Question about Microwave Ovens
Swan SM21040 900-watt Combination Microwave
Swan SM21040 900-watt manuals
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave stopped working for no reason
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your tech sheet, you can download it here.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download Whirlpool owner's manuals and installation instructions here.
Posted on Nov 23, 2008
SOURCE: SWAN MICROWAVE SW1100W
we had power surge microwave not wroking properly
Posted on Feb 22, 2008
  • 2323 Answers
SOURCE: Panasonic NN-V671S 900 Watts Convection / Microwave Oven
User guide for your appliance.
Posted on Apr 24, 2008
woobie dog
  • 1273 Answers
SOURCE: Light inside the microwave is out.
Hello, This is a repeat of a previous post I made some time ago. It is for your make/model, if it is built in.... Mine is installed also, and I've had to replace the bulb twice. I wised up the second time and installed an access hole where I can pull my microwave out about 6" and access the bulb. I use a 35 watt 120v halogen bulb, with a GY 8.6 base, Lowe's part number 15797. If your's is different, the specs will be stamped on the metal beside the reflector when you remove the sheetmetal. You have to remove the microwave completely from the cabinet and remove the sheetmetal case that surrounds the entire unit. You can then access the lamp socket by looking in from the top. The first time, I took out the reflector with the socket. The bulb can be replaced by removing the two small screws adjacent to the socket on top of the reflector. My access port is a hole cut into the top. I cover the hole with a piece of sheetmetal and two sheetmetal screws. Seems to work just fine. If you do decide to cut a hole, do so with the metal enclosure off and away from the microwave to avoid getting any metal shavings into the machine! If, however, yours is an over the stove type, it may be possible to remove the front grille and replace the lamp.
Regards! --W/D-- feel free to rate this solution! Thanks!
Posted on Jul 31, 2009
  • 18 Answers
SOURCE: DCS - CMO24SS - 900 Watt - Microwave not Heating
If all appears to be running as its working but just no heat. Could be issue with magnetron. You could also have loose connections to magnetron or somewhere in high voltaged as well.
Posted on Nov 25, 2009
Combination swan
yes you can all depend the grade of expertise that you have or self-motived.
God bless you
Oct 17, 2013 | GE Advantium 120 Convection/Microwave Oven
Manual
Swan is now owned by Littlewoods. You can contact them here. The Swan helpline is at 01733 404 709.
Jan 30, 2013 | Microwave Ovens
I have a kenmore microwave hood combination. Model 721.80419. How many watts does this microwave work on?
It has a specified power rating of over 1000 watts.
There are 10 settings of power and is prrogramable.
get your manuals from the following link:
http://www.hammerwall.com/Download_Manual/59565/
Sep 18, 2010 | Kenmore 80412 Microwave Oven
Need instruction manuals for swan breadmaker sb1010nb. also swan slow cooker sf11020n
check out the swan web site for a downloadable instruction manual
Sep 11, 2010 | Microwave Ovens
I did not fet a manuel with my swan combination
GO TO MFG. HOME PAGE,SEE MANUEL SECTION..
THEY WILL HAVE YOU MANUEL AND JUST PULL IT UP AND READ OR PRN IT OUT....
FRED
Feb 14, 2010 | Microwave Ovens
Need manual for swan swm900c microwave
Aug 19, 2009 | Microwave Ovens
Where can i get the instruction manual fo the swan sm2050 microwave
Aug 03, 2009 | Microwave Ovens
Microwave Ovens Logo
513 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
