Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Westinghouse television VR-3236 channel selection
Can't get to UHF channels by inputting the channel number into the remote. Have to run through the list of channels with the up arrow.
5 Suggested Answers
  • 3 Answers
SOURCE: Westinghouse LTV-19W6 TV Won't change channels
An email from Westinghouse that fixed the problem for me.
Thank you for your inquiry.
We apologize for any inconvenience in waiting for our response, but below is what I can suggest to move forward.
It appears all you need to do is run a channel scan on the unit. Once you have run a channel scan, you will be able to scroll through the channels using the channel up and down buttons.
If you have any further questions, you may contact us through email, or by calling us toll-free at 1-866-287-5555, between 9am and 9pm Eastern Standard Time, Monday through Saturday. One of our technicians will
assist you.
Posted on Dec 04, 2008
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Posted on Feb 20, 2009
  • 3 Answers
SOURCE: I just bought the Westinghouse VR-3215 and tried
for comcast use the sony code 10812 it just worked for me
Posted on Nov 11, 2011
SOURCE: Directv remote code needed
Follow these steps:
http://support.directv.com/app/answers/detail/a_id/3188/~/white-remote-control-programming-steps
When it asks you to enter the code for your tv use 10178
It works like a charm!
Posted on Feb 04, 2012
WD40FW2610 shows please run channel auto scan then i do thes it gots up to 69 and quits
What about your Westinghouse 40" LED TV? What was the year of manufacture? Did they offer more that 69 cable channels on that model in that year? Not on UHF/VHF bands!
UHF/VHF: AIR (2-69); CABLE (1-135) • Composite/C-Video Input: NTSC
Apr 24, 2017 | Televison & Video
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
Westinghouse VR-2188 will not find channels when hooked up to comcast basic cable box but will if connected straight into wall, whats wrong? Cable box works on all other TV's in the house also so it is...
Make sure you have selected "cable" as the source input to the tuner. If there is a selection for both digital and analog channels when doing a channel scan then select it.
Jan 04, 2014 | Westinghouse Televison & Video
Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Oct 07, 2012 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
I need to change the input on my tv but I don't
It's a westinghouse......you better get the model number off the back, then find a universal remote at walmart.....it'll give you a cpl different options for your tv....so read carefully the instructions that come with the remote you buy.
Apr 27, 2012 | Televison & Video
Will not find digital tv stations
I'll be glad to assist you in locating the digital channels in the TV.
Make sure that the Cable or Antenna Input is connected to the TV. The Cable and Antenna input can be connected to the VHF/UHF Input on the TV. The TV can search for the channels only if the VHF/UHF/CABLE input is connected to the TV. If you're connecting the Cable box or the Satellite Receiver to the Video or HDMI inputs on the TV, then it is not require to auto program the TV. Here, the auto program may be required in the cable box.
To Auto Program the TV, select the Manual Channel Search option from the Menu option and then select the CABLE, AIR or Digital Add-On option depends on the connection. The Digital Add-On option adds any new digital channels that are found to the Channel Scan Database.
This should resolve the issue. Please feel free to get back to us for further assistance.
Thanks for contacting FixYa.
Aug 04, 2011 | Sanyo DP46848 LCD TV
Lost remote want to use a univerisal remote but tv say front panel lock How do I unlock it? 32 in westinghouse
On the TV itself, MENU, SET-UP, INPUT, VIDEO then go to Channel lock and de-select it.
Hope this helps. If you post a model number, I can probably get you a manual.
Good luck, R.J.
May 13, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Need directv code for a Westinghouse VR-4085DF Television. The ones posted on Directv's web site do not work.
Need the firmware update and the codes still do not work... About ~ 40 scans in and my vr-4085 worked. Tried all codes prior. No luck.
This works on rc-65
There is no other setup code indicated for your product
that links to the model number you entered.
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    • 1 for Televisions
    • 2 for "AUX 1" devices - VCRs or DVDs
    • 3 for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Dec 09, 2010 | Westinghouse 16093 Remote Control
Sk-32h240s unable to get all local channels thru ant. only what whould be the formally vhf channels, not uhf.
UHF needs a UHF antenna most all channel antennas do not work good on UHF,
Try the set at a friends house that does get those channels. UHF is harder to get and that is why a UHF only antenna is needed by most people. Lots of antennas are junk do a search and you will find the 8 bay C/M is rated the best by a large margin.
A good antenna amp at the antenna is also needed it should be a low noise one. A search will show the ones that work best.
The Gov. as much as lied to us and the TV Stations the type of digital they forced on us is the wrong one and millions of people even with a great antenna have lost TV.
Oct 25, 2009 | Westinghouse SK-32H240S Television
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
163 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
