 2011
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Mintek DVD-1600 Setup to cable box/tv
A dvd player that doesn't record hooks straight to the television, not the cable box. Tv's typically have av jacks. If yours doesn't, you will need to buy an rf modulator. If your tv has the jacks, U will need to use your tv remote and hit tv video or input or source on that tv remote to switch between input and tv modes.
May 03, 2009 | Mintek DVD-1600 DVD Player
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Hook up DVD
I hooked up my DVD player to the Yellow/Red/White inputs on the back of the set. I think you can buy a manual for $2.60 from the Orion website. Good luck.
Jan 05, 2009 | Orion STV2763 27" TV
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Quasar VV-1319W 13 in. Combo Logo
66 people viewed this question
Top Quasar Televison & Video Experts
Radames Pagan
Radames Pagan
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
