Question about Dometic Refrigerators
Broken door hinge on a DM2652. Plastic on door broke.
The top plastic socket in the bottom door cracked and the door fell off. Can I get parts for the door? Looks like if I take off the plastic in the center, I can get to the hinge mounts.
  • 41 Answers
SOURCE: What is the little round white plastic circle that
That part is called a HINGE BUSHING,it's what the pin slides into and keeps the door in line and fits snugly on the hinge pin.
Posted on Aug 25, 2009
  • 101 Answers
SOURCE: Marvel, Model 61 RF ww-F made in 7-19-2000
Dear John,
Contact the factory directly at 800-223-3900 8:00am to 5:00 pm EST. I believe the bar pn is 42241938 (for the 2nd and third bar) and the top bar pn is 42241937. (I am going by memory so have them verify it). They also have a kit that has both side hinges and new springs for the freezer door. If you can't get through via phone contact Tim Malloy using tmalloy@northlandnka.com. He's a little overloaded but should get back to you within a day or two.
Posted on Nov 02, 2009
  • 234 Answers
SOURCE: I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
Posted on Dec 27, 2009
SOURCE: dometic rm2804 door hinges are worn and plastic
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Posted on Nov 28, 2010
  • 207 Answers
SOURCE: Just received a Beko Larder
The cap probably goes on the the hinge part, most likely on the top just for looks.
Posted on Mar 24, 2011
Need refrigerator door for Dometic RM7732. Bottom hinge is broken...i.e. and the end of the plastic molding on the bottom of the door..wood panel look.. Looking for salvage door. Does anyone have one?
I suggest you contact your local Yahoo freecycle group and place a request for the item you need. I understand there are other but similar sites that you could try.
I understand social networking sites can also be helpful in such matters.
These days old fridges can't be just dumped and they must be disposed of at official recycling centres. You might find what you are seeking at one or these.
Screws into thin metal or plastic rarely work. The fact the thing broke in the first place is testament to a design not fit for the purpose. It is possible with modern materials and a degree of old-fashioned cunning to make good repairs of such things.
I have recently repaired a pedestal fan with a similar design fault - top heavy design supported by thin plastic that soon grew tired and broke. I glued the parts together with an epoxy resin and then using a thin card template cut and shaped two aluminium reinforcers that I also glued into place using epoxy.
There must be a dozen sorts of filler and bonding filler available, thin metals that are strong but easily cut and shaped, some fantastic adhesives and a wide variety of methods.
One guy I know broke a plastic part on his car. He asked me to drill a series of holes each side of the break and sew it together with thin wire. Once it had been prepared, filled and painted it was as strong as it needed to be.
All these things need is a bit of knowledge and experience and a devious mind...
Jun 29, 2016 | Cars & Trucks
Plastic hinge brokeand screws fell out need replacement
Hi Carol....what exactly is it that you need a hinge for? Please
advise product, make and model and we will do our best to
help you.
Regards,
Dennis
Oct 12, 2014 | Televison & Video
Broken plastic door hinge
You can contact Viking here or call 1-888-845-4641.
Aug 21, 2012 | Viking VMOC205SS Microwave Oven
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
Strange thing over night my refrigerator has lost the suction in the doors. I have to close the door and hold the door close, to keep it close
there is a plastic part that attaches to the lower hinge that helps keep the door closed. it is like a rocker that when the door is open the door rides up on the plastic rocker then as you close the door the door rides down on the hinge rocker and helps to force it closed. mine stopped closing on it's own then all of a sudden the black plastic piece broke and fell to the floor. I am ordering a new piece if I can find the part number.
Mar 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
Dec 27, 2009 | Dometic RM2652 Refrigerator
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
Jun 25, 2009 | Dometic Refrigerators
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Front vent fell off
This should be a very easy fix. I assume you are talking about the plastic vent grill on the top of the oven above the door. There should only be a couple of screws holding it in from the top. The grill then should tilt out from the top first then from the bottom to remove. Since you said that it had fallen off, it sounds like the tabs where the screw holes are have broken off. This is a common problem. You can buy the part by ordering from the manufacturer, or from most repair websites. All you need is the model number from the microwave. Good luck.
Jun 19, 2007 | GE JVM3670 Microwave Oven
Refrigerators Logo
63 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
