Question about Drills
How do I change screw bits - Drills
  • 3 Answers
Put the drill in reverse and hold the chuck (which is the plastic grip behind the bit) and tap the trigger. this will release the bit. If it's not a keyless chuck then you will need a chuck key, which you can get at your local hardware store. Tip: bring the drill with you to the hardware store as there are different sizes of chucks
Posted on Feb 12, 2012
Hey av got a hotpoint sy23x gas oven am trying to open the oven pan .Av opened the 2 screws on each side were the fire lights under neath. Screws are turning freely but can't get the pan off .
Sound to me it is a older range screws some time strip out in the metal cabinet . a bit tricky to get out you need to pull on panel at same time turn screw. panel may also take a bit to brake loose .
have some one pull while other turns screw .
after that there are more of same to deal with depending what part your changing welcome to my world good luck
Mar 03, 2015 | Hotpoint Kitchen Ranges
Burgess Vibro-tool Deluxe
Between the set screw and the bit. Use pliers to unscrew. U may need to hold the bit so it does not burn at the same time. Just like a drill :)
May 06, 2013 | Hand Tools
Top chuck just clicks but won't change bit size?
It sounds as though you will have to replace the chuck. Remove the screw (l/h tread) from inside the chuck first before removing it.
Feb 02, 2013 | Drills
Screw bit size the steering column cover on a 2001 Ford Escape
You thought it was a Phillips Screw
It is a Torx Screw like a T20 size, most likely
You also come across some metric hex at times,
so make sure it looks like a double hex,thus torx
Oct 18, 2012 | 2001 Ford Escape
Chuck will not hold bits, How to change chuck
down inside the chuck theres a big flat head screw that should do it.
Nov 17, 2010 | Hitachi DS18DVF3 18 volt Cordless Drill...
Was given a drywall screw gun to use, but I need to change the bit to fit smaller star drywall screws. How do I remove and replace this screw bit?
I use a DeWalt and the bit should just pull off like you would a cordless drill/driver. You might need a little persuasion (vice grips or pliers) because of the constant torque placed on it.
Mar 02, 2010 | Drills
What type of screw driver to change ignition lock?
TORK BIT, MOST LIKELY A "T-15". IT'S A STAR SHAPED BIT FOUND AT ANY HARDWARE STORE.
Jan 22, 2010 | 2000 Dodge Ram 3500
My brush is no longer working on my bissell healthy home vac. when i try to turn it on it makes a high pitched squealing sound. I'm pretty sure it needs a new belt but my husband is having trouble getting...
According to Bissel, they should be standard phillips screws. Nowever - things change.
This is a general guide from Bissel for belt change -
BELT CHANGE _ CLICK HERE
Check your model number on that site for exact details.
If the screws are Torx (star) or other security screws, tool bits are available from Screwfix -
SECURITY SCREW BITS
That fit standard loose-bit screwdrivers.
Hope that solves your problem.
Thank you.
Sep 22, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Screw in chuck is unknown size
this can be a problem if you have been using reversible drill bits in chuck as they tend to drill out screw head when drill bit jams if this has happened you may have to drill screw and use an easy out remember it will probable be a left hand thread
Aug 25, 2009 | Drills
Carb adjustment
Screw both screws right in (don't force them) Then turn each screw out 1 & half turns each OUT. This will get engine running. To fine tune- turn low speed screw out, bit by bit, while idling, till engine revs change, then turn screw in till revs change, the correct setting will be somewhere between the 2 adjustments you just made. Do the same thing to the high speed screw, but with full revs. Good Luck. Stevo..
Jan 16, 2009 | Garden
Drills Logo
50 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
