Question about Wahl Vision 180 Beard Trimmer
I have Wahl vision 180 B & M trimmer, I dropped in the sink, and it came apart, I reassembled the blades and spring and it moves like it is going to trim, but does not. what do you suggest? Do you have a diagram?
rick_stokes_
  • 61 Answers
SOURCE: I have Wahl vision 180 B & M trimmer M 9858,
It is very likely that one of the plastic pieces that hold the spring mechanism broke. If you send it back (with all the pieces and clipper) to Wahl Clipper, 2900 N. Locust St., Sterling, IL 61081, they will probably fix it for you for free.
Posted on Sep 30, 2009
rick_stokes_
  • 61 Answers
SOURCE: this is a very good shaving machine and i want another one
Wahl Clipper Corp
2900 N. Locust St.
Sterling, IL 61081
USA
815-625-6525
Posted on Dec 15, 2009
askmannyssha
  • 76 Answers
SOURCE: does the Wahl Model AC Trimmer have an adjustment
Wahl has two type of blades for this AC trimmer, some come with a fix blade no adjustment,the other type of blade has adjustable blade. Wahl dose market the blade as adjustable or non adjustable. But mannyssharpening.com has the adjustable blade type were they can adjust the blade for a close cut.
Posted on Mar 30, 2010
SOURCE: how do reassemble the blade for Wahl 8552
I had the same problem with the Wahl Pro Series Rechargeable model 8552, and called Wahl service. Here is what I learned:
Never unscrew the screws on a Wahl blade (they use those funky nonstandard screws to deter you) -- that's the main thing. The whole blade assembly is supposed to come off by pulling it up and off from the teeth.
But, if you did it (as I did), you can put it back together this way:
1. Place the large blade down on the table (Wahl logo down), and place the small blade on top of it (if you look carefully, you will see how it lines up).
2. Insert the spring points into the two holes of the white plastic part (on mine, the spring kept slipping out and I finally used a drop of superglue on each hole until it would stay in long enough to complete the assembly). Place that piece on top of the small blade (see photo).
3. The bent metal piece with the two screw holes then gets placed on top of the large blade, with the center ridge of the bent piece over the straight center portion of the spring -- so that you have to hold it in your hand and push it together against the spring in order to align the holes of the entire thing. As you are holding that, put the screws in from below and tighten. It's awkward and if you are like me, it will take several tries before you can get it all lined up correctly and tightened. The photo below is what the final assembly looks like before snapping it onto the clipper.
3. Clip it in: At the top of the assembly in the photo below, notice the small bent metal piece that will fit into the back of your clipper in the hole. Once you fit that properly, push the whole assembly down onto the clipper until it snaps into place.
Posted on Nov 22, 2011
Blade assembly: My WAHL Peanut trimmer hit the floor and fell apart.. How do I reassemble the blade which has also detached.
if it broke apart when it hit the floor then you will have more problems than just putting the blades back on. those are fairly well put together so coming apart means they hit pretty hard. you wont ever get them to cut right even if they go back together. your gunna have to just buy new ones.
Aug 01, 2014 | Wahl Tid-bit Mini peanut Trimmer Clipper...
Putting a wahl 9307 back together
You will notice there is a little hook that the spring thing fits into on the device. You want the smaller part of the spring facing upwards and it should tuck in smoothly.
This is the smaller part of the spring facing upwards:
Then it gets tucked in as such:
Take note from the above photo that the square edges on the plastic piece go at the top of the blade piece and the rounded edges are at the bottom.
Then the bottom blade piece rests on top with the curvature facing upwards: putting-wahl-9307-back-together-g0fa4lo4hxabacpjggd4qk4j-2-5.jpg
The rest should be straightforward!
Jul 10, 2014 | Wahl 9307
How do i put back the blades on a wahl 9918C beard trimmer
You connect the blades together with the plastic part the correct way through the top of the small moving blade. The plastic part becomes a guide to keep the 2 blades running straight and true. Then engage the plastic part into the motor cam shaft and the 2 tension springs at the same time and wriggle it onto the screw hole posts and fit & tighten the screws. Lubricate and you're done.
Jun 22, 2014 | Wahl 9918-600 Beard Trimmer
How to open wahl super trimmer model 1591/1592
Push the blade teeth away from the trimmer body, it will just click off. Undo two screws behind blade, undo one screw at rear of trimmer from the bottom. That's it cases will now split apart.
Jan 19, 2013 | Wahl The Peanut Hair Trimmer
I lost my instruction manual. How do you oil the Wahl beard and mustache trimmer model 99180? Thanks, DJ.
Oiling the trimmer is very simple. It is only necessary to apply oil to the blades. Simply apply one or two drops of oil directly to the blades while running. This should be done before each use.
You should have gotten a bottle of the blade oil with your clipper. If you have also lost this, you can buy a bottle of Wahl clipper oil from shaveroutlet.com. see link below
http://shaveroutlet.com/wahl-4oz-squeeze-bottle-clipper-oil-p-584.html
Jan 24, 2010 | Wahl 9916-800 Groomsman Beard Trimmer
This is a very good shaving machine and i want another one
You can get these wahl trimmers from Nose Hair Trimmer, that can be used for removing unwanted hairs from nose, ears and eyebrows.
This place would provide you most attractive deals on these branded trimmers with free shipping service.
Apart from wahl trimmer, you can also get recommendations for various other branded trimmers that are hygienic, comfortable and safe to use.
lowcost2.ru_2015.05.08-12.19.02_984580_electric_shaver_nose_ear_face_hair_removal_trimmer_clipper_dlya_nosa_y_ushey_y_brovey3-lmanv4snjocb41esrne4nwpm-3-2.jpg
Dec 03, 2009 | Wahl Vision 180 Beard Trimmer
I have Wahl vision 180 B & M trimmer M 9858, with 3 complete parts separated:a)a 1.5" x 1.5" flattish blk plastic & metal piece with cutting 'comb' at the end; b)a 1" x 1.25" Blk & metal piece...
Sep 17, 2009 | Wahl Vision 180 Beard Trimmer
The trimmer does not move although charged!So the trimmer head can be slid onto the handle of the beard trimmer. Once it clips in, and I turn on the charge, the device works for at most a minute before...
It sounds like you may need to oil the blades with the clipper oil that is included with the kit when you bought it. The blades will become gummy and sticky after use. The "Wahl oil" provided with the clipper is specially designed to "de-gum" the blades and let them move freely. The knob you speak of only holds it from rotating and should have any affect on run time. The only other possibility is if the rechargable battery is at the end of its life which shouldn't be the problem unless it has been used a great deal.
Aug 12, 2009 | Wahl Vision 180 Beard Trimmer
Wahl Vision 180 Beard Trimmer Logo
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
