Question about Asko Dishwashers
Asko dishwasher 1374
Half way thourght a cycle it will stop and all lights on panel will flash
  • 18 Answers
SOURCE: I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Posted on Feb 04, 2007
SOURCE: Asko dishwasher problem
Hello, What you are describing is called an overfill. Sometimes programming, soap usage or installation can cause this. ASKO Customer Service will be able to give you troubleshooting tips and will most likely be able to fix this issue right over the phone as this is typically an easy fix. You can contact the ASKO Customer Care Group at 1-800-898-1879. They are open 24 hours a day, 7 days a week for your convenience. Sincerely, AM Appliance Group
Posted on May 29, 2007
Rotu
  • 175 Answers
SOURCE: Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Posted on Nov 06, 2007
Part Number: 99002254 you may need this part depending on model no
SWTCH-DOOR 99002254.jpg View Larger Image
Posted on Jun 02, 2008
SOURCE: asko dishwasher model 1475
Have the same problem with our asko 1475. In the past, we would disconnect the dishwasher and when we reconnected the power, it ran fine. This time it isn't helping!
Posted on Jul 12, 2008
Dishwasher asko 1895 the pump the working the lights are flashing but the machine is not working
The lights flashing is telling that there is a fault in the dishwasher.
I am assuming you have emptied the dishwasher after the drain cycle failed to work due to the pipe block.
You will have to make a fresh start. Empty the dishwasher, turn the power mains switch off and on to reset the dishwasher.
Start a new cycle and see if flashing lights stop flashing. If still same problem you will have to note which light(s) are flashing and send a post on this page. There is a chance the impeller in the drain pump may have sufferred some damage due to drain block depending on how long the motor operated before you found the problem with the drain.
Jan 04, 2013 | Asko 24 in. 1895 Built-in Dishwasher
Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
I have a old Asko Dishwasher. It works perfectly. However at times at the end of the wash cycle the soap remains in the dispenser. This happens half the time.
Put less soap in. Your wash will be fine with less soap. We have same problem. MARK: do not have tall objects underneath that will stop upper rotor from spinning. Also objects in upper basket kan penetrate and stop uppper rotor from spinning. Using less soap works for us.
Mar 09, 2010 | Asko 24 in. D3450 Dishwasher
Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
  1. Unplug or turn off breaker.
  2. Remove kick panel.
  3. Remove water from pan.
  4. plugin/turn on breaker.
  5. watch for leaks.
May 30, 2008 | Asko 24 in. 1885 Built-in Dishwasher
My Asea 1502 Dishwasher gets most of the way through a cycle then stops with lights flashing. It is empty of water. What is the problem?
Further to my problem with my 19 year old ASKO ASEA D1502 Dishwasher .
I found a Use & Care Guide online at the ASKO site:
http://www.asko.com.au/downloads/manuals/
(It is an 8MB PDF, only 20 pages scanned)
The manual says flashing lights in the combo I had indicate heater fault.
Manual has good test procedure and I followed that and it showed that the Heater is OK.
Machine works through full cycle but flashes at the end.
It is an old machine so I suppose I just live with it unless anyone has any suggestions.
Apr 23, 2008 | Dishwashers
ASKO 1595
yes have you tried what i suggested yet
Mar 29, 2008 | Asko D1776 Stainless Steel Built-in...
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Dishwashers Logo
114 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
