Question about Kenmore Refrigerators
Manual Model 106.53606201 Ice Maker doesn't work
Ice Maker doesn't make ice
duby1990
  • 367 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
freetek
  • 5568 Answers
SOURCE: amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Posted on Jan 09, 2009
SOURCE: LG refrigerator model lfx25950tt ice maker not working
I had the same problem and replacing the filter solved the problem for me.
Posted on Mar 22, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
arikrom
  • 528 Answers
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Posted on Dec 30, 2009
Ice maker doesn't work
remove im and look into fill tube,if there is ice in fill tube,defrost with hair dryer and replace selinoid valve at bottom back side of unit.if not frozen replace im
Apr 09, 2013 | Kenmore Refrigerators
How do you reset Ice maker module
put the metal arm down to turn it on or pop off the cover and with a jumper wire stick it into the T and H,the ice maker motor should start to run,pull out the wire after 20 seconds.if it doesn't start you have a bad ice maker.
Sep 02, 2012 | Kenmore Side by Side Refrigerator
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
My ice maker doesn't work. Where do I start? Model number 561
HI.FIRST MAKE SURE U HAVE TURNED IT ON.SWITCH OR LEAVER.2- WATER ON 3-WATER IN ICE TRAY.4 IF EMPTY PUT SOME ON MANUALY.AND TRY.IF IT WORKS ONCE AND STOPS THEN U HAVE A WATER SUPPLY PROBLEM.CHECK PIPE;WATER VALVE.IF ALL OK THENNNN...ICE MACHINE?HOPE THIS HELPS.ALI
Jun 30, 2012 | Sub-Zero Refrigerators
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker doesn't dispense ice
The most reasonable things could be that the gas ran out; the buttons and thermostat don't work; power issues; or you might have a leakage on the gas pipe.
Try calling a fridge/air condition technician to verify this.
Nov 23, 2011 | Frigidaire FRS26RBCW Side by Side...
I need the instruction manual for the deni ice crem maker model 5400
I've scanned the manual for the Deni 5400 as a PDF file. I posted it on here I have one and it still works.
If it doesn't show up, you can use this link http://db.tt/LDAiFU2s to get the instructional manual PDF. I'll leave it there for a while.
If you appreciate this and like the Dropbox sharing service, you can sign up to get an extra 250MB of storage using my referral link http://db.tt/OFOEbLQ.
Sep 17, 2011 | Deni 5400 Scoop Factory 1.5 Quart Ice...
Refrigerators Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
