Turned on tv using nec remote rp 115 now not working tried changing batteries but with no effect any ideas?
5 Suggested Answers
mighty thor
  • 51 Answers
SOURCE: remote control quit working
Batteries can be bad or installed improperly. If you know someone with a digital camera that has an lcd display, point the remote at the camera while someone is looking at the camera's image in real time. Infrared will appear as white light to the camera's CCD "eye". Cool trick.
Remember, IR is line of sight. Make sure nothing is blocking the path between the remote and the TV. Also IR remotes and fluorescent lighting doesn't mix.
Posted on Nov 24, 2008
  • 172 Answers
SOURCE: Samsung TV Remote
Replace it with a Universal Remote with Learning, This way, if the new Universal codes in its Manual don't work for your Samsung, (they most likely will if the new remote is not used older one bought off eBay) then you can Teach it to Learn codes off the working keys on you Samsung.
Sony Learning Remotes are a very good choice, sold at Walmart or eBay. The advantage to a good Universal, is you can also program in all your other audio/video remotes into one remote.
Posted on Aug 24, 2009
SOURCE: remote and manually not working
one of the batteries was not making proper contact and was loose,had to gently stretch spring contact out to make it stay in place .kept dislodging itself,so far so good.thanks
Posted on Dec 07, 2009
daveknowles
SOURCE: My remote does not work with my bush a632 tv. i
Great Fix... worked fine for me, I thought it was the wireless keyboard and mouse on my PC causing the problem A++++++++++++++++++
Posted on Nov 19, 2011
TV scrolls through inputs and menu after turning on. Will not stay on any input.
Main system control memory IC is faulty. Replace it. Contact any service technician. http://electronicshelponline.blogspot.com/
Mar 25, 2015 | Televison & Video
TV flips through channels at 2 channels per second.
It sounds like a button is stuck or bad. I would spray some electrical cleaner on the buttons 1st. If that don't work, the switch is probably bad.
Jul 23, 2010 | RCA F32645 32" TV
Nec tv codes for comcast universal temote
You may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Dec 17, 2017 | ViewSonic N3251w 32 in. LCD HDTV
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Dec 30, 2008 | Yamaha HTR-6130 Receiver
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
Cant program directtv remote to sony tv
I'm not sure of your model number but those remotes use the NEC codes and the variants on the NEC codes. If that code set is not the databse, you may have to "learn" it on your particular remote.
Good luck
Mar 20, 2008 | ViewSonic N3251w 32 in. LCD HDTV
No Picture
Sharp 42" lcd. TV accessed incorrectly. Resulting in no picture.
Using TV remote, changed from analog 2 to input 4. Turned off TV remote. Returned to satallite remote, turned on TV, turned on satallite, still no picture. We seem to have power but no satallite signal. Ist time users of satallite TV.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
