Question about Roper RGX4634KQ Gas Dryer
Dryer doesnt turn on when you have timer control on the auto cyclye side
If you push the on button on the dryer nothing happens unless you move the timer button to certain positions.
Buy another dryer
Posted on Nov 05, 2008
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
Rex4635eq2 electric dryer. all switches and fuses check out. Nothing comes on and the timer doesnt move or make a clicking noise when i push the start button. what do you think? Timer? Gary
You need to check your door switch and thermal fuse. The thermal fuse is located behind the back panel at about 6 oclock. If the thermal fuse is bad, you need to make sure the vent is clean.
Mar 26, 2011 | Roper REX4634KQ Electric Dryer
My gas dryer doesnt want to start. I push the start button and doesnt turn on. I checked the outwlet box were it is plugged into and it works because I connected a lamp it turned on. So I took apart the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Dryers
Dryer doesnt run when i push the start button light inside comes on when i open the door but nothing happens when i go to start it
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 20, 2010 | Dryers
I have a kenmore dryer. On the left side is the
Try a different cycle, the timer may just be hung up a bit. Also, check that the door latches properly. Any looseness, or noticeable debris should be addressed. Always unplug the dryer first before doing any probing.
Regards, --WoobieDog--
Jul 10, 2009 | Kenmore Dryers
Dryer will not turn on
POST YOUR MODEL NUMBER PLEASE
Apr 09, 2009 | Dryers
Batch complete sounds when start button is pushed
door switch or timmer or the knob on the timer may not be turning the timer
Nov 27, 2008 | Maytag PYE2300AY Electric Dryer
Dryer won't start
Check your door switch and wires to see if they are damaged first.You may have a bad Start Switch.If it is a 2 wire switch you can tape them together and then plug in dryer ,if it starts,replace the Start switch. Please Rate this!
Jun 12, 2008 | Kenmore Dryers
Roper RGX4634KQ Gas Dryer Logo
44 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
