Question about GE JSP26 Electric Kitchen Range
F2 Error GE JSP28GP Electric Range - GE JSP26 Electric Kitchen Range
jumptrout51
  • 3361 Answers
SOURCE: GE Self Cleaning Gas Range F2 Error, happens at
Your oven temperature sensor must be replaced. It is located in the oven compartment up high, may be right or left side depending on model. Smaller than a pencil about 3&1/2 inches long.
Posted on Jul 25, 2009
fixyourboard
  • 310 Answers
SOURCE: I have an electric range, model # J SP42SOK4SS.
This means the controller is sensing a stuck key, which may be due to an actual stuck key or a problem with the controller. There is a way to diagnose which is the cause if you are comfortable tearing into the unit, or a repair tech can quickly diagnose for you. If you need a controller, you might consider having us rebuild it for you.
Regards,
Bruce
www.fixyourboard.com
Posted on Oct 10, 2009
Icebassman 5
  • 57 Answers
SOURCE: F2 and F3 Errors just started on my GE Electric Range
Try to unplug the oven for about 10 minutes. It might reset itself.
Iceman.
Posted on Nov 10, 2009
Testimonial: "Thank you very much Iceman! Prompt and helpful."
  • 1891 Answers
SOURCE: GE spectra JBP66 electric oven that displays the F2
f 2 code states that oven has exccded 590 deg w/door in unlocked position or 990 f in locked . either the themp prop is bad or the relay in the EOC ( clock ) is welded closed . I would replace the prob first ( less expensive ) then the clock if needed .. **** ..
Posted on Dec 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: GE Spacemaker JMP28 Electric Kitchen Range F1 error message
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
(*UJ
Posted on Oct 01, 2010
F2 error code on GE Spectra JBP78
F2 indicates that temperature inside the oven has gotten to high. Pull the temp probe and check to see if it has 1100 Ohms. If it does, you will need to replace the control board.
Here is the probe to order if it is bad.
Here is the control board to order if the probe is good.
Keep me posted!
Jan 19, 2013 | GE Spectra JBP78 Electric Kitchen Range
F2 reading and steady beeping sound on GE spectra oven after oven has been on.....how do i fix
The F2 error code is for the temp sensor. The temp sensor is mounted inside the oven cavity & regulates the oven set temperature. If the temp sensor fails the oven could overheat. This is what generates the error codes. I recommend having the temp sensor checked with an ohm meter, at room temperature the sensor should ohm out at approx 1100 ohms. If the sensor checks ok, then the control will need to be replaced.
Jan 21, 2011 | GE Profile JB968 Electric Kitchen Range
GE oven error code f2 is displayed
Hi
Thanks for using FixYa. Error F2 in your oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 24, 2010 | GE JRP28 Electric Double Oven
My ge electric range keeps on beeping f2
The F2 error code means: For an unknown reason, the oven temperature has exceeded a preset threshold.
This is GE's recommendation:
Before Calling Service, you can try the following...
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code, however there are some cases when further service may be required. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
GE does recommend turning the range or oven off at the breaker until you have it serviced. It is okay to cycle the breaker and turn the range or oven back on long enough to use the surface units. Be sure to turn the range or oven off at the breaker again when you have finished.
May 17, 2010 | Kitchen Ranges
Error code f2 broiler comes on by itself and won't shut off
F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
Mar 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
I have a GE Range. Purchased in 1993. The user guide says it is for JSP26GP, JSP28GP, JSP31GP. The thing won't quit beeping and the function code displayed if F1. What should I do? Thanks!
The F1 error code means your oven temperature has exceeded 590 degrees and the beeping is to warn you to shut it off.
Itis likely that the oven thermostat has failed, so you will need to get it replaced.
Jan 04, 2010 | GE Ovens
Dec 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
I had to clean the contacts in the control panel to fix my same problem.
Nov 10, 2009 | GE Kitchen Ranges
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
F2 error code on GE built in Oven Model JKP13GOP
Your error code means this. F2 For an unknown reason, the oven temperature has exceeded a preset threshold.
Good Lock and Please Rate FixYa!
Dec 27, 2008 | GE JBP90 Electric Kitchen Range
GE JSP26 Electric Kitchen Range Logo
98 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
