I get "Beep" errors when trying to start laptop, they are 1 long, 2 short, then a space, then 2 short.
  • 59 Answers
That sounds like a video or ram code try changing ram first as it is easier
Posted on Oct 24, 2008
2 short then 1 short beep
It may indicate error or issue with Video Card.
If you can open and reset VC or try resetting the RAM.
Jul 15, 2015 | ASUS N53SV-XV1 Versatile Entertainment...
Tip
Tipical Computer/Laptop Post & Beep Error Codes
Error Code: Faulty Component:
_____________________________________________________________
1 short beep None (Normal Boot)
2 short beeps ( POST error)
Non-stop beep ( Power supply or system board)
1 long beep and 1 short beep ( System board)
1 long beep and 2 short beeps ( Video card)
1 long beep and 3 short beeps ( Memory)
3 long beeps ( Keyboard)
Non-stop short beeps ( Power supply or system board,a key on the
keyboard might also be stuck)
None ( Power supply,system board,or system
case built-in speaker)
______________________________________________________________
Visual POST Error Codes:
Error # Range: Component with Error:
100-199 System Board
200-299 System Memory (RAM)
300-399 Keyboard
600-699 Floppy Drive or Floppy Controller
700-799 Math Co-processor
900-999 Parallel Port (LPT1)
1000-1099 Parallel Port (LPT2)
1100-1199 Serial Port (COM1)
1200-1299 Serial Port (COM2)
on Oct 01, 2010 | Computers & Internet
3 log beeps on power on
Gigabyte doesn't list 3 long beeps as an error code, so I'm not sure if you're actually getting 3 short beeps or maybe 1 long and 2 short or... But, for reference, Gigabyte's error code list is as follows (depending on whether you have an AWARD BIOS or an AMI):
(AWARD BIOS)
1 short beep: System normal
2 short beep: CMOS Error
1 long beep and 1 short beep: Memory error
1 long beep and 2 short beep: Graphic card error
1 long beep and 3 short beep: AGP error
1 long beep and 9 short beep: Memory Error
Continuous long beep: Memory not correctly installed
Continuous short beep: Power supply unit failed
(AMI BIOS)
1 short beep: Memory Error
2 short beep: Memory parity check error.
3 short beep: Basic memory 64K address check error
4 short beep: Real Time Clock malfunction .
5 short beep: CPU error
6 short beep: Keyboard error
7 short beep: CPU interruption error
8 short beep: Graphic card error
9 short beep: Memory error
10 short beep: CMOS error
11 short beep: CPU cache memory malfunction
It might not be a lot of help, but it's somewhere to start... and at least this way you'll know what to be listening for.
Nov 30, 2013 | Gigabyte Computers & Internet
Lenevo t61 1 long beep and 2 short beeo no display
Standard Original IBM POST Error Codes 1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Nov 09, 2012 | Lenovo ThinkPad T61 6457 Notebook
Ram beep but no display bios jumper is clear stat bios jumper is normal then no start machine
Please see this as reference
Continuous long beeps-RAM error
2 short beeps- BIOS error
1 long and 8 short beeps- Display Card error
1 long beep after few seconds 2 short beeps-FDC error
1 long beep after few seconds 1 short beeps-FDC is Ok
1 long beep and 2 short beeps-Display Card Error
Most probable cause is Ram memory, please try removing modules and reinserting, also try using alternately just one of them to determine which one is defective.
Mar 04, 2011 | ASUS P4GE-MX Motherboard
It makes this "BEEP" noise, I don't mean the one
Check the ram first.
1 short DRAM refresh failure -You can change the ram if you have a spare .
2 short Parity circuit failure
3 short Base 64K RAM failure
4 short System timer failure
5 short Process failure
6 short Keyboard controller Gate A20 error
7 short Virtual mode exception error
8 short Display memory Read/Write test failure
9 short ROM BIOS checksum failure
10 short CMOS shutdown Read/Write error
11 short Cache Memory error
1 long, 3 short Conventional/Extended memory failure
1 long, 8 short Display/Retrace test failed:if you beep long but one beep please check graphics
card on board video chip.
Follow the bellow link you can get more:http://www.pchell.com/hardware/beepcodes.shtml#ami
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Acer Computers & Internet
I was previously surfing the net using Chrome and I had opened many many tabs.. My laptop (Fujitsu Lifebook S Series - S6420) then hung/hannged and I couldn't do anything so I held down the power button to...
Your beep codes are..
1 short beep System is OK
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card .
So looks like a display problem, have you tried any of the recovery/restore options available when you press F8 on boot up
Sep 30, 2010 | Intel S6240 Notebook
Laptop with blank screen
so it sounds like your video card is having trouble
Jun 26, 2009 | Acer Aspire 5100 Notebook
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
Computers & Internet Logo
23 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
