Question about Panasonic Lumix DMC-FZ8 Digital Camera
Panasonic lumix fz38 shutter button
My shutter button has lost its pressure, i.e I can press it down to take picture, theres no sponge under button, if you know what I mean. Can I repair this myself and how! Help any advice, its too expensive to repair privately and cost nearly as much as the camera, ridiculous! Also would this effect my flash? it comes up fine but at the same time as button went , my flash stopped working? thanks
SOURCE: Panasonic TZ1 flash problems!!
Panasonic knows about this and can fix it. It involves replacing a circuit board. I sent them my camera (Elk Grove Village, IL repair facility) at the beginning of Dec with a letter giving six web sites reporting the problem and asking them to fix it free of charge. I don't think the camera was on warranty, but I received it back, fixed, and with no charge, in about a week. Panasonic really came through on this and there is clearly no fix other than this one... except to stop trying to take flash pictures.
Posted on Dec 28, 2007
SOURCE: Problems with my Panasonic Lumix Digital camera
let me explain to you guys, these cameras are slim line cameras and if dropped or mishandled it is going to give problems. you cant blame the camera if you are not handling it corectly.
Posted on Jul 09, 2008
  • 3 Answers
SOURCE: Panasonic Lumix DMC-TZ3 shutter doesn't close all the way and gives message "please turn camera off then on again"
My camera got dropped into the dirt. The dirt grains are detrimental to the plastic mechanics of the lens system, they imbed themselves into the plastic and become like sand paper. I took my whole camera apart - something that I would not recommend but I was desparate. I don't think I can save my camera, it needs a new optics.
If the shutter has problems it is most likely that the thin aluminum casing at the front of the lens got bent and you may be able to bend it back with a thin screw driver, that you can manage to insert between the plastic casing of the shutter and the aluminum cover. Just where the aluminum casing ends at the front of the lens. But be careful, you may otherwise damage the aluminum and the looks of your camera. If you got dirt in there, you may want to manually (carefully) open the shutter when the camera is shut off, let it close, etc. while blowing air between the gaps of the shutter blades. You can buy a 'Cleaning Duster' spray bottle from Office Depot and use that. But be carefull to hold the bottle straight, don't tilt it or the liquid content will spray over your lens and you have to clean the oily residue with a solution of soap and water (I had to) and wet a paper tissue (use a Kleenex that is not impregnated with a lotion, on the back of the box it will tell you 'Not recommended for cleanig eyeglasses'.
Hope that helps.
Stephan
If that doesn't work, then you may have to send the camera in for repair.
Posted on Sep 16, 2008
  • 60 Answers
SOURCE: Purple Screen
If it is only 2 months old,then you still have warranty.
A purple lcd, viewfinder and photo is a 100% CCD failure.
If out of warranty, not worth the repair.
Posted on Mar 07, 2009
  • 11967 Answers
SOURCE: Panasonic Lumix Fx35 Malfunctioning
Go into the setup menu and scroll to "reset"...follow the on-screen instructions. This procedure might work. If you can't get into the menu because of malfunctioning buttons, try a manual reset...remove the card and battery...press all the buttons...insert the card first and then the battery...turn it on.
Posted on Sep 14, 2009
When pushing the shutter button i do not get any more the pause after the focus. the camera always takes the picture. how do i fix this problem?
Did you press the AF / MF button on top of the camera. Just a little to the right of the main dial?
Try pressing it again.
Let me know if it helped.
Success
Apr 25, 2014 | Panasonic Lumix DMC-FZ7 Digital Camera
A blank screen on my fz38
Try pressing the DISPLAY button on the back of the camera to see if that corrects the problem.
Nov 09, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
When half press the shutter button, the camera immedietly snaps a picture, it does not focus on the object or get the correct exposure.
Yeah,why did you half press the shutter?When you take a photo,you should press the shutter with force quickly.I think you didn't set your Panasonic Lumix DMC-FZ5 Camera at a proper mode for the scene,shot with a correct the next time.Wish helpful to you.
Nov 22, 2010 | Panasonic Lumix DMC-FZ5 Digital Camera
I have a Panasonic Lumix DMC-ZS5 digital camera. My pictures often are blurry & not crisp. Help. All reviews & friends recommended this camera. Even if I use sport mode this happens. Most of...
With autofocus digital cameras, blurred photos are almost always a result of camera shake. You need to hold the camera still even after pressing the button, as there is often a short delay before the shutter fires.
Many digital cameras have a two-stage shutter press- first pressure causes the camera to focus, then the follow through pressure takes the picture. If you are rushing this, you may get unfocussed shots.
Finally, make sure that you have not left the camera in Macro mode. This is a special extreme close-up mode offered by some cameras, and it does not allow autofocus on object at normal distance.
Oct 27, 2010 | Cameras
How do I use the self timer on my panasonic lumix dmc tz10?
Press cursor-left (marked with a one-handed clock). Use up/down to select a mode. Start the self-timer by pressing the shutter release button.
Aug 06, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
USERS MANUEL in English needed
Go to the support section of the Panasonic website and enter Lumix FZ35. That's the same camera in the USA. If your camera comes in a color, you will need to add the letter of your color.
Jan 10, 2010 | Panasonic Lumix DMC-FZ30 Digital Camera
Sep 14, 2009 | Panasonic Lumix DMC-FX35S Digital Camera
How to use auto timer
1. Turn on the camera in picture taking mode.
2. Now press the left arrow button.
3. Select the timer duration with the up and down arrow buttons, then press MENU SET.
4. Aim the camera, focus and press the shutter button. You now will have either 10 seconds or 2 seconds before the camera takes the picture.
Jul 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-FZ5 Digital Camera Problem
Possibly the shutter release (the "take a picture button") or the mechanism under it is getting stuck down and not coming back up to let you take a second shot.
Try cleaning under there with a can of compressed air. Be careful because the release button is super fragile - looks big but only held on underneath by a tiny stalk about the size of a pin (I know because mine broke off when the camera dropped). Panasonics are light but fragile, others, like Sony, heavier but much more solid.
Oct 22, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Panasonic Lumix DMC-FZ8 Digital Camera Logo
121 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
