Question about Refrigerators
Maytag RSD2200 Freezer coils ice up solid
I have read other post. My heater coils measure 25 ohlms for the two in series at the junction panel. I see the defrost time spinning through the view window. Looks like defrost cycle is not runningl The defrost tubs look pretty discolored but coils inside seem connected. Not sure how they disconnect from wire ends. Not sure which is broken. Anyway to test the termostate, timer. Can I short two termainals on the timer to see if the heater coils will heat? Also where do I get parts for this thing, none of the diagrams online are my fridge. This is a 1993 model that has been great until now.
22yooper
  • 828 Answers
SOURCE: GE Profile SxS Refrigerator wont defrost after new heater installed
If one coil was burnt out and you replaced the heaters and defrost terminator switch I would recheck the continuity through the defrost heaters. You can do this with an Ohm meter with the refrigerator unplugged. If you had an open coil in one of the heaters you did not have to replace the thermo disk. If you have a complete circuit through the heaters try using the old thermo disk. If you have a meter you can check the voltage from the heater connection on one side to the inlet side of the thermo disk with the refrigerator running in the defrost mode. You should read 115-125 Volts on the meter. This reading tells you that the defrost timer is supplying power to the heater circuit.
Posted on Apr 30, 2008
docjohn174
  • 943 Answers
SOURCE: Freezer frozen solid freezer cool fridge not
HI look for this part in the freezer. its the most common one to fail.replace it
Posted on Oct 14, 2008
  • 958 Answers
SOURCE: Defrost heater wont heat up
so you seems to have done your homework. all the inputs are great.
you said you have 206 volts at the heater connection prior to connecting the heater.
and would become zero once the heater is connected.
so you have a loose connection from the timer to the defrost thermostat then to the heater.
does the defrost thermostat you are talking about is the same as the bi-metal that we used to refer in our technical language.( it is the part that would open up as the temperature inside the evaporator rises to a certain level.)
because if you are referring to the fridge thermostat which controls the compressor. ( this is also 0 ohm when closed), then the problem could be in your bi-metal.
this is the part in between the timer and the defrost heater.
it terminates the power once the temperature of the evaporator coil is about 5 degrees Celsius.
here's what you can do.
run the fridge for a day ( so that we would be sure that the bi-metal is close) then put the heater in place, turn the timer to heating mode by turning it slowly.
then place the test leads across the bi-metal, if you can measure 220 volts then that is the problem.
it is not shorting out even with a freezing temperature. you can further test the system by putting a jumper wire between the bi-metal and you heater should be heating up now.
tnx 4 using fixya,
drcool
Posted on Oct 31, 2008
SOURCE: GE Refrigerator Defrost heaters are shorted to ground.
My oven is turning on by itself. It will heat up to around 200 - 250 degress and shut off. I have made sure the knob is in the "OFF" position. Any ideas?
Posted on Dec 22, 2008
catriver
  • 878 Answers
SOURCE: Freezer won't defrost, coils full of ice.
Dave, you are throwing me a little here. By jumping line to defrost you should have 120 V. at the heater. J-11 to j-9. Are you measuring voltage? Lets ohm out the circuit. Unplug the refer and disconnect the blue connnector from the main board. Measure between the blue wire on the connector and the orange wire on J-7 pin 9. This is right to the right. You should have approx 22 ohms. If you don't have this the problem lies either in the heater, harness,or defrost T-stat. The Tstat sits on the evaporator, opens at 140 degtrees and closes at 110 degrees. So it should read closed. Let me know how you are doing, Catriver
Posted on Jan 29, 2009
I have frost on the freezer side and both the freezer and fridge are not keeping the food / frozen items cold. The fridge seems to be running constantly
remove the rear panel in the freezer,and if evaporator coils a solid block of ice,take a hand held hair dryer and melt the ice,then remove the heater located under the coil and test it for continuity,if open replace it with g.e.# wr51x10055 heater element
Aug 07, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Tip
Refrigerator not cooling-freezer section icing up
Refrigerator not cooling, ice forming on back of side-by-side freezer:
Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to expose iced-over coils. Use a fan to speed up defrosting. Put a towel or a plastic drip pan in the bottom of the freezer to collect melting water (rather than letting the water collect and maybe overflowing in the drip pan underneath the refrigerator).
After defrosting, by temporarily replacing the freezer back panel and turning on the unit, the refrigerator may operate OK for about 3 weeks before the next excessive ice build up.
Possible problem- a burned out Defrost Heater.
To check: After defrosting, turn off power to or unplug the refrigerator.
Unscrew the Defrost Heater bracket (2 screws). When loose, unplug the two wires connected to the unit. Have the unit checked, or use an ohm-meter to check continuity. If unit measures "open", high resistance, replace the Defrost Heater and bracket. If the heating element shows continuity (or low resistance) the heater is probably OK and you have another problem. Now you may need to contact a repair man.
on Jul 06, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Freezer is ok but refrig is at 60f even though it is set at max cool - maytag model mtb1954dro purchased 7-25-00
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Aug 01, 2011 | Maytag Refrigerators
Coils in my 2454 packed solid with ice. Thawed it out....worked fine for a couple of weeks. It quit staying cold so I dug behind the freezer to discover the coils again encased in ice. Thawed it...
your defrost heater around the coils is open and can no longer heat,or the adaptive defrost timer or defrost thermistor are defective located in the refrige control panel behind the temp controls and the thermistor is located on the defrost heater assy
May 02, 2010 | Maytag MSD2454G Side by Side Refrigerator
Maytag wide by side not cooling. just prior to this frost build up on top of freezer. Compressor not running.
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. My coil was solid ice.
Apr 05, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag SidebySide model MZD2766GES Fridge portion not working...
yes probably the a.d.c. but make sure all ice is defrosted from evap. coil. remove the freezer panel and use heat gun or hair dryer.
Aug 05, 2008 | Maytag MZD2766GES Side by Side...
Defrost for Maytag side by side
To access the heater circuit you must remove shelves from freezer, defrost the back panel with a hair dryer. Remove screws holding the panel in place and remove the panel. Defrost any ice on coil. This will give access to the heaters and defrost thermostat. If the defrost thermostat is deformed in anyway such as bulging at the molded part the chance is that that is your problem. Reading through the heater circuit with an OHM meter will tell you if the heater(s) are open. If you get an open reading replace the heaters. If this is above your capabilities call a service tech.
May 25, 2008 | Maytag MSD2756G Side by Side Refrigerator
Refer
Most likely the heater is bad. It is located under the evaporator inside the freezer rear wall . Look for a long glass tube about half inch in diameter with a long coil of wire inside. That is the heater . It can be unplugged easily.
Jan 21, 2008 | Maytag PTB2154G Top Freezer Refrigerator
Fridge not cool, freezer fridge temp
The most likely fault is a problem with the defrost cycle. The most likely is the defrost heater which should be a solid bar which is located directly underneath the coil. If you are capable then you can generally unplug the connectors for the heater and check that you have a resistance across the ends if the heater is faulty it will be open circuit. If it is not open circuit then it could be the defrost sensor or defrost timer at fault. You can also generally tell if the heater is warped or cracked. Hope this is of some help.
Sep 05, 2007 | Maytag MSD2454G Side by Side Refrigerator
Freezer compartment not defrosting
most refrigerators utilize an electrical heater coil to prevent freeze-ups. your coil has most likely failed. hard to pinpoint without being there, however, i would check its resistance with an ohm-meter with power off: if no resistance, then coil is burned out. look for around 2 ohms
May 26, 2007 | Maytag MBB2256G Bottom Freezer...
Refrigerators Logo
242 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
