Question about Locks & Locksmithing
How to change battery micro fridge safe
Micro fridge electronic safe
3 Suggested Answers
dmathwizard
  • 113 Answers
SOURCE: small floor safe Sentry Model 3877 electronic lock and key
This manual will answer both of your questions.
http://www.sentrysafe.com/pdfs/OwnersManuals/501664.pdf
Posted on Mar 05, 2008
SOURCE: I have a micro fridge electronic safe and forgot
i havea micro fridge safe and the battery died i cant open it
Posted on Jan 07, 2011
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    The batteries run out and the key is inside safe ,how i can open it
    heat the safe for about an hour. This should raise the level in batteries to enable it to open. Change batteries straight away.
    Mar 07, 2011 | Safe International Digital Electronic Safe...
    When I key in the pin it says to proceed but the bolt wont open. do I have to change the batteries? If so, how do I change it? My safe is a fire safe S0607
    Locksmith advice on how to install sentry safe batteries
    slide open the battery cover located just below the keypad.
    Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
    reconnect the connector and put back the battery holder. Slide the cover back in place.
    How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
    turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
    Aug 10, 2010 | Sentry Fireproof Safe
    I forgot my safes password
    call a local locksmith he can help, if it can not be opened you may have to bust it open, call some one with many tools they may help. I recommend an angle grinder this will cut through steel. If you can remember where the pins are that hold the door closed you can grind through the side and cut the pins with two cuts. would take ten minutes to open with this method. There is probably an upper and lower pin.
    Apr 01, 2010 | Safe International Digital Electronic Safe...
    Change battery of sentry safe
    To install sentry fireproof safe battery
    reconnect the connector and put back the sentry safe battery holder. Slide the cover back in place.
    Dec 01, 2009 | Sentry Fireproof Safe
    Locks & Locksmithing Logo
    189 people viewed this question
    Top Locks & Locksmithing Experts
    ray gallant
    Tom Chichester
    Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
