Question about LG RU-42PZ61 42 in. HD-Ready Plasma Television
Does the LG RU-42PZ61 support HDCP
I prefer to connect to my Marantz model SR701 AV Surround Receiver via HDMI. I have installed the correct adapter to my LG RU-42PZ61 Plasma TV. The SR7001 manual states: "When the HDMI is connected to a display that does not support HDCP, signals are not output. It is necessary to connect to a display that supports HDCP." Note: I am able to utilize S-Video or Monitor Out RCA type cables, but would prefer HDMI throughout my entire system.
  • 1554 Answers
SOURCE: lg plasma
there are 2 types of flicker, one is the lamps that drive the display and the second is the sync signal of the video.
I assume the video sync is the flicker you see,
I would try connecting a different way to make sure it is not the tv,
connect using the aux /rca connectors to cable box.
and or connect using the cable direct bypassing the cable box.
I have seen several complaints about the hdmi cable signal being incorrect in some way,
this is the same issue that the svideo connector had in its early adoption signal was too hot or too low.
another thing to watch out for is the low light sensor on the front of tv if it gets an incorrect reading it can flicker the back light though it should be slow in doing so.
some times the flicker you see is not flicker but ac running through the sides of the picture from an ungrounded cable source.
how does it perform if you play a dvd player , with and without the cable box connected.
Posted on Apr 29, 2008
  • 88 Answers
SOURCE: recording from LG 42pc1dv plasma tv to LG v782w VCR
If it does this on all channels then the video on your AV out from the TV is bad.
If it only happens with some channels then this is Macrovision protection working which will not allow you to record premium channels and any that are using this protection.
Posted on Jan 11, 2009
SOURCE: how can I use my lg lcd tv model m1994a for my ps3
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Posted on Nov 22, 2009
Testimonial: "ok!!! it is very much helpful...I solved my problem already using this I can play my ps3 games by my LG lcdtv 19 inches..."
  • 585 Answers
SOURCE: Can not get the listings for the TV Guide to load.
Hi my name is Roety,
I can help you with your issue ,
The cable box signal is received from a round cable called coaxial cable. The guide is sent to the cable box through the coax cable. The HDMI cables sends the picture to the TV.
The Tv does not download TV guide listings , just the box does. That would be a cable company/box issue not a TV issue.
Some TVs have a built in TV guide for when you recieve signals from an antenna (not cable).
If thats what you are referring to don't bother .
Use the cable box guide .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Posted on Dec 01, 2009
  • 73 Answers
SOURCE: I have a brand new LG 50 plasma and a Bravia Sony
you may have to set the input value on the bravia for optical on the input from the cable box. sometimes there is more than one way for a particular input to receive an audio signal, you may have rca(red and white), a black or orange rca type for digital, and then the optical. i would suspect you have to tell the bravia how the sound is inputed into the bravia. also , just a thought.... on the cable box there should be a volume control on the front of the box........ make sure the cable box volume is ALL the way up (it is the preamp volume).
Posted on Jan 21, 2010
Connect tv to iPad NO SIGNAL problem
Check the input or source on the TV to make sure it is on the correct input for the ipad.....
Apr 30, 2014 | LG 19LS4R 19" MULTISYSTEM LCD TV...
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
I have marantz Av surround receiver model SR301 I have tried a lot but I am having sound from only 2 speaker when I put in setero mode but when I put in surround no sound from any speakers I checked all...
First off you will need to do a little bit of trouble shooting. Is the source (dvd, Blu-ray, cable box, etc...) plugged into the receiver with the standard red and white RCA cord or by an optical (toslink-fiber optic) or digital RCA (orange color code). If you are connected with a standard RCA cord then that it your problem and you need buy digital cord that both the source device and the receiver can accept (toslink -,779.html or Digital RCA). If the connection is now correct then you need to make your receiver do a "test-tone" to insure that a signal can be sent to every speaker (this is an internal test that just checks the speaker connections). If the tone tone operates correctly then you know the amplifier is functioning. If both of the mentioned things are now done and still not surround output then you need to check the internal menus on your source device and make sure that it does not require you to manual change a setting in the audio menu to make it work (i.e. change from 2-ch 44KHz to 5.1 or 7.1 or Dolby Digital or AC3 or some other surround sound protocol.)
Aug 08, 2013 | Audio Players & Recorders
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
Jul 07, 2011 | Marantz SR7005 Receiver
I have a 55" LG
Easy solution; this is a very common problem. Connect Cable or satellite box / DVR directly to one of the TV HDMI inputs. Connect an optical audio cable from that box to receiver so sound is surround through your speakers. You cannot connect DVR directly to receiver because the anti pirating chip will shut off the picture and produce a green or no screen at all.
You can, however, connect a BD (Blu-Ray) player via HDMI cable directly to your receiver without that problem. Connect HDMI output from receiver to a second HDMI input on the LG.
Contact me if you need more help! All the best, John
Nov 14, 2010 | LG INFINIA 55LE8500 LED HDTV
No picture with cable to denon AVR-589
Long and painful answer!!! However, in the end, you need to bypass HDMI thru your receiver and go direct to the TV. Connect Digital Coaxial or Optical for audio to your receiver. Your version of HDMI in your receiver is not compatable with today's HDMI version. Yours is 1.1a and the current version is 1.3b going to 1.4. If you want detailed info as to "why", just google "HDMI 1.1 problems" you can read for hours! Sorry for the bad news! However, it is what it is. Hope this helps. If you need further help with setup, post a comment and I can give you further help.
Feb 28, 2010 | Denon AVR-589 Receiver
How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Dec 29, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Harman Kardon AVR 154 OSD setup screen wont display
It will only display via component. Your HDMI firmware is either 1.1 or 1.2 and has HDCP issues (High Definition Copyright Protection) it's a firmware problem that has been fixed on all new receivers, not just a HK issue, all receivers! the new version 1.3a and 1.3b have fixed the issue. Unfortunately you cannot update the firmware on the receiver. Hope this explains it for you, sorry! Lot's of angry people out there!!! myself included.
Jun 27, 2009 | Harman Kardon AVR 235 Receiver
Yamaha Receiver sound cuts out with Dolby Digital.
Your problem is related to HDMI technology not the Receiver. HDMI in it's current version 1.3b has worked out 90% of the current problems being reported by HDMI users. it's a problem with HDCP digital copyright protection and the recording industry not wanting us "consumers" to duplicate or record their DVD's. Your receiver and every other receiver with version 1.1,-1.2, & 1.2a just don't cooperate with BluRay and even HD Cable or HD Sat receivers. If you just purchased this receiver recently, return it and get an 09' model or equivalent with 1.3a or 1.3b HDMI technology. If this unit is "un-returnable" then, what needs to happen is you need to run component video and digital audio to the receiver OR Run your HDMI directly to your TV and run a Digital Coaxial to your DVD audio input on the receiver. Depending on how many sources you are running to the TV via HDMI will be limited to the TV's capability (how many HDMI inputs)
Now, if your TV is 50" or smaller, the difference between running HDMI and Component is unmeasurable to the human eye. So, if you have to run component, don't sweat it! just use good cable, ie. Monster, Phoenix, Translucent etc. I do theese installs every day, and I still prefer Component or DVI if available over HDMI. They just haven't proved the reliability to me yet and we're three years in! Hope this helps
Jun 23, 2009 | Yamaha RX-V563 Receiver
LG RU-42PZ61 42 in. HD-Ready Plasma Television Logo
Computer Repairing
Computer Repairing
