Question about Nintendo Wii Console
Wii console My son i believe may have put a coin or coins into the Wii and now the each disc i try does not work and a error message comes up each time i put in a disc. Also the discs i have put in now seem to have scratch all the way round which again indicates ther is possibly something inside that is causing the erros. I bought it via an online German site last Christmas although i live in Glasgow How can i open my Wii to see if there is a coin or not? or where would you suggest i take it to get repaired in Glasgow? Thanks Grant
    President:
  • 4,402 Answers
Try or here
do not run the Wii till you get the coins out, you will cause more damage
you do need a special screw driver.
you can send it in to Wii or me!
Posted on Oct 24, 2008
Wii wont take disc completely in the unit help
try taking it to your local game store or take it apart or maybe the led reader is broken
Sep 01, 2012 | Nintendo Wii Console
Either my 2yr old brother or my 2 cousins put coins in my nintendo wii. This is the third time they have done it.The first 2 times, i shook my nintendo wii and the coins popped out but now i tried shaking...
If your Nintendo is under warranty, my advice is to take it to Nintendo service center..
If not you try removing the outer cover and remove the Coin...It should be poping out easil\y..
Dont try to shake it heavily, if the coim hits the Lens then your device eould be spoiled and you cant avail warranty..
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
Dec 03, 2010 | Nintendo Wii Console
My son put coins in the wii which I was able to remove it but now its seems like it doesn't read the discs. The wii turns on and goes to the main menu but thats as far as it goes. The arrow to select where...
He must like the arcade ;). Sadly, it sounds like the coins might have hurt the internals of your system, more likely than not it knocked the laser out of alignment. Best bet is to call Nintendo and see about getting them to fix it, since they will have to open it and this will void your warranty. Sorry :(
Jul 29, 2010 | Nintendo Wii Console
My son has put coins in the disc area which i have removed but now I have inserted a disc and it wont come out?
Maybe its because you were messing with the disc area and you made it jammed or something. First of all, you dont put coins in the disc area, its used for discs lol. Anyways, you could fix it by bringing it to a store or replacing the console. Hope that helps.
Jan 20, 2010 | Video Game Consoles & Games
My 2 year old stuffed a couple of coins intoPS3
open it and try to get the disc port open on then just take out the coins and put it back together (and try to keep coins away from your 2 year old)
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
How to remove coins from a nintendo wii
kids inserting coins in the video game??? is this? disassemble the wii and remove the coins...take a look in youtube and you will see many videos tutorials to disassemble it...
Good Luck!!!
Sep 09, 2009 | Nintendo Wii Console
My daughter has put a coin into the wii thru the disc slot an now i cant get it out can u help
That will be very difficult, the Wii requires a special screw driver to get the face plate off. It is called a Tri-Wing screwdriver, you can google for it if you'd like to attempt to fix it yourself.
There are two other ways you could try to rectify this. Unplug all cables from the back of the wii, turn it upside down so that the cd-rom slot is facing the floor, and shimmy it around a bit to see if you can get to the point where you are sure the coin is agains the cd drive. Then you could carefully attempt to stick in some small tweezers and try to grab out the coin. Just don't stick the tweezers in more than an inch or so, that way you avoid doing any damage. If you still can't get the coin out you should probably call Nintendo, they can fix it for you, and probably for free. Their number is: 1-800-255-3700
Jul 07, 2009 | Nintendo Wii Console
Coins placed in the disc slot of the Wii.
I would not advise using the drive if there are any loose objects inside. Doing so would void your warranty, cause damage to the wii, and possibly even bodily injury. If the disc should come into contact with the loose object while spinning at high speed, the disc could shatter and the shards may actually break through the drive casing.
A loose object, if it catches something traveling at high velocity, can easily damage the casing and the wii remember
The only practical solution is to remove the drive from the wii and obtain a replacement. It would be prohibitive to try to fish out the loose object, since you might damage the internal components in doing so. you will need to call Nintendo ( 1-800-255-3700) and see if they can fix it or guide you through taking the disk drive out
I don't think they will slide out if you turn the MBP on edge. I would take it to the Apple store and be prepared for a nice bill. I hear kids also do this in the disk player in the car to get it fixed It won't be cheap, I 'm afraid,
At the very least the drive will need to be removed, I fear. It may actually have to be replaced. A few hundred dollars, I would guess.
Good luck
May 06, 2009 | Nintendo Wii Console
A coin inside it
take it all apart u will ne small torx screw drivers from sears ok to get to it take it apart then lid off u can get coin out ok
Feb 01, 2008 | Nintendo Wii Console
Nintendo Wii
From the official Nintendo website:
"Object inserted into the Disc Slot If an object is inserted into the Disc Slot, it will automatically be pulled in, and it won't be possible to eject it. Do not attempt to open the Wii console or otherwise try to remove the object, as it may result in further damage to the console.
The Wii console will need to be repaired. Because this type of damage is not covered under Nintendo's warranty, there will be a charge for the repair. Please call 1-800-255-3700 to discuss available options."
Nov 17, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
236 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
