Power on problem with delay in powering on.
  • Dwayne Page Feb 13, 2012
    Sharp Aquos 42" LCD can take anywhere from 5 to 20 minutes to power on!
    Top Expert:
  • Televison & ... Master
  • 74,666 Answers
Hello
The power board to your TV should be replaced. It has the trouble. Normally, there is no repair is possible to this board. It is better to replace it as card.
Posted on Feb 13, 2012
FIXYA The power supply output of my Dell Dimension 8200 desktop pc is delayed for minutes after i press the ON button in the tower front. The momentary button switch is OK. The delay is 15 minutes if
It's not about the switch, a problem may be caused by bad power management control driven by XP. Ask on DELL's forum about any patches about this. Finally, check-up your power management scheme.
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Mar 06, 2014 | Dell Computers & Internet
2011 Grand Marquis Accessory Delay Doesn't Keep The Radio On
If you open your doors that feature won't work
You stop the delayed feature once the doors open
At least try it & see if I'm correct,may not be that way
on yours
Jan 28, 2013 | 2011 Mercury Grand Marquis
We have a 1EGD1 dayton timer delay relay what is the wiring diagram
Open following link to identify timer:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1EGD1&op=search&Ntt=1EGD1&N=0&sst=subset
This is typical 8 pin delay timer relay.
The wiring diagram appears on side of the timer.
Open following link for example how to wire 8-pin timer.
http://waterheatertimer.org/images/Connect-relay-to-timer.jpg
Example shows 24Volt, but 120Volt wires exactly the same.
The timer is 120Volts. So connect power to terminals 2 and 7.
Other terminals are dry, and receive no power when 120V is connected to 2 and 7.
In the example wiring, the objective is to have power connected to Load at all times except when timer activates. So power is connected to terminal 1 and Load wire is connected to terminal 6.
If the objective was to have power connected to Load only when timer turns ON, then connect power to terminal 1 and connect Load wire to terminal 3.
Read how to wire timer:
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#pin
Oct 07, 2011 | Amperite Dayton Solid State Timer On Delay...
I have a fan timer that delay for 30mins for every set time but the problem is when the power is out it loses its memory and start with 30mins delay all over again
Power outages are not that common.
If I understand correctly, you have or need some kind of automatic delay timer, like the Paragon ET series.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#ET
Or maybe the Dayton off delay timer.
Or you have an occupancy sensor with time delay like the Tork SSA.
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#SSA
Is this timer hard-wired into a box, where it gets steady power?
Is the timer supposed to have a back-up rechargeable battery?
If this is a digital Tork box-type timer, most of those timers have a power-loss carryover.
If you can identify your timer, or say more details about how your timer operates and where timer is located, and what fan Load is, I might be able to suggest an alternative that works for your purpose.
Add a comment.
Dec 14, 2010 | ICP Vortex Fan Timer Control Board For Air...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
48DD0284 model I am wanting a part number for a Time delay relay. Dont know how to look up
I looked up information and the unit is obsolete. I also did not see a time delay in the diagram with the original unit. It must have been added later. Post me back and let me know where it goes and what numbers it has on it.
Nov 28, 2008 | Carrier Heating & Cooling
Strange delay.
I'm having the exact same strange delay problem as you.
I fixed my delay when I too took my machine to your girlfriends. LOL!
No seriously.... you solved your delay problem yourself when you UNPLUGGED the power cord from the back of the monitor.
My guess is that when you unplug the power cord, the monitor resets itself. It's only a temporary fix, but, IT WORKS.
1. Turn the monitor OFF
2. Unplug the power cord from the back of the monitor
3. Wait 10-15 seconds or so
4. Plug the power cord back in
5. Turn your monitor ON........DELAY ELIMINATED.
The delay returns eventually, but, I just unplug-n-replug and I'm good to go again.
Apr 07, 2008 | Gateway FPD2275W LCD Monitor
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
