Question about Exercise & Fitness
NordicTrackl c2300 model NTL12944 bad burning smell
A few moments after I start on the treadmill I smell a "burning odor"
    Top Expert:
  • 12,223 Answers
Dear Sir:
You have 4 conditions when burning smell:
1) Very high belt/deckfriction.(Lack of lubrication by maintenance2) Short in the motor.(The same problem maintenance)3) Short in the wiringor electronics.You must have some skill in electricity or electronic or you can cal some service tech.4)Literally cooking the lacquer or cardboard core (on cheap machines) in themotor from belt friction or a drive system,The same lack of maintenance and lubrication.
And recommend that RUN the Calibration Software for easy diagnose and troubleshooting that coming with your treadmill, most of them the instruction step coming from the Hood of motor, and follow the instruction, or use your manual Ins.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 16, 2012
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: treadmill rubber tread has strong odor
Turn off and unplug the unit before making any adjustments. Check the belt alignment on the treadmill. If the treadmill is making noise or you smell burnt rubber, the belt may be loose or out of alignment. There should be a belt roller on the side or the front of the unit. You can use a hex wrench or an adjustable wrench to loosen the belt so it can be properly aligned. Make sure you tighten the belt so it does not rub against the machine. Consult the user manual for specific instructions in adjusting the belt.
  • 2 Reposition the heart rate monitor. If the monitor does not show a reading, it may need to be repositioned. The monitor should be placed against your skin so the sensor is facing toward your body and the HealthRider logo is facing away from you. The monitor will only work if you stay on the treadmill, walking in the middle of the belt.
  • 3 Test the hand grip monitors for a correct reading. These are the metal plates that are secured to the hand railing. If the plates are dirty, they may not function correctly. Wipe them clean with a damp cloth. Your palm will need to wrap completely around the plates at all times for a proper reading.
  • 4 Reset the unit if the treadmill still does not function correctly. Unplug the unit from the electrical outlet. Leave it unplugged for about one minute and then turn the machine back on. Remove the safety key from the treadmill and reinsert it into the key slot. Taking out the key will reset the unit, clearing all memory and resetting it to factory defaults.
  • Posted on Nov 15, 2011
    My tredmill works but after few mins I get burnt smell?
    Treadmills are relatively simple machines, which means a burning smell can be quickly determined.
    Check your treadmill belt for wear. Try to find where on the treadmill feels hot when you smell the burning. It could possibly be the electric motor or wiring giving out under load.
    Oct 01, 2015 | Cars & Trucks
    Power surging
    sounds like the treadmill is drawing too many amps. try using a larger surge protector.
    Feb 19, 2014 | Nordic Track NordicTrack C2300 Treadmill
    I have a 1990s JVC tv that we were wattching the other day then we smelled a smoky smell. Then horizontal lines and staticy sound started to go through the tv. We tried canned air to clean the vents a few...
    That tv is very close to catching on fire. UNPLUG IMMEDIATELY. When electronic equipment is old they dont just stop working sometimes. Sometimes the electrical current starts burning the wires and the dust inside. there is a definare odor to electronics burning or shorting out. smell around the air vents in the back of the TV. youll know if wires were burning its a distinct odor
    Jun 03, 2012 | JVC Televison & Video
    There is bad smell from the motor
    Dear Sir:
    There can be 3 options: 1) Deck belt smell bad 2) Drive belt smell bad 3) Drive main motor winding burn. Test it and proceed according.
    or Course you can do it by yourself or 2) call to service tech.
    God bless you
    May 22, 2012 | Exercise & Fitness
    Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
    1) Try to reconnect the plug between console and pcboard very well.
    2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
    3) adjust the Sensor SWITHC.
    4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
    If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
    Nov 17, 2011 | Exercise & Fitness
    Treadmill rubber tread has strong odor
  • Nov 09, 2011 | Exercise & Fitness
    While running on treadmill I got an odor of slight motor burn out. Then i got a code of FET and the machine shut down. After ten minutes i plugged back in and it would have operated but i didn't...
    hi, some treadmills you have to top up the oil in the motor just like a car. if you have the instruction booklet this will be explained. and the burning smell is normally the belt on the motor and not the motor it self. hope i have helped.
    Nov 11, 2010 | Life Fitness T5i Treadmill
    When we start the car after it has not been started and engine is cold, we get a strong exhaust odor on the inside of the car until engine has warmed up
    Is the exhaust loud? If not it may not be an exhaust smell. I work at an exhaust shop and we have seen a few vehicles with the same issue. More often than not, it ends up being a fluid leak (usually oil) that has flowed on to an exhaust manifold or front pipe and on start up the fluid burns off, causing the odor. Once the fluid has burned off there is no more smell. This is no to say the leak has stopped, but the odor is less noticeable when the vehicle is moving and the fluid burns off a little at a time as opposed to all at once like it does on start up. Hope this helps to steer you in the right direction, good luck!
    Jan 28, 2010 | 2004 Cadillac SRX
    Burning smell from AC Unit
    http://www.hannabery.com/faq14.shtml
    "Odor problems can be as serious as a gas leak or as simple as a dirty air filter. But remember, a good mechanic doesn't just use his hands. He uses his ears and nose. Unusual odors could indicate a serious problem and should not be ignored.
    We will go through each of the five categories and list the possible causes and things to check.
    1. Electrical odor - Electrical odors are usually caused by parts overheating. Indoor blower motors are a common example. If there is a mechanical failure such as the bearings seizing up, the motor over-heats and the insulation on the wires and the motor windings themselves start to melt, causing the odor.
    Sometimes loose electrical connections cause wires or plastic relays to overheat causing electrical odors.
    It is possible for a very dirty air filter to cause the odor. If the airflow is restricted enough, it could cause electric resistance heaters to overheat, even burn-out.
    If you smell an electrical odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
    2. Burning odor - This is similar to an electrical odor only worse. It is also sometimes accompanied by smoke. Once again, this can be caused by parts or wiring burning-up.
    It can also be debri such as plastic getting into the ductwork and melting on the electric resistance heaters or heat exchanger.
    If you smell a burning odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
    3. Gas odor - First of all, if you really smell gas and suspect a gas leak, you should open the windows, get out of the house, then call the gas company.
    Now excluding that "worse-case" scenario, if you notice an odor that smells like gas and it seems to be coming out of the supply vents, it usually isn't gas. Sometimes dust that settles on the heat exchanger during the summer months burns off at the beginning of each heating season and it smell just like gas.
    If the odor doesn't seem to be coming from the vents, try to pinpoint where the smell is coming from. Use your nose. If it is gas, it usually would be from a leak in a pipe fitting or at the equipment itself.
    Gas odor is the one that causes the most fear. People think of gas explosions or carbon-monoxide poisoning. Well, gas explosions are very rare and carbon-monoxide for the most part is odorless.
    Having said that though, don't take a gas odor lightly. If you can't locate the source of the odor and you are worried you have a gas leak, remember, open the windows, get out of the house, then call the gas company.
    4. Oil odor - Oil odors are usually caused by one of two things. An oil leak/drip or an oil burner that is not working properly.
    The oil leak is usually easy to spot. Just look for oil. Check the burner itself, the oil tank, filter and oil line. Sometimes it is just a matter of tightening a fitting. If there are no signs of an oil leak then it is most likely a burner problem.
    This can be caused by many things, too many to list. It could be a minor adjustment to the burner to a faulty or blocked chimney. From a bad fuel pump to a plugged oil nozzle. Listen for any unusual rumbling or banging sounds or smoke or soot while the burner is running. If you notice any of these things and/or you have an oil odor, you should call for service immediately.
    One other common problem today is that new houses are insulated so well and are built so tight that they run out of combustion air, causing odor problems. In this case it is just a matter of bringing in a fresh air for the burner. Call your local Heating Company to assist in a proper diagnosis.
    5. Damp and musty odor - This is more common in the air conditioning mode. Sometimes attic units or very damp basements have this problem. Check for air leaks in the return ducts. Check for water damage to the ducts or air handler itself. Possibly consider having your ducts cleaned. Run a dehumidifier and see if the odor goes away.
    But this odor problem is almost never due to a problem with your equipment.
    Final Tips:
    Keep in mind that almost all heating systems cause an odor the first time they are fired-up. And the first few times at the beginning of each heating season. Brand new furnaces are coated with oil to keep the heat exchangers from rusting. This burns off, creating a bad odor - even smoke. But it usually only lasts for about 20 minutes. Opening the windows usually solves the problem. And the first few times the backup heat on a heat pump kicks on, it smells like an electrical smell. This might last for a few days but isn't that bad. If you are worried, call for service.
    Remember to check for a clean air filter and that your vents are opened. Check to see if the fan is working which mean your motor hasn't burned-up.
    Check for air leaks in damp areas, oil stains or rumbling sounds, strong gas odors - these all indicate problems. Do not ignore them.
    Hope this helps, remember - these are just rough guidelines and not all possible situations are covered."
    Jul 28, 2008 | Sharp CV-P09FX Air Conditioner
    Exercise & Fitness Logo
    244 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
