Question about Whirlpool Fabric Freshener LRF4001RY
The fabric freshener is not draining the water
I have water in the fabric softener spot and it won't drain out
Water flushes the dispenser during the wash cycle to remove residue. Some water remains after flushing. It's not a problem.
Jan 19, 2015 | Washing Machines
My GS23R fabric steamer does not work.
Time to return under warranty. There are no user serviceable parts.
Nov 06, 2014 | Conair GS33R Compact Fabric Garment...
Bosch washing machine - electronic timer goes down to 1 minute remaining and stays there. Washing liquid has been drained from drawer, however, fabric softener is still there. We have resorted to stopping...
Check if drain filter is clear and drain pump is working properly. Also remove soap conditioner tray and check if you have black residue inside the soap/conditioner dispenser. Sometimes this can prevent water from entering the conditioner tray.
Oct 24, 2013 | Bosch Washing Machines
Unit doesn't steam during steam cycle
MAKE SURE YOU PUT DISTILLED WATER IN THE RECYCLE CUP. AND THE WATER
TUB IS NOT PLUGED UP.
Feb 10, 2012 | Whirlpool Fabric Freshener LRF4001RY
You know, it smells stale. What can I do about the odor? I didn't want to come out and say it "smells like ****."
Pull the panels on the unit look at the drain pan you will probably see a lot of stagnet water turned moldy you can remove this by flushing the drain pan. Also using simple cleaner to freshen up the unit. You can buy some evaporator coil cleaner that requires no rinsing to clean the coil that will freshen it up a bit.
Jun 27, 2011 | Convair Portable Air Conditioner
Leaking water from the actually fridge over the floor.
manually fully defrost unit,clean all vents /drain pipes
make sure door seals touch all round(no air gaps)
use bicarb to freshen interior and dry as best you can
then switch on and hopefully,if unit is working normally,enjoy...only place cold food in fridge to minimise ice build up.(some fridges have a drain vent in the centre bottom of door to allow water to drain when defrosting
Feb 14, 2010 | Refrigerators
Bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Sep 14, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
MY 90 WERIES KENMORE WASHING MACHINE FABRIC SOFTENER DISPENSER DOES NOT EMPPTY
I am having the same issue. I do know that the reason you don't see any physical provision for it to drain is because it is drained using a siphoning effect. water is put on top of the fabric softener until it reaching a point where the siphoning begins. Once the siphoning begins, the whole thing will drain out until there isn't much left (however there will always be a little water left). I know siphoning works with my drawer b/c when I take it out and fill it with water slowly until the siphoning begins, the whole thing drains out. There must be another reason why the fabric softener isn't working.
Apr 27, 2008 | Washing Machines
Whirlpool Fabric Freshener LRF4001RY Logo
140 people viewed this question
Top Whirlpool Kitchen Appliances - Others Experts
richie46
John Tripp
John Tripp
Are you a Whirlpool Kitchen Appliances - Other Expert? Answer questions, earn points and help others
