Question about Linksys WRT54G3G Wireless Router (WRT54G3G-ST)
Multiple router is it possible to have more than 1 router connected to a single phone line? My current router does not have the range I need
Sorry I mean't connected to a different BT socket not to another router i.e. 1 router connected to phone socket then another router connected to anothe socket in a different room
Posted on Oct 26, 2008
  • Linksys Master
  • 6,487 Answers
Yes, you can use multiple router on one single internet line, in order for you to do that you need to connect the second router to the main one using a CAT5 cable/Ethernet and everything should be ok already.............
Posted on Oct 24, 2008
1 acres =
One acre is about 4047 square meters or about 43,560 square feet.
Feb 20, 2014 | EnGenius FREESTYL1 Slim Design Long Range...
How do I connect multiple (two or more) 3 phase ac power sources (from wind turbine alternators) to a single 3 phase junction to power one device?
what did you mean by single 3 phase? single phase motor have two wire output 110-110, 3 phase gen have 3 wires 110-110-110. if only two wires here ,this is single phase, all appliances are only single phase so you can connect it here, except some 3 phase motor or dynamo. the ac current has no polarity so you can connect to it all kinds of load depends upon the amperage of of your turbine generators
Jul 22, 2010 | Kitchen Ranges
How to connect multiple phones to voip adapter? Only line 1 is available for connection.
Have you tried using a 5 or 8 port switch to see if this will allow u to have 8 or 5 more phones available ...they do make a 25 switch if you want to add 25 phones
Sep 18, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Need to connect phone and fax machine to one phone jack
You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:http://www.trianglecables.com/tellinsplitl.html
A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
Mar 29, 2009 | RCA 25201RE1 Corded Phone
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Need to connect ans. machine to single line on a multi line business phone. Help!
Out of box, the AT&T 1738 is designed to operate on a single telephone line. I don't know of any device on the market today that could automatically switch it between multiple telephone lines.
Some options include (in no particular order):
1) Purchasing additional 1738s to cover the other telephone lines.
2) Some cordless telephones on the market are designed to handle 2 telephone lines. Their answering machines will cover both lines. AT&T and Panasonic offer such phones.
3) Check out AT&T's line of NoKSU small office telephone sets. The phones will handle up to 4 telephone lines and 1 model features a built in answering machine. In order for the telephones to function 100% all phones would have to be replaced with the models within the AT&T NoKSU family.
4) If this is strictly a business application, consider purchasing a true business telephone system for the office.
Sep 24, 2008 | AT&T 1738 Digital Answering Machine
Special Applications
Some applications require multiple connections, such as Internet gaming, video conferencing, Internet telephony, VPNs, and others. These applications have difficulties working through NAT (Network Address Translation). If you need to run applications that require multiple connections, specify the port normally associated with an application in the Trigger Port field, select the protocol type as TCP (Transmission Control Protocol, UDP (User Datagram Protocol), or both, then enter the public ports associated with the trigger port to open them for inbound traffic. The Trigger port is an outgoing port (from LAN to WAN) that the application will send out. Step 1 Open your web browser and enter the IP address of your router (192.168.0.1). Step 2 Enter your username (admin) and password, if any. Step 3 Click on Advanced tab on the top and then Applications on the left side. Name - This is the name referencing the special application. Trigger Port - This is the port used to trigger the application. It can be either a single port or a range of ports. Trigger Type - This is the protocol used to trigger the special application. Public Port - This is the port number on the WAN side that will be used to access the application. You may define a single port or a range of ports. You can use a comma to add multiple ports or port ranges. Public Type - This is the protocol used for the special application. At the bottom of the screen, there are already defined well-known special applications. To use them, click on the edit icon and enable the service.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Open Questions:
Linksys WRT54G3G Wireless Router (WRT54G3G-ST) Logo
54 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
