Ariston amxxf 149 door wont open
Just did a regualr wash, and now the door wont bugde. Tried opening the panel in the front and at the back, and couldn't find any manual door release, or a filter to clean.
  • martin_t_h Feb 12, 2012
    Could also add that the "locked" light isn't lit when this occurs
  • inger_johann
    inger_johann Mar 19, 2013
    I have godt the same problem. How Didrik you fix it?
5 Suggested Answers
SOURCE: Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Posted on Jan 02, 2008
SOURCE: Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Posted on Jun 09, 2008
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
SOURCE: Cant open door of washing machine
I plugged it out. Left it for 15 minutes. When I went back the door could be opened and it also started to wash.
Posted on Jan 21, 2009
Door wont unlock
Some of these machines have a door lock that dose not unlock for a min. or two after wash is done. If so try the door now & it should open.
Jul 15, 2014 | Washing Machines
Cannot open Wash door
Here is a tip that I wrote about how to get your washing machine door opened...
Washing Machine Door Jammed
heatman101
Jan 24, 2011 | Ariston Technologies Ariston AWD12 Front...
Door handle on ariston awd12s has broken how i can i get the door open
open the table top of the machine and release the door switch by any flat screw driver
Jun 06, 2010 | Ariston Technologies Ariston AWD12 Front...
Moved the machine, put in the locking bolts , when i did the first load it stopped after the first cycle ...now its full of water and washing and i cant open the door?
Try laying the drain hose down to floor level, and let the water drain out into a bucket or similar.
You should then be able to open the door.
If you can't, then it will have to be released from inside the washer, this means removing the top cover to gain access to the door lock.
Hope this helps..
Dec 13, 2009 | Ariston Technologies AW 149 NA
We have the Ariston Margherita front loader washing machine and cannot get the door open
if the machine is full of water pump blocked or broken if machine empty needs new door interlock or pressure switch blocked or broken
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
May 17, 2009 | Ariston Technologies Ariston AWD12 Front...
Jan 20, 2009 | Ariston Technologies AWD121WH
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Closed door
Dear babmat: just now got your question. We are very satisfied with our ARISTON Washing Machine. I trust that that is what you are inquired about? I had the same problem the first time. This locking occurs when one opens or tries to open the washing machine door too soon!!!! It has to be left alone for a few minutes. When I waited and later tried again to open the machine, I did not have a problem.
Just wanted to leave this note for anyone who encountered the same problem. You, yourself, hopefully, might have gotten that answer and the problem fixed in the meantime!?
Greetings, handinovice
Sep 04, 2008 | Ariston Technologies AW129NA 16 Lbs Front...
Washing Machine Door will not open
it is poss that you pressure system has not released, and this can keep the door closed. Unplugging it will not cure this fault. It is also poss that you have a blocked filter or waste. Unfortunatly has you are older people I would call an engineer
Jun 23, 2007 | Ariston Technologies AW129NA 16 Lbs Front...
Washing Machines Logo
139 people viewed this question
Top Washing Machines Experts
