Question about Sony Playstation 3 Slim Console
Solid state drive seems to freeze up my ps3
I upgraded my hard drive in my ps3 to a solid state drive and i notice the system freezes up a lot...any one else ran into this problem?
SOURCE: ps3 freezes on all games
i have the same problem...
Posted on Nov 23, 2008
  • 14 Answers
SOURCE: error 8001002B
That is the common "dirty disc" error. If it happens with every game, it more than likely means that your Blu-Ray diode is dirty. Do you have the PS3 in a dusty environment? Be sure to clean the vents on the side, above the USB ports and on the back of the PS3 on a daily basis. A quick swipe of a soft cloth will do.
You can try several solutions for your problem, the most common to buy a can of air and blow it inside the disc drive in hopes of cleaning the diode. You can also try a CD/DVD cleaning disc.
If it happens with every disc this could also mean a dreaded Blu-Ray drive failure, or in your case, one that is in the process of failing.
If cleaning it does not work, I highly recommend you give Sony support a ring.
Posted on Jan 26, 2009
  • 265 Answers
SOURCE: PS3 freeze
hey guys i fixed this...
its over heatings the CPU and GPU
you need to disassemble it... http://www.llamma.com/PS3/repair/PS3_disassembly_tutorial.htm
then you need to replace the thermal compound with artic silver 5 as the stuff sony has put on is very dry and cracked, i have done this 4 7 of my mates PS3'S and they all work fine.
only do this if its out of warrently, if you removin the sticker on it, it shines through void
Posted on Feb 16, 2009
  • 35 Answers
SOURCE: ps3 keeps freezing
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Posted on Mar 12, 2009
  • 85 Answers
SOURCE: PS3 freezes when booted up
This sounds like your hard drive might be bad. Try pulling the hard drive out of your PS3 then turn it on and see if it will turn on. If the system turns on then i would say your hard drive definitely needs to be replaced.
Posted on May 17, 2009
When changing from one profile to another my ps3 freezes. how can i fix this?
Your internal hard drive may be on its last legs. You might need to replace it with an off-the-shelf consumer laptop-sized (2.5") hard drive. Otherwise, you can access the recovery menu of the PS3 by turning off the console, holding the power button until the unit turns on and then off again, WITHOUT releasing the button until it does so, and then releasing the power button and holding it in again until you here three beeps in a row. Then you are to release the power button, and wait for the repair menu to start up. From there, rebuild the hard drive, and hope that fixes your issue. If it doesn't, take a trip down to your local electronics store and buy a hard drive from them. If you're lucky, they might even be willing to install it for you if you bring your PS3 along with you. Otherwise, it's very easy to install it yourself. Just go to Sony's website and follow their manual on replacing and upgrading a PS3 hard drive.
Mar 21, 2014 | Video Game Consoles & Games
Sony vaio vgn-fz21e upgrade solid state drive
If you are looking to upgrade to a solid state drive, or already have a solid state drive and just want to upgrade the size, you will have to purchase the new drive, when you receive the drive you will have to turn the notebook over and there should be a rectangular panel underneath about 5"x3" inches which can be removed by a small Philips head screw driver, remove the panel, carefully remove the hard drive installed, and install your new drive. Put all the parts back, and then you will have to do a clean install of an operating system on the new system. Good luck!
Aug 17, 2012 | Sony VAIO Notebook
What should i do if my PS3 keeps freezing When i
The big question here is what can you do when you see your ps3 freezes? Well there are a few things that you could do.
The first thing you could try doing is sending it back to Sony if you really want to. Because they are the ones that made it, they will certainly be able to fix the annoying ps3 freezing, but that certainly comes with a very high price. You could pay about $150-200 just to repair the ps3 freezing issue and you might not have your console for 1-2 months! Can you deal with that? Can you really do without Solid Snake and that massive alien invasion for an entire month?
If the answer to that is no, then there are a few things that you can try by yourself as far as fixing the Ps3 goes.
First of all you could try searching for loose cables within the system. This could cause a problem, and this is especially true if there is a loose cable on the actual hard drive. In some cases it might be necessary for you to replace the hard drive which would be pretty easy considering that the Playstation 3 uses a standard SATA hard drive.
Because it is most likely an overheating problem it couldn't hurt to have a look at the fans. There is one large fan on the bottom of the console that is vital to it's operation, so make sure that one is actually working. If it is not, then you should either replace it or put a cooling pad underneath the Playstation.
As luck would have it (or not), many other people have run into the Ps3 freeze problem themselves. There are some that have managed to fix the ps3 freezing problem on their own, and they were nice enough to put together guidebooks that you can learn how to repair ps3 freezing problems in http://www.ylod.net/.
These guides will cost you some money, but not nearly as much money as you would be paying to ship the console back to Sony. On top of that, you won't have to wait 6 weeks for your console to be repaired! These fixes are usually quick and easy and they work like a charm if you follow the instructions step by step.
Stop sitting around wondering if your Ps3 will ever work again. The truth is it could probably be working today!
also check this link
http://www.youtube.com/watch?v=sojXPm0e6UQ
Jul 13, 2010 | Sony Playstation 3 (PS3) Console
My Ps3 freezes before loading up the home screen
if it's hard drive has a lot on it it will lag try cleaning out old saved games and music it will speed up.
Aug 15, 2009 | Sony Playstation 3 (PS3) Console
My PS3 freezes up shortly after start of game, won't run movies
I believe you may have little or no memory left...
you can upgrade it with a 500 Gb HDD from SATA (2.5' 8or 16" MB Cache make sure it is 5400 RPM ) You can buy it at best buy..
I replaced mine... and it works great now.. when you replace it you can download the software into your external hard drive and transport it back into your ps3..and itll instantly upgrade it for you
Jul 02, 2009 | Sony Playstation 3 (PS3) Console
May 17, 2009 | Sony PlayStation 3 40GB System
Corrupt files
If you can get to it without it freezing use the System Restore function under:
System->Settings>Restore PS3
If you can't get to it because of freezing you should put your hard drive into another PS3. It will see it as a new drive and prompt you to format it. Afterwards put it back into your PS3 and it will do the same thing again.
It doesn't matter which PS3 yours or the one you put your hard drive into, they're all the same as far as the process goes.
Feb 20, 2009 | Sony Playstation 3 (PS3) Console
I'm currently trying to upgrade my ps3 to version 2.35 but it keeps freezing at 1%
Check out your ps3 guide that came with the ps3 and check out the hard drive section, pull the hd out and replace it.. shows you how to in the guide.. shut the system ff after you re-install the hd and let me know what happens. Should fix it!
May 24, 2008 | Sony Playstation 3 (PS3) Console
Download freeze
Is this when you try a second and third time to download the same movie? Try a different one. Update to version 2.2 (came out last night). It has upgraded reliability for the internet. Hopefully that helps. Good luck!!
Mar 16, 2008 | Sony Playstation 3 (PS3) Console
Game Freezes
It seems that your system is having trouble writing data to the HDD. Have you tried switching hard drives with your brother? It can be a corrupt sector or the entire disk. Try to format the disk and try again or switch your hard drive with your brother's or if you have the cash, buy a new hard drive for your ps3. Regards. Hope it helps.
PS: If you try using your brother's hard drive in your PS3 you will have to format it so I suggest you do a backup.
Dec 03, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 Slim  Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
