Question about Gateway GT5220 PC Desktop
Computer running slow
Can all the files in a Computers SEARCH base be delighted?
  • 47 Answers
Happy to help u .no u can't delight all the files in ur computer.
Posted on Oct 24, 2008
do a massive clean out of unused programs , and data
run the defrag program
in the search box under the programs on desk top screen type in CHKDSK and run that as it fixes any faults in everything ( takes about 6 hours to do the job but it fixes files and registry faults)
If still slow remove the disc type hard drive and install a solid state hard drive --much faster , no moving parts and stores more than a disc
Jan 28, 2018 | Computers & Internet
My computers so slow
Most computers actually run slow because of a hidden part of your system, which is constantly being used by Windows. This part of your PC is called the "registry" and is the central database for Windows, which stores everything from your latest emails to your desktop wallpaper. It's one of the most important parts of Windows and can easily make your PC run slow.The more corrupt registry files your computer has, the more it struggles to read them.The files which makes it run slower and slower. To fix this, you simply need to use a reliable like am using Reginout since 2011. This is the program which actually work by scanning through the registry and fixing any bad files that are in there. Then allows Windows to read as many files as it wants, when it wants to.
Good Luck :-)
Oct 31, 2013 | google.com
Laptop computer runs slow
Mostly laptop runs slow issue occurs due to broken Windows registry entries. Fixing registry will help you to boost up your laptop. You need to download and install a Registry Cleaner program to fix corrupt or broken registry entries. To download a reliable registry cleaner, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends. After downloading run all of its tools one by one except Internet Optimizer, to clean all the junks and registry errors from your computer.
Oct 27, 2013 | Computers & Internet
Hp netbook is running so very slow
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
Jan 17, 2013 | HP Mini 1000 Netbook
Will having too many processing program will slow down my Mac?
Maybe, or probably. Well, there are a number of reasons that may causing a Mac computer running slow, but generally two factors: hardware part & system part. For hardware part: I guess it's OK if your Mac is not that old. For system part: there might be a lot of junk files, caches, registry errors... out there which largely slow down any Mac machines. about 80% slow Mac caused by this reason, if so, try cleaning the system. Learn more from: http://www.howtospeedupmac.com/
Regards!
Feb 17, 2012 | Computers & Internet
Why is my computer running so slow it is saying tape drive is running and it will cause my computer to run slow
Check the System drive free space it should be more than the paging size configured. Also delete the temp files and temporary internet files from your profile will solve your problem.
Dec 15, 2009 | Computers & Internet
Slow Dell computer 4600
Normally computers get slow for the following reasons.
1) Infected with malware/viruses. Run free programs available from (CNET) www.download.com. These include MalwareBytes, SPybot Search and Destroy, Adaware.
2) Computer hard drive is full or seriously fragmented. Try removing unneeded programs (especially pictures) and then attempt a defragmentation.
3) Hard disk failing or getting old. Sometimes this is due to environment. Smoky, dirty or dusty environments will eventually contribute to build up of heat inside the computer and excessive heat kills computers. Also hard drives are mechanical and they do wear out over time. Laptop drives take more abuse because they are moved around more than desktops. If they start getting noisy then it is time to prepare to replace it. If you haven't done it yet GET YOUR IMPORTANT DATA OFF NOW!!!!
4) Overclocked or over heated processors. Dust buildup in the cooling fans and heat sinks can cause the temperature to rise and when processors get heated up they slow down and evenyually crash.
5) Running out of memory. As our computers get older we keep adding programs and eventually (if we dont upgrade the memory) the computer runs out of memory.
So if I were in your shoes I would do the following:
1) run some of the malware removal programs I suggested (if your hard drive has the available space for them) and also run your anti-virus program.
2) Remove unneeded files from the hard drive and then run the disk defragmentation tool. I once had a customer that had jammed her hard drive full of pictures and when it crashed it had no room to rebuild itself.
3) if all that does not improve the speed then see about getting an upgrade for the memory.
May 03, 2009 | Computers & Internet
Gateway GT5220 PC Desktop Logo
26 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
