Question about Uniden Radio Communications
I have a uniden cb pro 510 xl cb radio that the speaker doesn't work. I cannot find where or how the speaker connects into the power board. Is there a wiring diagram for this available?
The 1987 Pro 510 xl is receives transmissions, but the speaker is not connected. how do I connect the speaker to the control board?
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi Anie,
START HERE: join yahoo group specific to your radio Make/Model, they have all the answers, plus you can download manuals and other stuff, i.e,. schematic diagrams for your radio.
I hope this helps.
Cheers,
Peter
Posted on Mar 04, 2013
Benimur
  • 6966 Answers
SOURCE: how to install echo board in uniden pc66 cb radio
You have to cut the microphone line and put the echo board in between. The INput of the echo board should go to the end that goes to the microphone connector, the OUTput would go to the wire that leads to the CB board.Connect also the B+ and ground. The B+ should go to the switched B+ of the radio while the negative can go to any grounded area.
Good luck and kind regards.
Posted on Oct 25, 2007
SOURCE: philips fm92 cb radio
Hi there soleman , it was common for Philips to fit fuse holders to both positive and negative wires on their radios , the red with black trace is neg the plain red is positive . Cheers T
Posted on Dec 05, 2007
dobhan
  • 105 Answers
SOURCE: repair to my radio schack model PRO-2050 scanner the unit is mfg by uniden
be spicific,you did not mention, what are the problem of your unit,pls elaborate....
Posted on Jan 25, 2008
SOURCE: mic wiring
Here is the wire diagram for the Galaxy:
1-SHIELD
2-MOD
3-TX
4-RX
I hope this helps you!
Posted on Apr 16, 2009
SOURCE: Wiring diagram for accessory plug needed.
I am looking for the same wiring diagram. The headset Moto sells is a single earpiece with microphone, so how does that end up being a stereo connection Neto? Just curious how, or is there also a full headset with microphone? ( I dont' know, just asking)
Would this be a 4 ring TRS connector? Sleeve = ground, then left, right, and the tip as the microphone??
Posted on Sep 21, 2009
CB Uniden 4-wire mic to a Uniden 510 radio how to wire color codes please
look up microphone wiring diagram for your cb and mic. more than one way to wire, depending on mic and cb having 4 or 5 on plug end. write down mic numbers and cb plug numbers. if audio on mic is 3 and cb is 4 put 3 on 4 pin check each wire. using power mic make sure red and black wire are on the right pin, can damage radio or mic or both.
Feb 11, 2018 | Uniden Radio Communications
Uniden pro 520 xl,fuse type
generally, a standard AM only CB will use a 3amp fuse.
Jan 30, 2014 | Uniden Pro 520 XL
Wiring diagram for uniden pro 520 cb radio
is this the 520 or the 520 XL? go to www.cbtricks.com for the 520E wireing diagram
Sep 25, 2013 | Uniden Cb Radio Pro 520
How do I resoder the plug on a uniden cb mi
You need a schematic diagram to make sure you connect the correct wire onto the correct connection, else you'll stuff up the radio.
If you've never done this before, then don't find a technically minded friend to do it for you.
That's my advice.
Cheers,
Peter
Apr 28, 2012 | Uniden Pro 510 XL
How to turn the power down uniden pro 520 xl
For this radio you adjust power through coils in the back of the radio. Using a watt meter and a plastic screw driver push coils L201 and L202 together and the power output will decrease. If D203 (modulation limiter) has been removed you can replace that as well. This should get you fixed up. Good luck.
Jan 10, 2011 | Uniden PRO520XL 40-Channels Base CB Radio
What do you clip to turn up the power on a uniden pro 510 xl new style
hi you cannot tweak anymore output power from these radios as ajusting any components will damage the rig ,they come factory set at 4watts tweaking it anymore will after prolonged use damage the finals /pa transistor so leave it well alone if its not broken dont fix it goodluck
Oct 27, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
ADD TALKBACK TO A UNIDEN 510 WITHOUT A PA JACK
In theory you could locate the AUDIO pin from the back of the mic jack, and add a resistor from there to the center pin of the ext speaker jack in the same manner as you would a PA jack.  But look into more before you do as I have never done it that way and Unidens sometimes have a funky way of wiring their boards.  If I had one laying around I would try it out but I don't.  best of luck!
Jan 22, 2009 | Cobra 150 GTL DX Base CB Radio
WANT TO ADD TALKBACK IN A RADIO
A 200 ohm 1-watt resistor across pins 1 & 4 of the mic jack will make some talkback. More or less resistance will make less or more talkback. Note the association of less and more.
Uniden Pro 510xl can send but not receive
If you look on the solder side of board you shoud see a straight line of 5-7 solder joints, look on the other side the audio vhjp is a bmack thin retangular ic chip. Not to worry you wont hurt anything by doing this. Its an old cb tech trick to test audio chips.GOOD LUCK.
Oh one other thing does the radio have same same problem in either vehicle? A insulating washer on the antenna bracket can cause this also,
Happy New Year , Tom
Dec 30, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
Radio Communications Logo
131 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
